Old 09-10-2014, 09:05 PM   #11 (permalink)
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
Originally Posted by dirtydave View Post
Does the heater work? If it doesn't its the water pump. Is the fan coming on? If the top hose from the radiator is hot you can know the thermostat is good.
Heater works awesome. And Yea the top hose is hot as well as the bottom hose.
Old 09-10-2014, 09:08 PM   #12 (permalink)
herp derp Apprentice
Saturn-sold - '99 saturn sc1
Team Saturn
90 day: 28.28 mpg (US)
Yukon - '03 GMC Yukon Denali
90 day: 13.74 mpg (US)
Originally Posted by Baltothewolf View Post
How close is the condenser to the radiator on the drivers side? Or is it touching / pushed against the radiator? I don't recall what the spec is, but I think if 2 coolers are too close together it kills air flow.
Old 09-10-2014, 09:18 PM   #13 (permalink)
Furry Furfag
I'm eating right now, I'll go look and take a pic when I'm done, 10-15 mins at most.
Old 09-10-2014, 09:28 PM   #14 (permalink)
Furry Furfag
Omg I think that's the problem /facepalm. The previous owner told me that he left it on a hill and forgot to put the e-brake on, the car got away from him and ended up at the bottom of the hill against a telephone pole... Just... Look at the pics below /facedesk 100x.
Old 09-10-2014, 09:40 PM   #15 (permalink)
Team Saturn
What's going on in the second pic? Kinda looks like a damaged induced, lower condenser block situation
Old 09-10-2014, 10:14 PM   #16 (permalink)
Furry Furfag
Like I said, it rolled down a hill into a pole.
Old 09-10-2014, 10:27 PM   #17 (permalink)
Top and bottom hose both hot= radiator not removing enough heat due to restricted cooling passageways in the radiator. The misalignment show in your photo will not cause the overheating your describe.
Also any time you open up the cooling system there is a very specific bleeding procedure.
regards
mech
Baltothewolf (09-21-2014)
Old 09-10-2014, 10:31 PM   #18 (permalink)
Here is a youtube video of the bleeding procedure.
regards
mech
Old 09-10-2014, 10:33 PM   #19 (permalink)
Furry Furfag
regards
mech
Yea I followed that procedure to the T. I just burped the system again and a ton of air bubbles came rushing up the second I turned the car on. I think I'll just replace the radiator to rule that out.
The Following User Says Thank You to Baltothewolf For This Useful Post:
Cobb (09-10-2014)
Old 09-10-2014, 10:41 PM   #20 (permalink)
Don't confuse a proper bleeding procedure with a bad radiator diagnosis. They are not related. You can put a brand new radiator in the car and not bleed it properly and it will still overheat.
Keep opening the bleeder until you get nothing but liquid coolant, That COULD fix the problem. The dealership replaced the water pump bypass hose on my Riviera. It was running hot until I took it back and they bled it until it had no air pocket and it ran cool.
regards
mech
