Old 01-20-2010, 10:26 AM   #11 (permalink)
Black Beauty - '09 Honda Accord EX-L
90 day: 27.44 mpg (US)
Originally Posted by Clev View Post
Back in the mid-90's, Car and Driver claimed an average 26 mpg while driving 100 mph across Montana in a Z-28.
Those engines had high amounts of low-end torque and a good tranny gear ratios. Just shift gears and never hit the gas pedal!
Old 01-20-2010, 10:40 AM   #12 (permalink)
Hypermiling rookie
Laurentiu's Avatar
Opel Corsa B - '96 Opel Corsa 1.2 8V
90 day: 47.27 mpg (US)
VW Bora 1.6 16V - '02 Volkswagen Bora/Jetta
90 day: 35.84 mpg (US)
The higher the torque the higher the speeds at which you can "cruise" for FE...Diesel's rule in that
"It has been my observation that most people get ahead during the time that others waste" Henry Ford
Old 01-20-2010, 11:57 AM   #13 (permalink)
The Geo - '93 Geo Metro
90 day: 45.16 mpg (US)
No one hates V8 here, we hate people who drive inefficiently.
Old 01-20-2010, 04:18 PM   #14 (permalink)
oldscoob - '87 subaru wagon gl/dr
90 day: 47.06 mpg (US)
301 pontiac. I ran one in a delta 88. Very reliable, EGR was a monster, engine needed very deep cleaning, and even removed nuclear debris (Quite a phenomona if to live through it) EGR has been a perfect omen...even in a little subaru...
when back to as normal as I could get it (I was 16 back then)
new lines, etc, 15mpg was good.
the highway had an unusal realm..does your transmission indicator have an "S" somewhere inbetween D and 2 and 1?
that was amazing, kinda like an older powerglide(?) 2 speed with a looooong drawn out gear.
treat it like the gearing of a diesel, big tread etc (I don't mean donk)
I wondered what staying in the rochester little two barrel side of things correctly would have done for my own 301. good luck...
a 600 holley even barreled would be a very very mathed fit.
Old 01-27-2010, 01:51 PM   #15 (permalink)
The Beast - '79 Buick LeSabre
I managed to find out that I have 2.29 gears in the back, so that puts me at around 1600 rpm at 60 mph. Not bad at all. I'm almost positive I've got a TH200 3 speed on it, and I'll check the oil pan for confirmation next time I drive it.
I've also ran several different dyno's and simulations on it, and I found that a mild cam with a little bit of overlap would increase my highway mpg by 2-5. While you can't exactly trust the numbers 100%, it does tie in with logic. The stock cam has almost no overlap, if I remember correctly. So some overlap will do her good in all realms of efficiency. Not to mention that I very rarely run at WOT, so my EGR might as well not exist.
Oh and I'm also going to lean up the mixture a little bit. Smells a little too rich right now.
And a tranny swap is almost 100% out of the question right now. I don't even come close to having the money right now. One day I'll throw in a 4 speed though
Old 02-06-2010, 01:48 PM   #16 (permalink)
Tank - '76 Chevy El Camino Classic
90 day: 25.89 mpg (US)
Sabrina - '91 Mercedes Benz 190 E
90 day: 37.07 mpg (US)
Angel - '88 Mercedes-Benz 420SEL
Last 3: 23.01 mpg (US)
Quicksilver - '04 Mercedes-Benz CLK55 AMG Cabrio
Haha i understand where you're coming from I've got a camino with a 5.0 V8 and that gets pretty good mileage too These old V8's are actually pretty efficient if you drive em right
Tank:
(No actual EPA numbers for car just used F/E numbers when i first got it)
Old 02-06-2010, 04:38 PM   #17 (permalink)
No, they aren't.
In this day we should not be satisfied with anything less than 30 mpg.
Old 02-06-2010, 05:04 PM   #18 (permalink)
Wannabe greenie
The Clunker (retired) - '90 Honda Accord EX sedan
90 day: 29.49 mpg (US)
Mountain Goat - '96 Ford Ranger XLT 4x4 SuperCab
90 day: 18 mpg (US)
Zippy - '10 Kymco Agility 125
90 day: 65.03 mpg (US)
No, they aren't.
From any vehicle. There are six 2010 SUVs rated 30+ mpg, and there's no reason why all current passenger vehicles can't hit that.
Old 02-06-2010, 05:11 PM   #19 (permalink)
Wannabe greenie
90 day: 18 mpg (US)
Let me clarify. That's just large SUV's. There are obviously many smaller utes and crossovers that qualify as well.
30 MPG SUVs | New SUVs with 30 Miles per Gallon
Old 02-06-2010, 09:27 PM   #20 (permalink)
Get a TH2004R tranny, w/ the BOP pattern. TH700r4 is either SBC or 2.8L patterns. Dump the 301, if you ever take the intake off you'll know why. This is a castration of the pontiac V-8s. Short stroke, no compression ratio worth mentioning, & siamised ports in the heads, if ever GM made a boat anchor this is it. Get a real pont 350, all accessories should swap over, the longer stroke makes much more torque to handle taller gearing. Anotherthing to watch out for on any pont. v8 is very weak timing chain & gears.
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 69 12-27-2014 01:17 PM
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1041 07-28-2014 09:19 AM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 55 08-20-2012 11:34 PM
Alt Car Expo Los Angeles 2008 cfg83 Events & Meet-ups 2 10-14-2008 06:21 PM
