Old 07-02-2013, 09:39 AM   #141 (permalink)
sizematters - '08 smart 4-2 passion cabrio
90 day: 51.99 mpg (US)
escape - '06 Ford Escape xlt
90 day: 26.78 mpg (US)
Buick - '04 Buick Park Avenue Ultra
Team Turbocharged!
90 day: 27.26 mpg (US)
Originally Posted by WD40 View Post
I have used a special mix that consists of the following for the last 2 years:
2 ounces to 10 gallons two stroke oil TC W3
1 ounce to 10 gallons diesel fuel
2.5 ounces to 10 gallons lucas injector cleaner
I just changed the plugs and wires .. plugs had over 50k on them and they looked perfect, my car also passes air care without any issues.
The engine is noticeably quieter and I can definitely notice the mpg loss if I forget to add the mix.
Do you have any numbers to quantify how much loss? Chumly
Old 07-02-2013, 09:46 AM   #142 (permalink)
EcoMod Proof of Concept
WD40's Avatar
WD-40's Insight - '00 Honda Insight
Gen-1 Insights
90 day: 56.04 mpg (US)
WD-40's Mirage - '15 Mitsubushi Mirage ES
90 day: 46.05 mpg (US)
WD-40's Sonata Hybrid - '17 Hyundai Sonata Hybrid Limited
nope .. just the instant read on my MPGUINO and the butt-o-meter .. good enough for me.
2000 Insight MT 106K Citrus A/C
Old 07-05-2013, 12:39 AM   #143 (permalink)
Exceptional Member
YukonCornelius's Avatar
Crapolier - '98 Chevrolet Cavalier base
90 day: 34.81 mpg (US)
05 CTS-V - '05 cadillac cts-v
90 day: 33.01 mpg (US)
95 Accord - '95 Honda Accord
90 day: 38.06 mpg (US)
11 CTS-V - '11 Cadillac CTS-V
I notice improved idle in my 95 accord. Nothing with my CTS-V but with the cam smooth would be tough to judge. my travels are not consistent enough for mpg comparisons. I have no problem adding some lubrication to my fuel.
Old 07-05-2013, 01:57 AM   #144 (permalink)
FYI:
1oz : 4 gallons = 1:512 ratio = .195%
1oz : 5 gallons = 1:640 ratio = .156%
1oz : 10 gallons = 1:1280 ratio = .0781%
You realize this is a concentration of between 7/100ths and 2/10ths of one percent.
Sorry, I tried to make a nice pie chart to help illustrate the additive:gas ratio, but the pie chart generators either wouldn't do it because the additive value was too small, or it gave me a circle with a "radius" line in it. :/
Somebody find me an example of anything fuel and oil related that is effective at that concentration.
Old 07-05-2013, 09:31 AM   #145 (permalink)
RobertISaar's Avatar
MC SBX - '95 Chevrolet Monte Carlo LS
Last 3: 29.75 mpg (US)
https://en.wikipedia.org/wiki/Tetraethyllead
Typical formulations called for 1 part of prepared TEL to 1260 parts untreated gasoline.
1/1260 = .079% if i'm doing my math right.
The Following 2 Users Say Thank You to RobertISaar For This Useful Post:
Frank Lee (07-05-2013), radioranger (07-05-2013)
Old 07-05-2013, 09:46 AM   #146 (permalink)
Ha! Bob did it!
Duuuuurrrr... still doubt this stuff is doing anything.
Old 07-05-2013, 10:22 AM   #147 (permalink)
ehh, in the ranger, if it doesn't get a dose of oil in the tank, within about 3 gallons used, gets a nasty misfire/dropped cylinder at cold startup. possibly an injector issue. but if i throw in oil at a rate of 1 oz/5 gallon, it goes away after a few gallons are used.
not that using oil in fuel is really a permanant fix to a mechanical issue, but it helps that at the very least. now, if at some point it "fixed" the injector to where i wouldn't need to keep dosing the fuel with oil, i wouldn't complain at all, but i'm not expecting it.
i will say that i've gotten a record tank with it now though, a whopping 27.8MPG... which beat my previous best tracked tank by nearly 2MPG. more than just the oil contributed to that though, so i can't really quantify it as being from oil alone.
Old 07-10-2013, 01:46 PM   #148 (permalink)
Tacoma - '12 Toyota Tacoma base
90 day: 30.48 mpg (US)
Escort - '99 Ford Escort wagon SE
90 day: 32.77 mpg (US)
Originally Posted by wungun View Post
I love it when people get all horny about magic additives that promise the world...
2 stroke oil? Really?
Must work wonders for cat clogging, sparkplug fouling and generally polluting the air...
Oh, and denting your wallet!
Actually fuel with tcw3 burns cleaner. In fact it lubricates and cleans.
Most any ICE benefits from top end lube esp. when using ethanol which should never be in your fuel.
Adding the tcw3 will have little effect on +EF if your plugs, valves and rings are new and clean but it will maintain their pristine condition.
Folks with dirty top ends could notice a nice +EF as the internals are cleaned.
It is funny that some people that have no problem using Techron (which is fantastic stuff) MMO, Lucas etc. don't seem to grasp the concept of TCw3 clean burning oil.
The Following User Says Thank You to esnap For This Useful Post:
jimsiggy (03-01-2015)
Old 07-10-2013, 02:22 PM   #149 (permalink)
Lubricates what?
Old 07-14-2013, 03:07 PM   #150 (permalink)
Lubricates what?
Your cylinder walls, rings, intake valve stems and fuel pump.
