11-25-2008, 10:25 PM
#261 (permalink)
Block heaters are great to have, they are very very necessary here in Saskatchewan, Canada. It gets to -40C here in the winter somtimes and with the wind can get to below -50C. You really notice that your tires are not fully inflated when the temperature drops to -20C, they develop a flat spot that doesn't go away because of the tire being so COLD and it feels like you have square tires for about a block.
11-26-2008, 06:22 AM
#262 (permalink)
Hi-Tech Redneck
Temp readings this morning with the Solus Scanner read 90 degrees F and outside temp was 32.
GeoMetroforum.com - got mpg?
12-16-2008, 09:02 PM
#263 (permalink)
Hi-Tech Redneck
Went from the P155/80R13 to the P175/70R13 tires and got 4 new one's for $100.00.......
Also had a caliper hanging up, so did a complete front brake job, but saved rotors........
New window sticker................
12-17-2008, 10:01 AM
#264 (permalink)
Have you no shame?
Why the switch to fatter tires?
12-17-2008, 08:06 PM
#265 (permalink)
Hi-Tech Redneck
Price
Handling, stability, and a sidewall max rating of 50 PSI compared to 44 PSI, so I am not sure about the hit on MPG's since the weather is really messing up my fuel log. These larger tires even fill it out some and they look better. I have not seen the sun in a couple months, so when we get a nice day, I'll clean it up and take some pics.
03-23-2009, 06:05 PM
#266 (permalink)
Hi-Tech Redneck
It never ends. I am currently rebuilding a head to have a spare for either me or someone who needs it, but everything changed recently. I have received a few things in the mail from 3Tech Performance and am going all out. The head I am rebuilding is being documented here........
Head Rebuild Project............
I now have an economy grind camshaft, head bolts, and a 10 degree advanced timing gear......
I am going to also cut Singh grooves into this head for experimental purposes and fuel economy testing.........
More info on that here...........
Somender Singh grooves in a Geo Metro!
SOMENDER-SINGH.com - Home
03-23-2009, 07:23 PM
#267 (permalink)
Renaissance Man
It cracks me up looking at a camshaft with six lobes!
03-23-2009, 09:40 PM
#268 (permalink)
Any plans to mill it down a little?
03-25-2009, 10:31 PM
#269 (permalink)
Hi-Tech Redneck
Well, I thought about planing the head. One of the guys I work with wants to port and polish the head for me and brought in his tools.........
He re did one of my combustion chambers and I was impressed.........
I also got my new valves and seals...............
Muhahahahahaa!
04-27-2009, 10:00 PM
#270 (permalink)
Hi-Tech Redneck
Installed new door moldings on the side of the car................
Yes, I installed a passenger side mirror again. Crazy people like to pass on the right because I drive too slow.
Also painted the rusty wiper arms red.................
Last, but not least, installed a 3Tech XFi cam and advanced (10 degree) timing gear.........
Now we should see 60+ all summer long!
