Old 06-26-2008, 07:26 AM   This thread is in the EcoModder Project Library | #1 (permalink)
MPG...what?
Terkle - '97 Toyota Tercel Whitehawk
90 day: 40.91 mpg (US)
Bubble - '10 Toyota Yaris base
90 day: 41.88 mpg (US)
Deva - '13 Chevrolet Spark LS
90 day: 39.82 mpg (US)
Malibu5 - '82 Chevrolet Malibu Classic
90 day: 17.61 mpg (US)
Highlander - '06 Toyota Highlander Limited
Send a message via AIM to malibuguy
my new underbelly tray (Dodge Caliber)
for the Caliber...
its not perfect, but its there
i need to put 2 more screws up at the corners after the wheels...the are catching some air, plus i have some aluminum sheetmetal that i'd like to use to cover up the center where the exhaust is
then i got to figure out a good solution for doing oil changes...
-Greg...the exhaust freak.
-06 Highlander 3.3awd
-10 Yaris sedan
-97 Tercel, 1NZfe swapped
-96 Tercel
-82 Malibu 1UZfe swapped
-19 Fit (wifey ride)
www.pipedreamsfab.com
Old 06-26-2008, 08:06 AM   #2 (permalink)
vectra a - '95 Opel Vectra GLS
90 day: 37.51 mpg (US)
that looks really great!
for oil changes you might cut a rectangular hole in the right location and make a small hatch
i'd be interested to see what improvements you get...
my undertray is much smaller and although i don't have enough data to be sure i'm suspecing a 1.5 to 2.5 % improvement, wich is what i expected
personaly i'd be a bit worried about the exhaust heat... maybe you want to use some thin aluminum in those areas.
aer·o·dy·nam·ics: the science of passing gass
*i can coast for miles and miles and miles*
Old 06-26-2008, 09:28 AM   #3 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Oooooh ...that is nice !
Old 06-26-2008, 11:14 AM   #4 (permalink)
Looks pretty good.
Old 06-26-2008, 11:32 AM   #5 (permalink)
Nice work. Is there enough room for the air inside the engine compartment to escape?
Old 06-26-2008, 02:02 PM   #6 (permalink)
Cd
Ultimate Fail
Cd's Avatar
If it is anything like my car, the air exits out the wheelwells.
Old 06-26-2008, 02:05 PM   #7 (permalink)
A madman
brucey's Avatar
Pequod - '17 Subaru Outback
90 day: 22.79 mpg (US)
Send a message via AIM to brucey
Looks nice, did you just use exsisting holes to screw it on?
Old 06-26-2008, 03:03 PM   #8 (permalink)
vtec-e's Avatar
De Yaris - '04 toyota yaris T2
90 day: 69.55 mpg (US)
Good job! I'd go with lunarhighway's idea of a hole under the sump plug. If the oil filter is accessible only from the bottom, you may have to make the whole front of the bellypan removeable. Re: covering up the exhaust. I'd monitor temps in there to make sure it doesn't overheat. Naybe a naca duct at the front of the aluminium section to direct a little cool air. Or maybe the engine bay air could go down the exhaust tunnel and out at the back. Watch the gas tank though.....
Malibuguy, whats your mpg gain like with the belly pan?
Old 06-26-2008, 05:38 PM   #9 (permalink)
04Cavalier - '04 Chevrolet Cavalier Base
90 day: 33.83 mpg (US)
Send a message via AIM to Timber334
Well the gas tank will begin melting at a point of between 220 and 265 degrees keep it under that and you will be fine. The coroplast has an even higher melting point, you could use it as a makeshift sheild
Old 06-27-2008, 12:15 AM   #10 (permalink)
I used screen over my exhaust pipes and it is working well.
For oil changes you likely will require two openings. One for the drain and the other for the filter.
You going to continue to the back bumper?
http://ecomodder.com/forum/showthrea...html#post24865
Chrysler Expected To Kill Models, Bring Italian Vehicles Ashore Jammer The Lounge 17 06-26-2010 07:29 PM
Underbelly clean up Phase II EXPIOWA Aerodynamics 3 04-29-2009 01:23 PM
Underbelly smoothing options Sunwapta Aerodynamics 17 11-08-2008 01:41 PM
2007 Dodge Caliber: The Drive DifferentPointofView EcoModding Central 0 06-19-2008 07:58 PM
Dodge ZEO BEV sports car cfg83 General Efficiency Discussion 0 01-16-2008 10:55 PM
