Old 05-14-2011, 08:19 PM   #4731 (permalink)
Diesel Addict/No Cure
cleanspeed1's Avatar
StolenHoopty - '90 Honda Accord EX
HvyDrnkr - '93 Cadillac Seville
Originally Posted by MPaulHolmes View Post
Well, I'm an expert at taking someone else's idea, messing it up the first 5 times, and then getting it to work. hahaha.
I just ordered the parts for a prototype of the isolated DC-DC. ya! I'm going to breadboard it this week if I have time. I also ordered some 12w 100 Ohm resistors that I can put in parallel and series so as to test the load on the output up to around 500mA, and see what's what.
Look dude, I never thought about doing an electric vehicle seriously until now, just because for too long I thought it was too expensive. Between you and the other members here that have done budget electrics that work well, it's obviously possible.
Volvo WIA42 VED-12 / 335 hp / 1300 ft/lbs / 9 mpg
Big n' Boxy, Never met a Hill it Didn't Like
The Following User Says Thank You to cleanspeed1 For This Useful Post:
MPaulHolmes (05-14-2011)
Old 05-15-2011, 09:20 AM   #4732 (permalink)
jackbauer's Avatar
Built and fitted the little igbt interface board today. Comprised of 8 resistors. Four off 3R3 2W for the gates and four off 0R33 2W for the emitters.
ID:	8361   Click image for larger version
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
Old 05-15-2011, 10:10 AM   #4733 (permalink)
Basically, you run the 555 timer at around 50 to 100kHz, and that 5v signal goes to the mosfet driver. The mosfet driver makes a square wave on the primary side of the line filter above. The output side then gets a similar square wave. YOu use the zener diode to clamp the output voltage, and the 4 schottkys to rectify it. Bam!
The URL for those parts didn't work. But I'm guessing that it's a capacitive line filter, not a transformer. If so, you are implementing a capacitor level shifter.
That's good for a local isolated supply. But it has high capacitive coupling between the house/accessory supply and the traction supply. Which is bad for safety, has essentially no common-mode noise immunity, and won't work just when you need it the most.
The DC-DC converter is an expensive part of the system, but it's pretty hard to substitute something less expensive and get the same level of protection and performance.
You can save some money by getting a semi-regulated module. And after all, a gate driver doesn't really need 12.00V. These modules have a narrower input voltage range, typically +-10% (e.g. 10.8-13.2V) to meet spec, and non-guaranteed +-20% to work (often 9V-15V). If input voltage is a concern you can waste a little power by getting a 5V to 12V module and putting it behind a regulator. Or a 5V to 15V converter, and putting a regulator on both sides.
An alternate approach is using traction voltage to create the gate driver supply. Read the datasheet for the LNK306 switching converter to see how to do this with just a few components. But it does give up one of the features of the Cougar -- the ability to work with any traction voltage. If you want to operate at 12V (which is useful for testing), you need to build a buck-boost design, and that involves more components.
For our controller we put all of the isolation on the gate driver board, with overlapping footprints for two types of DC-DC converters. That allows us to use $5 modules (only 1W output and 1KV isolation) for most testing, or use better modules (2W, wide input voltage range, 5KV isolation) if needed.
Our gate driver board is using a Si8233 chip, which provides isolation and dual gate drivers in one package. It does an awesome job. You don't have to deal with all of the optoisolator hassle -- drive current, production variations, dimming with age and temperature.
The Following User Says Thank You to DJBecker For This Useful Post:
sawickm (05-15-2011)
Old 05-15-2011, 10:44 AM   #4734 (permalink)
PaulH
MPaulHolmes's Avatar
I think I fixed the links. I think what happened was, I was logged in on Mouser and Digikey, and then started doing specific searches relative to my account. I tried doing just a generic part look up and copied the link so it should work this time.
Those line filters have a tiny capacitance. They have been used very successfully for years by Fran with various 3 phase inverters, all the way up to his current 400amp per phase inverter that they will be testing this Wednesday. All of them have a nominal voltage in the 300-320v range. It's used deep down in Platinum mines in South Africa inside of these tank-like things, and a bunch of other applications too, like mine destroying big tank things that spin giant metal chains that bash the ground and detonate mines. Almost like roto-tilling the whole countryside.
kits and boards
Old 05-15-2011, 12:46 PM   #4735 (permalink)
jackbauer's Avatar
Camaro , i'd be very interested in the pic system.
www.evbmw.com
Old 05-15-2011, 06:56 PM   #4736 (permalink)
I'll post my code in the next few days, and I'm designing a PCB in Eagle for a small plug in board. I've never been a fan of AVR's. They're just more of a pain to program, but I understand why Paul choose it.
Old 05-15-2011, 07:45 PM   #4737 (permalink)
No, its inductive ie two coils on a bobbin with a bit of ferrite. Normally one coil goes in each ac leg. It is actually a transformer with a 1:1 turns ratio with a very high voltage isolation capability.
Sometimes I sits and thinks and sometimes I just sits.
Old 05-15-2011, 09:48 PM   #4738 (permalink)
Finally got the car together enough for an initial road test at 24 volts. Darn fuel clip was dragging making a noise that caused concern for my wife (Wont need that any more, The fuel clip, not my wife.)
Will it make it out of the garage?
Will we get to their house?
Old 05-15-2011, 10:00 PM   #4739 (permalink)
PaulH
Best Videos Ever!!!! Your son is so adorable! And it sounds like your wife was a tiny bit surprised that it worked. haha.
kits and boards
The Following User Says Thank You to MPaulHolmes For This Useful Post:
pnikolaj (05-17-2011)
Old 05-15-2011, 10:06 PM   #4740 (permalink)
AC-DC enthusiast
mrbigh's Avatar
Dual-PWR PHEV - '04 Toyota Prius
Kopper - '79 Bradley Bradley GT-II
YouTube - 2001 Focus BEV First Time Out of the Garage
YouTube - 2001 Focus BEV First Road Test
CONGRATULLATIONS!!
It's moving by it's own power
Prius Absolutum Dominium . ..........KOPPER
PHEV conversion since Dec 2006.. . .... .Future EV
. . . . . . . .CALCars # 27. . . . . . . . . . ..on the works now !!
The Following User Says Thank You to mrbigh For This Useful Post:
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 3480 05-04-2022 05:43 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 04:10 PM
