10-04-2019, 01:34 AM
#21 (permalink)
Originally Posted by Xist
How many women is she?
IF I had said woman, it would have been a bad description. She's an artist, a baker, a graphics design maker. She designs the garden & prepares for the ghosts & goblins of Halloween. Married to her, I feel that I have a harem. My slip of the typing finger, said what I needed to say about her.
The Following User Says Thank You to litesong For This Useful Post:
10-04-2019, 02:32 AM
#22 (permalink)
10-04-2019, 09:30 AM
#23 (permalink)
Redneck Ecomodder
Alright folks, now that I have the Camry it's question time. The car has 195/70r14 tires. RE92 are 165/65r14. I'm not sure I could narrow up that much, and even if I could I don't really want to go to a shorter diameter as I'm not sure the LRR would pay off. That said, are there any other notable LRR tires closer to my stock size? (or a little taller, plenty of room in the wheel wells). I also don't want to spend a fortune, I can get cheapos in this size for $40-60 a piece, and I'm going to get a pair of winter tires and an extra pair of wheels shortly. I can probably make it to summer with two of the current tires on the back, winter on the front, then replace the rear tires I run this winter with summer tires come spring, and run the other two current tires on the rear through summer, then replace those the next spring.
Kinda rambly, but any input is greatly appreciated.
10-04-2019, 09:56 AM
#24 (permalink)
Redneck Ecomodder
Originally Posted by roosterk0031
Do you want to keep stock rims? I'm running Nokian WRG3/4 on all mine(not the Cruze yet), 195-60(or 65)-15 wouldn't be much taller if willing to get new rims and no need for winter tires then. About $90 each though.
Not looking to spend a lot of money on this car right now as I'm closing on a house in three weeks. Also I like smaller rim sizes, and I'll probably get the same size for my winter pair as my local scrap yard has a couple for $35 each.
Also I don't buy aftermarket wheels, my experience is that their quality is way way subpar compared to factory wheels
10-04-2019, 10:01 AM
#25 (permalink)
I'm really fond of Michelin Defenders, but they're not cheap.
Although they're not marked as LRR, I'm running Vredestein Quatracs on my Insight right now and they seem to have an excellent balance of RR, quiet and grip for such an inexpensive tire.
10-04-2019, 10:31 AM
#26 (permalink)
Redneck Ecomodder
I looked at Hankook Kinergy. Cheap (~$60), good reviews, and a 70k treadlife, but I don't know if they are at all LRR. They were one of the results from a LRR tire google search but who knows?
10-04-2019, 10:42 AM
#27 (permalink)
How will this car be used? I'd be wary of going with a smaller diameter if you're going to be spending any time on the highway (shorter gearing).
The current Prius uses a 195 width 15" tire. Not sure what brand, though it's obviously going to be LRR. Might be worth getting those on some cheap steelies.
Also: I assume this is the I4 engine, not the V6?
10-04-2019, 11:21 AM
#28 (permalink)
Redneck Ecomodder
Yes I4, wouldn't buy a v6 Camry. Definitely not going smaller diameter tires either, I think I could go a size or two taller and be fine though as it has big wheel wells.
10-04-2019, 11:53 AM
#29 (permalink)
Not sure how different your car's drivetrain is from the next gen Camry, but my parents had a 2002 (and now a 2005) I4 that was a surprisingly good highway MPG machine:
Thread: Speed vs. MPG chart: 2002 Toyota Camry 2.4 auto (impressive highway MPG sleeper car?)
Note though the gauge that got me the above numbers was later calibrated against a similar car - they were about 10% high. Still very decent though.
The 2002 Camry drag coefficient is supposedly 0.28. That's decent.
10-04-2019, 12:13 PM
#30 (permalink)
It's a shame hatchbacks aren't as aero as sedans, because I certainly appreciate the utility. I've always thought a sedan looks like the proper shape for a car from an aesthetics perspective though. Any hatchback, regardless of make/model, appears as a utility vehicle to me, and loses all notion of luxury or prestige.
