Old 10-13-2022, 07:06 PM   #411 (permalink)
90 day: 51.82 mpg (US)
Thanks!
It's hard to believe I've had the car for 6 full years now (just over 15k km / 9k miles driven).
I still really enjoy driving it. It's a pretty zen experience cruising along the river or through the countryside in an open car on a beautiful day. More so than motorcycling, in my experience.
I envy the owners of the latest Miata/MX5, though. They'd probably be getting 50+ mpg with 1/2 the effort. And at higher speeds.
Old 10-13-2022, 07:10 PM   #412 (permalink)
90 day: 39.72 mpg (US)
90 day: 59.69 mpg (US)
Thanks!
More like 40 in my case, but the driving conditions are different, and my tires are most certainly not eco.
Steady cruising at ~100kph looks to be 40-45mpg, top down, using no tricks.
MetroMPG (10-13-2022)
Old 10-13-2022, 07:24 PM   #413 (permalink)
Level roads, I'd say mine is good for about 45 mpg cruising at 80 km/h = 50 mph.
Sounds you'd probably be close to 50 at that speed?
Getting 50+ in mine requires a lower average speed & operating the engine like it's a hybrid whenever I'm off the power. Not to mention all the ecomods.
Old 10-13-2022, 07:57 PM   #414 (permalink)
With high performance summer tires, and no major ecomods yet, I'd say low 50's is achievable steady-state cruising at 80kph.
I probably ought to make a speed vs mpg chart, now that you mention it.
The Following 2 Users Say Thank You to Ecky For This Useful Post:
Gasoline Fumes (10-15-2022), MetroMPG (10-13-2022)
Old 10-14-2022, 07:07 PM   #415 (permalink)
Not very aerodynamic, but fun & useful!
Transplanting a young white pine from my friends' place to mine.
The Following 3 Users Say Thank You to MetroMPG For This Useful Post:
Cd (10-14-2022), Ecky (10-14-2022), Gasoline Fumes (10-15-2022)
Old 10-14-2022, 08:46 PM   #416 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Great to see you are still posting on the forum !
Now you can tell people that you literally stuffed a TREE in your Miata.
The Following User Says Thank You to Cd For This Useful Post:
MetroMPG (10-17-2022)
Old 10-16-2022, 12:13 PM   #417 (permalink)
+5 MPG!
One of these things is not like the other!!
Old one stuck wide open! This is going to really improve warm-up times.
Parts store says the replacement is a 192 degree unit.
COcyclist (10-17-2022)
Old 10-17-2022, 02:31 PM   #418 (permalink)
t-stat results
Wow! Big improvement with the new t-stat. It warms up like a normal car now - the needle is off the peg within one km of a cold soak start, where before it took many, many kms. And that's with a 90% (manually adjustable) grille block.
I don't know if it's possible, but I'd bet the old t-stat failed gradually, because I remember that it WAS working when I got the car (I tested it in a pot on the stove). I would have noticed a change this dramatic. So I'm thinking I got used to progressively longer warm-up times, until I noticed recently that running the heater dropped the temp significantly (even on low fan speeds).
Coincidence that yesterday saw a record setting segment MPG (by about 2) on a well-travelled route? Probably, right?
Also new: The engine RPM behaves differently with the new t-stat. It's doing some rev-hang between gears that it didn't do before. So, probably past a coolant temp-sensitive programming threshold it wasn't reaching before.
Ecky (10-17-2022)
Old 10-17-2022, 03:17 PM   #419 (permalink)
Makes me wonder about the XFi's thermostat now.
You can't be wise and in love at the same time. -- Bob Dylan
Old 10-17-2022, 03:21 PM   #420 (permalink)
In the KSight I had a similar issue. I couldn't imagine how a brand new thermostat had failed open. Turns out when I had added a sensor to the thermostat housing, I didn't realize it was too long and was holding the thermostat open. Made a huge difference.
COcyclist (12-02-2022)
