Old 09-10-2014, 06:27 PM   #1 (permalink)
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
Overheating problem.
I'm going to make a dedicated overheating thread as I need help. I don't know what to do at this point.
Things I have tried:
Coolant flush.
Thermostat replacement.
Block test (came up fine).
I'm out of ideas. The coolant flush made my situation worse. I use to be able to put around town all day with no problems at all, and now just going to my friends house, which I have done a dozen times in the insight, it overheated.
Old 09-10-2014, 07:06 PM   #2 (permalink)
Insight for life's Avatar
05 Prius (wife's) - '05 Toyota Prius package 5
90 day: 44.32 mpg (US)
Citrus - '00 Honda Insight
Gen-1 Insights
90 day: 60.68 mpg (US)
Who did the block test? Sometime they wont show up and then all of the sudden it shows up bad. I had a cobra like that.
Old 09-10-2014, 07:12 PM   #3 (permalink)
Furry Furfag
I did, I did it 3 times to make sure.
Old 09-10-2014, 07:19 PM   #4 (permalink)
Did you bleed the cooling system after the flush-thermostat? I posted in the other thread I thought it was the radiator. A radiator shop can test it for hot spots in the radiator.
regards
mech
Baltothewolf (09-21-2014)
Old 09-10-2014, 07:30 PM   #5 (permalink)
Furry Furfag
regards
mech
I replaced the thermostat at the same time I did the flush. And Yea Ill have to find one out here. It's fine until I have to climb a hill, then it starts to heat up extremely fast.
Old 09-10-2014, 08:13 PM   #6 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
My radiator was full of dirt and road dust, kept overheating on hill climbs. Try getting a car wash spray up close. Oh yeah I had tried everything also... I felt SO stupid!
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 09-10-2014, 08:44 PM   #7 (permalink)
Liberty Lover
j12piprius's Avatar
pris prius - '12 Toyota plug in prius
90 day: 71.09 mpg (US)
new radiator
How old is the radiator? I replaced mine with a larger one one from Ebay a couple of weeks ago. This was easy to do and the change has made a major difference. The 15 year old original had become a thin smashed up shell that wasn't doing anything. Also check the size of your grill blocks, as the venting is especially important when going up hills.
Old 09-10-2014, 08:55 PM   #8 (permalink)
Furry Furfag
I don't have a grill block. Anyway, can you give me a link to the bigger radiator? When I get home I'll burp the system again, and take pics of my radiator so you guys can see what kind of shape it's in.
Old 09-10-2014, 09:02 PM   #9 (permalink)
Not bad for a machine
dirtydave's Avatar
Maechunbu - Retired - '00 Kia Sephia 1.8I4 16VDOHC
Last 3: 45.28 mpg (US)
Slasher - '96 Chevy Corsica 2.2L 3speedauto
Duct Tape Aero Crew
Team Chevy
90 day: 34.76 mpg (US)
Does the heater work? If it doesn't its the water pump. Is the fan coming on? If the top hose from the radiator is hot you can know the thermostat is good.
Old 09-10-2014, 09:05 PM   #10 (permalink)
Liberty Lover
j12piprius's Avatar
This is the one I got, on a bid for 55.99, however you will need a different one for the insight.
I should take a photo of the old one before tossing it in the trash.
