Old 11-21-2012, 03:29 AM   #1031 (permalink)
Hi! I had mpguino in my car long time ago then I removed it and now I tried to put it back in and run on some problems.
My mpguino now causes misfire when i connect it to car. Wiring is the same as before and it run without problems. Vss works normal, but as soon as I connect inj, idle gets rough, I can smell gas and got CEL and codes - random cylinder misfire on 1. and 3. cylinder... I am pretty sure wiring is correct, only differences are - I built a stand alone circuit refering to this diagram - http://opengauge.googlecode.com/svn/...no/mpguino.png and intead on using 50k resistors I used 67k and 1/4w zener diodes which are smaller then those I used before. What could cause these problems?
I googled around and could not find simmilar problem.
Vehicle is Lexus, so basicly a Toyota...
Thanks!
Old 11-21-2012, 04:22 AM   #1032 (permalink)
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
Check if you connected (soldered in) your Zener diodes corectly, and if those resistors you've used are really above 50kOhm. It seems that you are giving falze zero signal to injestor and it stays opened. That's why you get missfire, and you can smell gasoline.
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
The Following User Says Thank You to AndrzejM For This Useful Post:
njakts (11-21-2012)
Old 11-21-2012, 06:03 AM   #1033 (permalink)
You are right!
I figured that out myself on my way home from university
Zener diodes were soldered in parralel with 50k resistor (67k in my case, just double-checked)
Should work fine now.
Thanks!
Old 12-17-2012, 10:37 PM   #1034 (permalink)
Originally Posted by FalconFour View Post
^ Actually, you'll want to use this code instead: http://opengauge.googlecode.com/svn/...no/mpguino.cpp
I don't know why the "PDE" file stays up on the SVN page, it's moldy-oldy and faaaaar out of date. Now that everyone with an Arduino is using the (now-)standard '328 chip, there's zero concern of optimizing bytes in the compiled code... so the ye-olde PDE version should just be taken out back and shot, IMO.
Only thing you'll need to do is adjust the timing values (commented out) in the cpp version, if you're using a 16MHz Arduino as opposed to the 20MHz crystal in the prebuilt MPGuino board. Near the top, look for the section that says "//use with 16mhz, not tested" (it works fine). Match up the commented-out 16MHz values with the active 20MHz counterparts, and swap commenting ("//") on them, and you'll have 16MHz timing. Otherwise everything will be incorrectly displayed and timed on a 16MHz board.
Of course, over the next week or so I hope to start work on gutting and rebuilding MPGuino's code from the ground up, so this may not be too relevant in the near future...
I'm working on a version for the older European Diesels and have a couple of questions they relate to the pulse info from the fuel flow sensors. It's been noticed you can't do a good instantaneous flow from just reading & subtracting the pulses. It looks like you need to measure the time period between pulses from sensors and use that to determine your instantaneous flow rates. As I under stand the code this is how the instantaneous speed is determined. I also doubt you can use the interrupts from pins 4 for 1 sensor and pin 5 for the other, as the interrupts may hit at the wrong time. what's your opinion
Old 01-09-2013, 07:25 PM   #1035 (permalink)
Guys, how can I make MPGuino round all values to only one decimal? I've found format function, but I'm not sure how to modify it to give only one digit precision after decimal point.
Any help is appreciated.
Old 01-14-2013, 08:58 PM   #1036 (permalink)
Anyone?
Old 02-27-2013, 06:08 PM   #1037 (permalink)
Originally Posted by mosier View Post
dcb:
What method did you use to calculate your microseconds per gallon?
For a DOHC Saturn, with 21lb/hr injectors I get
Code:
21.00       lbs/hr
6.25        lbs/gal gas  (~72 deg F gas)
3.36        gal/hr
17.86       minutes/gal
1,071.43    seconds/gal
1,071,428,571.43	microseconds/gal  per injector
267,857,142.86          microseconds/gal with 4 injectors?
Fuel temperature will have a big impact on the calculation, I wonder how scanguage or oem systems handle this (ignore it?).
