Old 07-31-2018, 06:30 PM   #71 (permalink)
Bimmer - '02 BMW 325ci
90 day: 23.79 mpg (US)
Originally Posted by Vman455 View Post
Aqueous ethylene glycol decomposes into carbon monoxide and diatomic hydrogen (hydrogen gas) if it gets hot enough.
At what temp? Water would also split into oxygen and hydrogen if you heat it to 2000'C.
Old 07-31-2018, 08:51 PM   #72 (permalink)
Originally Posted by engineered View Post
Since this has been revived, why not use a 12V block heater and/or 12V oil pan heater to heat up the fluids? They could be used manually or controlled automatically to come on with the car and turn off at a certain coolant temp (or from the tstat).
The purpose of this thread is to use 'free' exhaust heat to speed up the warming of the engine to decrease fuel consumption.
A block heater does work, if you have 110V power. If you don't, this device can and will help.
Using 12V power from the alternator will actually increase fuel consumption, not decrease it. So that kind of defeats the purpose we are going for at least, though you would get heat quicker. VW actually does do this with their TDI engines to get them up to temperature faster.
How would coolant water (and glycol) degrade? It doesn't break down like motor oil. I'm mean if you overheat it, it would eventually vaporize, but 98'C water is always going to be the same water.
Vman is correct. Ethlyene glycol is only supposed to be good to 250F / 121C. It will start cracking at around 285F / 140C according to this paper (page 16). That is certainly achievable by warming the coolant with the exhaust. I'm not sure if the water will start boiling out before that point or not, but if it does, thats not good either.
The Following User Says Thank You to Daox For This Useful Post:
Xist (08-03-2018)
Old 07-31-2018, 09:03 PM   #73 (permalink)
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
I’d also note that the quality of 12volt energy is limited. Even with VW’s large battery and alternator the difference in warm up time isn’t noticeable to the average driver with the system disabled. The gen 3 Prius warm up time is genuinely impressive until you move to EV’s and expect heat instantly.
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
Old 07-31-2018, 10:29 PM   #74 (permalink)
Vman is correct. Ethlyene glycol is only supposed to be (page 16). That is certainly achievable by warming the coolant with the exhaust. I'm not sure if the water will start boiling out before that point or not, but if it does, thats not good either.
I agree that the exhaust heat is 100% free, while a 12V heater is not. I guess I was thinking people were looking to heat the engine up quicker to reach operating temps faster.
With a 100A alternator, a 12V heater could put out more than 1kW of heat into the coolant, which is very little compared to an idling engine, say 5hp (3.7kW), so the engine is already putting 4x more heat into the fluids. Still, 1kw heater would add 27% more heat, but barely noticeable to a driver. Gently driving around using 100hp(75kW) would put out 75x more heat and make the 12V heater very insignificant.
Old 08-01-2018, 10:36 AM   #75 (permalink)
Why complicate things. Just get an EGR cooler that has the valve built in. Then you just need a 12v vacuum pump to activate (based on the temperature sensing relay) to keep it open to let hot exhaust through during warmup. Then close it once up to temperature to stop it boiling the coolant in the egr cooler.
Old 08-01-2018, 11:20 AM   #76 (permalink)
I believe that is basically what the Borg Warner unit is. Only, it is electronically actuated, not vacuum actuated.
Old 08-01-2018, 12:54 PM   #77 (permalink)
90 day: 39.72 mpg (US)
90 day: 59.69 mpg (US)
G1 Insight:
2006 Civic:
2008+ Accord, 2009+ TSX, 2012+ Civic Si:
2009+ Honda Fit:
The Following 2 Users Say Thank You to Ecky For This Useful Post:
Daox (08-01-2018), Xist (08-03-2018)
Old 08-01-2018, 05:16 PM   #78 (permalink)
Master Ecomadman
arcosine's Avatar
sc1 - '98 saturn sc1
Team Saturn
90 day: 43.17 mpg (US)
rans - '97 rans tailwind
90 day: 28.25 mpg (US)
red bug - '00 VW beetle TDI
big tractor - '66 ford 3400
90 day: 58.42 mpg (US)
RV - '88 Winnebago LeSharo
90 day: 16.67 mpg (US)
v8 engines of the sixties and earlier had a bimetallic spring and a flapper valve on one exhaust manifold that would divert exhaust through the intake manifold during warm up, nothing new here.
Just use an on-off valve to let coolant into your exhaust heat exhanger when cold, turn the valve off when warm. Have a check valve at the bottom to let coolant out of the exchanger when it boils. When it all boils out, no problem. Make it from welded stainless steel.
- Tony
PBS takes the Hummer v Prius bait SVOboy Hybrids 51 05-19-2010 01:35 PM
Converting Exhaust Heat to Electricity SuperTrooper General Efficiency Discussion 13 03-20-2010 07:03 AM
Waste Heat from Exhaust TES111 EcoModding Central 35 11-21-2008 01:31 PM
Why does the heater core transfer heat from the coolant, not the exhaust? extragoode General Efficiency Discussion 23 10-17-2008 11:44 AM
Steam engine (from exhaust heat) iHero General Efficiency Discussion 23 09-08-2008 01:30 AM
