Old 09-22-2019, 09:27 PM   #31 (permalink)
mpg_numbers_guy's Avatar
Toby - '13 Toyota Prius C
90 day: 63.99 mpg (US)
Daz - '15 Mazda 3 iTouring w/ Tech Package
Team Mazda
90 day: 38.2 mpg (US)
Hm. My Insight can lean burn up to 72 mph on level ground at ~80 mpg in the summer. Haven't driven it that fast in the winter but I doubt I'd be able to maintain speed while lean burning in the cold. I wonder what's causing lean burn not to work well for you over 40 mph? Is this the case with both of your Insights?
2013 Toyota Prius C 2 (my car)
2015 Mazda 3 iTouring Hatchback w/ Tech Package (wife's car)
Old 09-23-2019, 10:24 AM   #32 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
I couldn't tell you how my other Insight drives.
I could try its ECM, but I doubt that's the issue.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
The Following User Says Thank You to Gasoline Fumes For This Useful Post:
Ecky (09-23-2019)
Old 12-01-2019, 01:36 AM   #33 (permalink)
Too many cars
Gen-1 Insights
Gen-1 Insights
145/65-15 Yokohama Ice Guard IG20 snow tires on Honda Civic donut wheels. No change in tire weight, but the wheels add a total of 34 pounds!
ID:	27267   Click image for larger version
ID:	27268   Click image for larger version
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
1988 Honda CRXFi
1994 Geo Metro
Old 12-02-2019, 12:33 AM   #34 (permalink)
Engine-Off-Coast
Natalya's Avatar
Red 2000 Insight (2017 through 2019) - '00 Honda Insight 5MT
90 day: 64.72 mpg (US)
Red 2000 Lithium Insight (2020) - '00 Honda Insight LTO
90 day: 71.76 mpg (US)
Oh gosh you're in winter hell with heavy wheels. No wonder your car is struggling.
What I did when I lived in Ontario was I got a set of Civic VX rims with all seasons on them. But it would be better if you got snows on them. The lower rotational mass on the VX rims helps counteract the fact that the tires aren't low rolling resistance.
Getting the missing aero taken care of will help too but the wheels are definitely what's killing your ability to stay in lean burn.
If you have time to read 6 pages of posts I talked with the guys on Insight Central in 2016 about this same issue. I also made a new post today about using 4th gear in lean burn, but that still might not help because of those heavy wheels.
The Following User Says Thank You to Natalya For This Useful Post:
Gasoline Fumes (12-02-2019)
Old 12-02-2019, 09:48 AM   #35 (permalink)
Too many cars
Gen-1 Insights
Gen-1 Insights
I read the first and last page. I'll have to experiment with 4th gear more. I just put the winter wheels on, I was complaining about the car with RE92s at 60-65 PSI. I'm assuming the bucking at part-throttle has something to do with the MPG issues.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
1988 Honda CRXFi
1994 Geo Metro
Old 12-07-2019, 12:27 AM   #36 (permalink)
Engine-Off-Coast
Natalya's Avatar
If it's still bucking after EGR plate clean you might need a new EGR valve as well.
You want the Dorman one with part number 911-756
You want to avoid most of the EGR valves out there. Most of them have a smaller opening which can cause you to get P1491 check engine light because the passage is too narrow.
I haven't tried this one but the valve passage looks to be the same as on the Insight, maybe this one works fine:
https://www.ebay.com/itm/GENUINE-OEM...MAAOSw9a5XPrDx
It's cheaper than the Dorman I referred to above.
The Following 2 Users Say Thank You to Natalya For This Useful Post:
Gasoline Fumes (12-08-2019), Xist (12-10-2019)
Old 12-08-2019, 12:07 PM   #37 (permalink)
Master procastinator
Turan turan - '09 Volkswagen Touran Freestyle
Combot - '04 Opel Combo Tour
90 day: 40.37 mpg (US)
Just out of curiosity, why the donut wheels?
Old 12-08-2019, 12:27 PM   #38 (permalink)
Too many cars
Gen-1 Insights
Gen-1 Insights
Thanks! Can the EGR valve be tested? I prefer not to buy parts unless I know I need them.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
1988 Honda CRXFi
1994 Geo Metro
Old 12-08-2019, 12:29 PM   #39 (permalink)
Too many cars
Gen-1 Insights
Gen-1 Insights
Normal 15" wheels would be too wide for these tires.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
1988 Honda CRXFi
1994 Geo Metro
Xist (12-10-2019)
Old 12-09-2019, 12:00 AM   #40 (permalink)
Engine-Off-Coast
Natalya's Avatar
If it's bucking in lean burn and you cleaned the egr passages then the egr valve is the main culprit. I'm not sure if it could be something else. I don't know how to test it unless you have a friend with an Insight and a good EGR valve you can try who lives near you. It's not super hard to pull the valve out.