I just put in my order, and hope to get it running on my non-obdii SL1 pretty soon..
I tried your by-hand formula versus the Excel Spreadsheet calculator posted on the Ecomodder.com Wiki, as applied to my 1991 Jeep Cherokee Laredo 4.0L Inline-Six engine, and found two different numbers as a result, with a variation of 7,894,737 between the 197,368,421 as done by hand, versus 189,473,684 as calculated by the Excel Spreadsheet calculator.
My advice, in this case, would be to try each of both numbers, first the low, then the high, then adjust incrementally by around 5-10% of the difference (193,421,053, in my vehicle's case) until you find the actual "Sweet-Spot" for accurate fuel consumption numbers. I have found my MPG numbers are POSSIBLY off by as much as 10-15% or MORE when just using the Excel Spreadsheet calculator's number, otherwise. Hope this helps, even if only a little...
Edit: Just tested out my theory, based on the two calculations and found that also dropping BELOW the lower calculated Microseconds-per-Gallon by the calculated difference between both numbers MAY also have a positive effect on accuracy of the Microseconds-per-Gallon equation. More testing AND re-calibration of the MPGuino will be necessary in order to confirm this, of course.
Old 04-28-2013, 03:27 PM   #1038 (permalink)
stewie's Avatar
Milano Red VX - '92 Honda Civic VX
90 day: 50.15 mpg (US)
Originally Posted by Yoshi View Post
Just FYI...
I would like to explain how fuel parameter is set for Honda VX on my SuperMID.
MPGuino release one workspace - Page 9 - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com
I use the fuel parameter 14220 for Honda VX.
The count tick is 5 usec, therefore the 14220 means 71100 usec per 1 milli-liter fuel usage.
Please note that I subtract 100 ticks (500 usec) from each injector on time for the mechanical delay (injectorSettleTime on your source which never been used).
so...
71100 usec/milli-liter -> 71100 X 1000 X 3.785 = 269113500 microSecondsPerGallon
Regards,
Yoshi
Thanks Yoshi for that setting. What are rest of the settings suppose to be set to? I got finger happy and changed some by accident when i got it like delay of injector etc. Can you provide those as well please. Also are rest of the settings car specific. Also if anyone with HOnda Civic VX can chime in and fill in the blanks that would be good. Thank you in advance.
VSS PULSES/MINUTE = 8208 per wiki page
Microsec/Gallon = please provide yours and why is yours different? Using Yoshi of 269113500
Pulses/2Rev = 1 per wiki
Timeout =
Tank Gal = 10000 (mine tank always seems like 10 gal)
Injector DelayuS = ???????????????????? PROBABLY IMPORTANT
Weight (lbs) = 2094
Scratchpad (odo?) = what is this?
VSS DELAY MS = ???????????????????? PROBABLY IMPORTANT
INJTRG 0-DN 1-UP =???????????????...WHAT IS THIS? PROBABLY IMPORTANT
Also what is the difference between current and instant mpgs screens?
Old 04-30-2013, 01:46 AM   #1039 (permalink)
I just received my MPGunio!!! I need to install it into a 1994 gmc k2500 turbo diesel.
It uses a PMD, pump mounted driver that uses pulse width to vary injector output. It controls All 8 injectors so I'm hoping the MPGunio can handle that many pulses vs 1 per cyl
Also, has Anyone connected a MPGunio to a gm pickup speedo...and if so what settings? I'm glad there are still those that know these units inside and out!
Old 04-30-2013, 02:58 AM   #1040 (permalink)
AndrzejM's Avatar
Congrats! You'll love it like I do I'm totally in love with my MPGuino
Anyway - you don't need any specific settings for your car to make your guino working properly in virtually no time. I've explained the procedure to Stewie here MPGuino calibration procedure. Feel free to use it
And please share your experience with installing guino in your diesel!
Good luck
My kingdom for a giant, heated workspace MetroMPG The Lounge 14 12-12-2010 09:08 AM
Motorcycle manufacturers beginning to release MPG info MetroMPG Motorcycles / Scooters 1 04-03-2008 05:23 PM
