Old 07-31-2008, 01:39 PM   #11 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
Johnny M -
Originally Posted by Johnny Mullet View Post
I do oil changes daily at my shop. I always put what the car manufacturer recommends which is noted on the door sticker. I always thought that I could help people save fuel by pumping them up to max, but it is my duty to make sure I performed my job correctly. Most of the oil changes that are not regulars have under-inflated tires 99% of the time anyway.
In your position I would do the same, unless requested by the customer, and I wouldn't go beyond the max PSI rating on the tire.
CarloSW2
American Solar Energy Society
Old 07-31-2008, 01:52 PM   #12 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
DoctorP82 -
Originally Posted by DoctorP82 View Post
I had my tires inflated about 40-41 until a recent oil change, and looking at the receipt noticed my tires were deflated to 30 psi. There was a noticeable difference in the driving by means of surface drag I could pick up on (eg - rapid decelerating when doing pulse and glide).
Curious question though, what is max inflation tire rating many of you have on your tires? For me it is 44 psi max, and I try to stay around 41.
I did a Cheesy-Lube a while back. It said 32 PSI on the receipt, but when I checked, they had left it at my original PSI.
I specifically picked my tires for their high 51 PSI rating, and that's what I keep 'em at :
http://ecomodder.com/forum/showthrea...ires-2642.html
CarloSW2
Old 07-31-2008, 04:27 PM   #13 (permalink)
Renaissance Man
Formula413's Avatar
Aegean C - '17 Honda Civic LX
90 day: 38.06 mpg (US)
Originally Posted by MazdaMatt View Post
Often they just hammer on them for a while with the impact gun. "That'll hold em on there good"... yeah, and strip my studs, too.
And warp your brake rotors...
+1 on hating having to hand over the keys.
Old 04-27-2010, 02:58 PM   #14 (permalink)
klr 650 - '08 kawasaki klr 650
The van - '15 Dodge Grand caravan Avp
whats the max you can inflate most tires and whats safe
Old 04-27-2010, 03:03 PM   #15 (permalink)
...beats walking...
...never exceed the MAXIMUM pressure value printed on the sidewall of the tire.
Old 04-27-2010, 04:30 PM   #16 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
Unless you're feeling adventurous, like some of us here.
Old 04-27-2010, 04:53 PM   #17 (permalink)
Renaissance Man
Formula413's Avatar
As stated above, the maximum pressure is listed on the sidewall. What's safe? I'm not going to open that can of worms. Do some searching.
Old 04-27-2010, 05:06 PM   #18 (permalink)
Basjoos Wannabe
ShadeTreeMech's Avatar
The Van - '97 Mercury Villager gs
90 day: 19.8 mpg (US)
Lyle the Kindly Viking - '99 Volvo V70
90 day: 25.82 mpg (US)
I read an article once that went very much in depth on how high you can inflate a modern tire. the burst pressure is like 2-3 times the maximum sidewall, so keeping it at sidewall pressure is likely the best bet.
RIP Maxima 1997-2012
Originally Posted by jamesqf View Post
I think you missed the point I was trying to make, which is that it's not rational to do either speed or fuel economy mods for economic reasons. You do it as a form of recreation, for the fun and for the challenge.
Old 06-18-2010, 09:52 AM   #19 (permalink)
I was getting a key made one time and the mechanic came out to let a waiting customer know that he broke off the pressure sensor inside of one of his tires. Stated that the part would be $85 + labor and he was not allowed to take the car somewhere else for the repair, because the law stated that the tire could not be remounted without the sensor.
He brought it in to have the a slow tire leaked fixed and it ended up costing him @ $150.00
Old 06-18-2010, 01:29 PM   #20 (permalink)
Camry MPG Modder
Camry CE - '00 Toyota Camry CE
90 day: 36.18 mpg (US)
Ditto...
My 1st Camry, ever single wheel stud snapped over a period of 2-3 months
as all of them had been air gunned to hell by dealer who swapped on "inspectable" junk rubber before I got the car.
Another great one was the Ford Dealer who over filled my Mazda3, 6qts in a 2 liter?
OR the Jiffy Lube Pro who filled my car with 5/30w even after I paid the extra $10 for semi-sythetic 5/20w that was spec for the Mazda.
When I noticed them doing that I gently reminded them and they drained it an d fixed it. 500 miles later my oil filter feel off and Mazda towed my car in (free roadside assistance) and checked my engine, said looks like you got lucky BUT your warranty is null and void.
They let some air out of my wifes monster Michelins on her Pilot last oil change at a Valvoline EVEN after I asked them politley not to.
We signed her car up for the Valvoline Oil motor warranty. As long as we use the semi-synthetic they warranty the motor until 125K, its at 65K now.
My Camry oil filter sits at a 45 degree upright position right over cross member. Messy change unless I do the drain all oil, put oil plug back on, start car, shut off after 5 seconds, drain rest of oil. That seems to get the cup or so oil out of the oil filter. Spin it off quick and turn it upside down and no mess.
Pete
2000 Camry CE 5 speed 128+K. Best 37.0, Goal is to break thru 36 consistently(Attained). New Goal 38.
ScanGauge II, Unibrow(1 wiper) Air Intake, Mud flap delete, 3.5+" Front Spoiler, Full Moon Hubcaps(Lost). Upper Grille block. (New and improved Fall edition)
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 144 01-25-2016 11:39 PM
Effect of gear oil viscosity on transmission efficiency (Metro owners take note) MetroMPG EcoModding Central 44 12-08-2014 11:22 PM
Oil change recommendations? rjacob EcoModding Central 48 08-02-2010 05:04 PM
Larger oil filter for better FE? Gregte DIY / How-to 44 05-22-2010 11:12 PM
3000 mile oil change is a myth! SVOboy Off-Topic Tech 15 02-14-2008 03:43 AM
