Old 04-10-2011, 10:58 AM   #4621 (permalink)
PaulH
MPaulHolmes's Avatar
It makes me so happy when people are able to put a controller together, and everything works like it should. Benny from Denmark make a very nice how to video of the soldering process.
kits and boards
The Following 2 Users Say Thank You to MPaulHolmes For This Useful Post:
mrbigh (04-10-2011), Nevyn (04-12-2011)
Old 04-10-2011, 02:01 PM   #4622 (permalink)
Custom EV Builder...
Originally Posted by harlequin2 View Post
Don't worry about it! The current flows down the busbars at about .4 nanoseconds per metre! And that means there is no measurable difference in which device gets what first. The turn-on and turn off times are orders of magnitude greater and completely swamp any variations in busbar length.
Does current flow effect this at all? Remember my build even heavily derated will do 2000A.
Thanks for all the input guys.
Old 04-12-2011, 08:01 AM   #4623 (permalink)
whew! just read the whole thing! Epic thread. jackbauer & Paul - per our email exchange we are really interested in a 1000+A IGBT-based design. Damien - have you been able to test your liquid-cooled 1000A IGBT monster yet? Also, I'd appreciate the contact info for whoever you worked with in SF to get the cold plate done (I actually live 15 miles from San Francisco so would be cool to meet with the guy).
Valery.
Old 04-12-2011, 03:41 PM   #4624 (permalink)
jackbauer's Avatar
It just so happens the heatsink turned up today. I quickly fitted the transistors and dummy located the bars and caps. As can be seen from the photos it looks good so far. I will be using the rev2c control board and the vla drivers. I decided to stick with the the 2c as its a proven design with proven software. I will be limited to a mere 900amps with this setup but i'll just have to make do
It will be tested on my test bench which is still a work in progress. Based on the evtv design but with a dc injection braked 11kw 3 phase motor as the load.
I will email the guy who designed the heatsink and , with his permission , send on the contact details or make them available on the forum. It's his call and i don't want to post anything yet without permission. He's a great guy so i'm sure it won't be an issue.
ID:	8157   Click image for larger version
ID:	8158   Click image for larger version
ID:	8159   Click image for larger version
ID:	8160   Click image for larger version
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
The Following User Says Thank You to jackbauer For This Useful Post:
mrbigh (04-12-2011)
Old 04-12-2011, 03:48 PM   #4625 (permalink)
Man...Those are some big capacitors!!
Old 04-12-2011, 03:50 PM   #4626 (permalink)
jackbauer's Avatar
Capacitance. Good.
Inductance. Bad.
They are epcos 400v 105c 4700uf low esr.
www.evbmw.com
Old 04-13-2011, 10:55 AM   #4627 (permalink)
PaulH
I tested the first of the 1000amp controllers on the electric bike yesterday. The precharge/contactor control is working properly, and the wheel spun just like it was supposed to. All the code changes seem to be working as they should. I've learned to be really careful when I have to go into linux every time I want to make a software change, send the hex file to my email, and then download it on the laptop before I can transfer the code to the microcontroller. I'll get pictures later after school.
kits and boards
Old 04-13-2011, 10:58 AM   #4628 (permalink)
EV Connoisseur
Cool.. does that mean they have a case now? Or did you test it without?
Old 04-13-2011, 12:40 PM   #4629 (permalink)
PaulH
I tested it without the case. Ziegler's Welding is taking FOREVER!!!!!!!!!!!!!!!!!!!!!! Maybe they are just busy right now, but it's making me look really bad to a couple people that ordered a kit too that are over a week past due when I was supposed to ship them. Usually they are really fast.
kits and boards
Old 04-13-2011, 12:47 PM   #4630 (permalink)
AC-DC enthusiast
mrbigh's Avatar
Dual-PWR PHEV - '04 Toyota Prius
Kopper - '79 Bradley Bradley GT-II
Parts replacem3nt
Paul
Is it there a suitable replacement we can use instead aTLP222GF optocoupler?
Mouser and Digikey are soldout
Thanks
Prius Absolutum Dominium . ..........KOPPER
PHEV conversion since Dec 2006.. . .... .Future EV
. . . . . . . .CALCars # 27. . . . . . . . . . ..on the works now !!
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 3431 05-04-2022 06:43 PM
Paul & Sabrina's Cheap EV Conversion MPaulHolmes Fossil Fuel Free 542 11-12-2016 10:09 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 05:10 PM
