Old 03-26-2009, 01:00 AM   #21 (permalink)
X-Frenchy: very
groar's Avatar
scenic - '01 renault scenic
90 day: 43.09 mpg (US)
megane - '97 renault megane classic
Diesel
90 day: 72.53 mpg (US)
dennisius - '06 Toyota Prius
90 day: 69.27 mpg (US)
I can use my butt-o-meter on my daily commute if you know well a portion of road you can see how the comportment is different. On a couple of small down slopes my car was slowing down and now it's accelerating. Also on a bigger down slope when I leave the top at a given speed, I arrive at a bigger speed at the bottom with the rear skirts than without.
As Pale said, coast down testing is a possibility. You may use the calc on IWillTry.org (see "Measure the drag coefficient of your car") if you want to calc your Cd.
I have also the idea to test the recording of the signal from a gps receiver while doing coast down and measure an average slow down in m/s/s with & without the mod. Currently time is missing not the ideas...
Denis.
Save money & CO2 at home : http://ecorenovator.org/
Created and managed by the creators of http://ecomodder.com/
Earth and health are priceless, so are kilotank and AT-PZEV
Best Mégane tank: 1268.9mi @ 77.847 MPG(US)
2008/06-2011/10 saving:
  • 5725.5 kg CO2 (5342.6+382.9)
  • Diesel / Money: 42.17% = 2446.25€ = 3357.26$
megane : thread - kill switch.
Old 08-28-2009, 06:03 PM   #22 (permalink)
jedi_sol's Avatar
2013 STi *SOLD* - '13 Subaru Impreza WRX STi
Subaru
Sports Cars
Team Turbocharged!
90 day: 26.59 mpg (US)
1996 Geo Metro *RETIRED from Ecomodding* - '96 Geo Metro Base
90 day: 58.68 mpg (US)
Back from the dead! New ideas...
Ok, so project Kammback was killed by the girlfriend
Other ideas that I'm currently planning/working on:
1)Installed alternator disable switch
2)Build custom solar panel and stick it on my trunk (there is turbulence in that area anyways so it shouldn't hurt with aerodynamics. And since project kammback was killed, this is my replacement). In the mail waiting for arrival.
3)Deep cycle battery in the trunk
*Should i use only the deep cycle? or wire it in parallel to the main starting battery?
4)(maybe) Alternator delete
5)Power steering delete
6)Rear wheel skirts
7)Front grille block
8)Underbelly Tray
9)skinnier LRR tires
See the rest of the Sti project log:
http://ecomodder.com/forum/showthrea...log-26612.html
Old 08-28-2009, 07:49 PM   #23 (permalink)
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 39.03 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Another Del Sol on here cool!!! I love the paint/pic of the Kamm back you posted. I'm going to do one for sure I just need to finish the final tuning on the engine.
The attachment for the Kamm back is the hardest part for me. Still haven't' came up with a good idea?
Pressure Gradient Force
The Positive Side of the Number Line
Old 08-28-2009, 08:42 PM   #24 (permalink)
jedi_sol's Avatar
Subaru
Sports Cars
Team Turbocharged!
My kammback idea is dead, it did not pass the girlfriend approval test.
The only idea i had to attach the kamm was to drill or double stick tape a low profile hinge on the roof, to allow the kamm to swing up and rest on the roof, that way i still have access to the trunk.
Old 08-28-2009, 09:21 PM   #25 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Depends on whether your deep cycle alone, or deep cycle + starting battery will get you where you're going (range).
One advantage of being able to switch between two batteries is this:
A) you drive with the alternator OFF on one of the two batteries
B) let's say you're not going to make it to your destination, so
C) you switch over to the "reserve" (fully charged) battery, and switch the alternator back on
D) then you recharge the deep cycle battery from the grid when you get to your destination
That scenario avoids switching the alternator back on part way through a drive, and taking the massive MPG hit of both running the vehicle plus recharging the batteries at the same time.
I like the idea of the solar cells on your rear deck. You're right - no aero harm in placing them there.
Old 08-29-2009, 12:20 AM   #26 (permalink)
jedi_sol's Avatar
Subaru
Sports Cars
Team Turbocharged!
This is what I was thinking.
Assuming I am using 2 deep cycle batteries, are you talking about an ACTUAL switch I would need to wire up? Or would one drain all its power, then the other one takes over?
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 158 01-12-2013 11:59 AM
EG seat swap Del Sol n2 EG Civic Nden DIY / How-to 6 04-02-2010 02:30 AM
fs: san diego honda del sol d15z1 VX Civic 50+mpg CALIFORNIA BAR Certified conversion fistopher For Sale 26 08-01-2008 07:43 PM
aeromodding del sol track car MazdaMatt EcoModding Central 8 07-23-2008 05:51 PM
CL: Mechanic's Special 95 Honda Del Sol Red For Sale 0 04-16-2008 02:38 AM
