Old 01-12-2013, 11:27 PM   #81 (permalink)
This whole thread belongs in the unicorn section.
Old 01-13-2013, 05:47 PM   #82 (permalink)
radioranger
My conclusion is the oil does help and hurt at the same time, it probably helps with the start up wear and tear, valve guides, rings etc, and hurts a bit with the higher temps or tendency to ping on hills, so i guess if your not going under heavy loads it's a good thing, as far as FE seemed to help then just stayed the same, not enough testing yet, trucks running great now though, may try super synthetic oil next since i use it in the old outboard exclusively now, . My old street bike a Suzuki 380 two stroke ran a good ten mph more top end and sometimes was so smooth you couldnt feel it run, pretty impressive. In general I think anybody running a carbureted motor should definitely add the tcw 2 or better,
Old 01-15-2013, 08:45 AM   #83 (permalink)
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
Yeah! We should contact a Mod to shut this down!
Happy EcoDriving...
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
Old 01-15-2013, 09:15 AM   #84 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
as opposed to only half of it.......or a quarter of it......or just post #81& #86.............
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 01-15-2013, 10:24 AM   #85 (permalink)
Prophecy99's Avatar
Maxima - '02 Nissan Maxima GLE
haters gonna hate
Old 01-15-2013, 11:56 AM   #86 (permalink)
9 pages in and so far nobody has been able to provide evidence that it is in any way beneficial to add 2 stroke oil to gasoline. Nothing. I understand the logic (even though I don't agree with it) about adding TCW3 to diesel engines with mechanical injection pump but a 4 stroke gasoline engine... seriously?
This is pure unicorn BS.
Old 01-15-2013, 05:22 PM   #87 (permalink)
UFO
UFO's Avatar
Colorado - '17 Chevrolet Colorado 4x4 LT
90 day: 23.07 mpg (US)
Yes tjts1, no evidence yet. Maybe a little more patience is warranted, but I basically agree, lots of "more torque" and "smoother idling" with no substantiation or data. It's the stuff of placebos.
I'm not coasting, I'm shifting slowly.
Old 01-15-2013, 07:54 PM   #88 (permalink)
Speedy Gonzales - '11 Ford Fiesta SES
I love it when people get all horny about magic additives that promise the world...
2 stroke oil? Really?
Must work wonders for cat clogging, sparkplug fouling and generally polluting the air...
Oh, and denting your wallet!
Old 01-16-2013, 08:27 AM   #89 (permalink)
EcoModding Alien Observer
suspectnumber961's Avatar
highcountryexplorer - '86 Nissan 720 KC 4x4 ST with fiberglass cap
90 day: 21.78 mpg (US)
Elroy - '03 Ford Focus ZX3 w/Zetec DOHC engine
90 day: 32.89 mpg (US)
The great and powerful LaPointe responds.....
"During several periods of my life, I just picked up the phone and ordered drums of any chemical I wanted--totally free. You name it and I have probably tested it. Gasoline for instance contains hundreds of chemicals including about 11% oil. That particular oil is there not to lubricate but to act as a mileage ingredient. Of course the heavy fuel ends or oils do lubricate somewhat but they are also the most difficult components to combust fully. These oils lubricate fuel pumps, pistons, walls, rings, valves and injectors.
But the mileage oil does not have great lube ability because it lacks additives that.exist in ordinary lube oils. Additives do nearly all the work in lubrication. The oil is the carrier. So I add the additive GP-7 to get excellent ring seal and prevent gases and fuel from getting into the crankcase. And to also keep lube oil from entering the chamber where it can cause knocking and smoking.
For 25 years I simply used straight acetone in the gas. Never had a problem but that was before I found the importance of a better ring seal from Bob and Dan Lancaster of Torco fame. By eliminating the wasted fuel from around the rings and pistons with GP-7, we get far better lubrication in the cylinders because crankcase oil is NOT getting contaminated by raw gasoline. Unburned fuel is the greatest source of wear in any piston engine by far. The wear and friction at TDC is 90-percent. Stop that wear any way you can and your engine will last nearly forever. Look at propane engines. They never wear because--there is no gasoline."
So...what does this mean? It means that at the top of the piston where the rings seal the combustion chamber from the rest of the engine...there is a lot of friction and wear. This is due to the nasty products of combustion and to the fact that due to the reciprocal nature of an engine...the pistons spends a good bit of time near the top of it's stroke. Also...most engines are lubed from below...from oil splash off the crank...not from the top.
This results in RING STICTION....an issue that a top lube can help.
If you've ever rebuilt an engine....you will know all about CYLINDER TAPER and the dreaded TOP RIDGE.
Carry on humans...we are extremely proud of you. ..................
Forty-six percent of Americans believe in the creationist view that God created humans in their present form at one time within the last 10,000 years. GALLUP POLL
The Following User Says Thank You to suspectnumber961 For This Useful Post:
Xist (07-15-2015)
Old 01-16-2013, 11:45 AM   #90 (permalink)
UFO
UFO's Avatar
Nothing like a well-polished testimonial to refute the criticism......
BTW, I've rebuilt a few gasser engines that never used additives, never found ridges or measurable cylinder wear. So there, anecdotal evidence is cancelled.
