Old 05-13-2011, 04:37 PM   #4721 (permalink)
moserial
For those who want to view real time data and configure your open source controller using an open source operating system, try moserial. If you are using Fedora or Ubuntu just go the the Add/Remove Software in the System menu and search for moserial, 1 click and it's installed. Set up is easy as it automatically found my serial to usb converter, just had to choose it from the menu. Screen shot should have all the info you need, just remember to set the device to whatever is appropriate for your system. I found that before sending any commands to the controller you need to hit enter first, type command and hit enter again. Font type and size is also configurable, I made it large so I could glance at it easily while driving.
Greg
EDIT: I have added this to the wiki. Also on the bottom right of the screen shot I have found it works better to set the outgoing to <CR end> and not <CR+LF end> as shown.
The Following 3 Users Say Thank You to Greg Fordyce For This Useful Post:
Crossdan (07-09-2012), LouMan (05-13-2011), MPaulHolmes (05-13-2011)
Old 05-13-2011, 08:37 PM   #4722 (permalink)
BadDog98's Avatar
Good Things Come To Those Who Wait!
Old 05-13-2011, 10:29 PM   #4723 (permalink)
PaulH
MPaulHolmes's Avatar
haha no those aren't private. I must have missed that message. Louman, do I have your email address? I'll send you the gerber files.
kits and boards
The Following User Says Thank You to MPaulHolmes For This Useful Post:
LouMan (05-14-2011)
Old 05-14-2011, 05:13 AM   #4724 (permalink)
After days of struggling with the AVR and accidentally locking its programming fuse, I've moved on.
I'm now using Paul's board but with a PIC24FJ. It's much easier to program (I think), cheap, and the development environment is free, like AVR.
Right now I've got the LED, UART, ADC, and PWM working. I just tested it at 24volts with an Etek motor that I have.
IT WORKS! First time I've used the power section.
I'll post my code, and an eagle PCB schematic and board that can plug right into the AVR socket if anyone is interested.
The Following 5 Users Say Thank You to Camaro For This Useful Post:
deodeo (04-20-2012), dneale (06-10-2011), jackbauer (05-15-2011), LouMan (05-14-2011), mpgmike (01-20-2022)
Old 05-14-2011, 11:50 AM   #4725 (permalink)
jackbauer's Avatar
The following takes place between 9am and 4pm. Events occur in (sort of) real time
ID:	8347   Click image for larger version
ID:	8348   Click image for larger version
ID:	8349   Click image for larger version
ID:	8350   Click image for larger version
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
Old 05-14-2011, 04:18 PM   #4726 (permalink)
jackbauer's Avatar
Thanks Lou. I didnt get any board with the dcdc. Its as received.
www.evbmw.com
Old 05-14-2011, 06:10 PM   #4727 (permalink)
PaulH
Fran explained to me today how he does a sort of home made DC-DC. I'm going to build my own version, and then the vla501 or whatever will no longer be necessary. And the AC control board will be dramatically simplified too. The cost is going to be WAY WAY cheaper. I believe less than $10 for the near equivalent of the vla501:
http://search.digikey.com/scripts/Dk...ds=ELF-18D290S
http://search.digikey.com/scripts/Dk...eywords=S555IN
http://www.mouser.com/ProductDetail/...j1V6NjRg%3d%3d
4 of these:
http://www.mouser.com/ProductDetail/...%2fyu57w%3d%3d
15v zener diode to clamp the voltage.
Bulk capacitor to turn the output voltage into DC.
A couple resistors and a couple MLCC capacitors for the 555 timer above.
Basically, you run the 555 timer at around 50 to 100kHz, and that 5v signal goes to the mosfet driver. The mosfet driver makes a square wave on the primary side of the line filter above. The output side then gets a similar square wave. YOu use the zener diode to clamp the output voltage, and the 4 schottkys to rectify it. Bam!
kits and boards
Old 05-14-2011, 06:25 PM   #4728 (permalink)
jackbauer's Avatar
yeh please that would be great!
www.evbmw.com
Old 05-14-2011, 06:26 PM   #4729 (permalink)
Diesel Addict/No Cure
cleanspeed1's Avatar
StolenHoopty - '90 Honda Accord EX
HvyDrnkr - '93 Cadillac Seville
Digi-Key Part Search
IXDF604PI Clare MOSFET & Power Driver ICs
4 of these:
VS-MBR160 Vishay Schottky (Diodes & Rectifiers)
Your genius scares me! I'm just waiting to see how you are going to do next.
Volvo WIA42 VED-12 / 335 hp / 1300 ft/lbs / 9 mpg
Big n' Boxy, Never met a Hill it Didn't Like
Old 05-14-2011, 08:57 PM   #4730 (permalink)
PaulH
Well, I'm an expert at taking someone else's idea, messing it up the first 5 times, and then getting it to work. hahaha.
I just ordered the parts for a prototype of the isolated DC-DC. ya! I'm going to breadboard it this week if I have time. I also ordered some 12w 100 Ohm resistors that I can put in parallel and series so as to test the load on the output up to around 500mA, and see what's what.
kits and boards
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 3431 05-04-2022 06:43 PM
Paul & Sabrina's Cheap EV Conversion MPaulHolmes Fossil Fuel Free 542 11-12-2016 10:09 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 05:10 PM
