Old 08-09-2011, 03:08 PM   #71 (permalink)
CigaR007's Avatar
GreenTurtle (Retired) - '01 Toyota Echo Sedan
90 day: 44.85 mpg (US)
Zulu - '14 Honda CR-Z
90 day: 49.05 mpg (US)
Thank you for the kind words.
As you can see throughout this thread, my grille blocks have evolved and I see that as a leap forward in terms of design, fabrication and efficiency. I must admit though, this whole process is very time-consuming but it is fun, so it is worthwhile.
Currently applying the final coats of electric green mica on the upper grille block. It looks like it will be very stealthy once installed on the car.
Old 08-09-2011, 03:31 PM   #72 (permalink)
graydonengineering's Avatar
Frontier 2wd 2.4L 5 speed - '98 Nissan Frontier XE
90 day: 27.87 mpg (US)
Looking great! I am thinking of doing something similar for my lower bumper. I was thinking of boxing off the slot to be pluged with plastic wrap all to make a sealed chamber and then injection expanding foam (such as Great Stuff) untill it is filled. Do you think this method would work? After that I would want to coat it and paint it. The resin coat looks like it is working well but labor intensive.
-Miles
Best 15-mile commute city/highway mix: 37.7 mpg
Best tank so far: 31 mpg
Old 08-09-2011, 11:58 PM   #73 (permalink)
Grasshopper
alohaspirit's Avatar
Makai - '01 Toyota Echo 4D Auto
90 day: 34.45 mpg (US)
New Galaxy - '07 Toyota Prius
90 day: 42.15 mpg (US)
excellent job ciga
ive been MIA from the board but keeping up with my gas log
unfortunately no grill blocks can be used where i am but yours is the way to go
are you having a paint shop put the paint in a spray can for you?
Past Present Future?
Old 08-10-2011, 12:13 AM   #74 (permalink)
CigaR007's Avatar
Yup. Simply asked for colour code 6R4 (electric green mica) and the mixture was made on the spot, in 10-15 minutes.
The paint has been drying for the past few hours.
I should have a pic of the grille block on the car tomorrow.
I have yet to finish the new lower grille block though.
Old 08-10-2011, 12:50 AM   #75 (permalink)
CigaR007's Avatar
Expanding foam does wonders, but requires a fair amount of preparation in order to yield good results. Patience is key.
As per the pics, I used aluminum foil to seal and protect the surface. Plastic wrap should work too. The amount of surface preparation depends on whether or not you want the grille/bumper block to be permanently fixed/attached, or the flexibility of being able to remove it whenever you want. I chose the latter.
Albeit, I will admit that great stuff foam should be easier to deal with, since it is less messy and easily controllable. The 2-part polyurethane foam I used (PartA/PartB) requires mixing the two parts with a 1:1 ratio and you have a limited amount of time to pour the liquid before the foam starts expanding. I had a hard time in the beginning but easily managed to get the hang of it. Live and learn.
This whole fabrication of foam grille blocks has its learning curve, I will tell you that.
The Following User Says Thank You to CigaR007 For This Useful Post:
graydonengineering (08-10-2011)
Old 08-10-2011, 01:41 PM   #76 (permalink)
CigaR007's Avatar
The car needs a wash but here is the final result of the upper grille block.
A-B-A-B test will be done eventually. Need to brush up on the how-to.
The Following 4 Users Say Thank You to CigaR007 For This Useful Post:
BamZipPow (08-10-2011), Daox (08-18-2011), graydonengineering (08-11-2011), UltArc (06-15-2014)
Old 08-10-2011, 03:15 PM   #77 (permalink)
Looks great especially with the matching paint.
The Following User Says Thank You to jeremy96gase For This Useful Post:
CigaR007 (08-10-2011)
Old 08-11-2011, 03:05 AM   #78 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Looks really good. Makes your car unique in a subtle way. I like. Do most of the lower grill too. Duct air to the radiator through the remaining opening. That would look cool too.
CigaR007 (08-11-2011)
Old 08-11-2011, 04:11 PM   #79 (permalink)
CigaR007's Avatar
Yup, currently working on it. Hopefully it will be done by the end of the week.
Old 08-11-2011, 07:03 PM   #80 (permalink)
Gives the front end that smooth EV car look. Nice! How did you decide keep them held in place?
-Miles
The Following User Says Thank You to graydonengineering For This Useful Post:
aero mod, grille block, toyota echo
