Old 10-04-2011, 02:34 AM   #5111 (permalink)
To Jackbauer,
nice work there and explanation,still assimilating your input.Impressive.Cannot afford all the r&d but I am sure and rely on the fantastic work done here on this forum.You guys sure know a lot.Once again Thanks.
Old 10-04-2011, 04:24 AM   #5112 (permalink)
Originally Posted by sawickm View Post
Hi Paul,
I put together an assembly drawing of what you posted.
I added the sensor assembly drawing into the revolt wiki: Open ReVolt/PCB Schematics - EcoModder
- Mark
Figured out this is the current sensor board i have, but i need to get the caps and the actual IC for it. i looked on mouser and digikey, and did a google search for it, but i can't seem to find the little tiny chip. any ideas?
thanks!
Old 10-04-2011, 12:14 PM   #5113 (permalink)
EV Builder
Freyguy's Avatar
isaac_alaska,
The actual part number should be MLX91205KDC-HB.
Both Digi-key and Future Electronics show stock.
Digi-Key - MLX91205KDC-HB-ND (Manufacturer - MLX91205KDC-HB)
MELEXIS | MLX91205KDC-HB-TU | MLX91205 Series 4.5 to 5.5 V Surface Mount IMC Current Sensor - SOIC-8 - Future Electronics
Qty 1 price from Future is only $4.85 compared to $10.13 from Digi-Key
The Following User Says Thank You to Freyguy For This Useful Post:
isaac_alaska (10-04-2011)
Old 10-04-2011, 07:44 PM   #5114 (permalink)
Originally Posted by Freyguy View Post
isaac_alaska,
THANKS! i would have had a super hard time finding that myself. i think now the only thing i have left to do is figure out how to program the rest of the board. can the 1ka cougar board be programmed with just the serial link? or does the microcontroller have to be programmed off the board first?
Old 10-05-2011, 03:24 PM   #5115 (permalink)
The Crimson Crawler - '04 Hyundai Elantra GLS
90 day: 36.71 mpg (US)
Sorry I've been missing for so long! With the SBE ring cap - You only need ONE to do the whole shebang??
Old 10-05-2011, 03:52 PM   #5116 (permalink)
according to the data sheet, it looks like each one is good for 500 amps rms. 1000uF is more than enough capacitance to supply the current needed during the conduction phase of the power stage. if i remmeber correctly, according to my calculations, at 50% PWM duty and 1000 amps and 170 volts, the capacitor must supply about 5.5 watt seconds of energy. at 100% PWM duty, it doubles to about 11 watt seconds. 1000uF at 170 volts is good for about 35 watt seconds. so even at MAXIMUM power draw, the capacitor never dips below 1/3 depleted. the data sheet also says it can handle 10,000 amps fault current.
However, it lists 500 amps RMS at 20 khz as the maximum. So i think for most applications, you would only need one, but if you're pulling the full 1000 amps for an extended period of time, you need two of them.
can someone else confirm this?
Old 10-05-2011, 10:07 PM   #5117 (permalink)
EVVette - '71 Chevy Corvette Coupe
The Soliton 1 controller uses only 1 of these caps and its rated at 1000A Continuous.
Also, you will very rarely pull even close to 1000A at 100% duty cycle. The morot would have to be stalled or close to it when the throttle is stomped.
-Adam
www.EVVette.com - 1971 Corvette Coupe Conversion to all Electric!
www.AdamBrunette.com - Machining, CNC, Robotics and Electronics.
You can download RTD Explorer for the Cougar controllers at www.EVVette.com
Old 10-05-2011, 10:47 PM   #5118 (permalink)
Adam, are these the 600v 1000uF caps? That's the only ones I was able to find a data sheet for.
*edit*
i found a bunch of other data sheets on SBE's website, but i don't see any that say they are rated for for over 500A RMS. it's very possible they aren't advertising this one though, or the soliton controller is just using them above their rms rating. (which it appears would still be really safe; several of their caps can handle a 100,000 amp spike)
Old 10-06-2011, 12:52 AM   #5119 (permalink)
Open Revolt motor controller
this is one long thread. 519pages. Couldn't read all of them. Mindboggling. I'm still trying to figure out what all those parts do. I definitely need the controller and for sure help to put it together. Gotta save a bit more money still.
c ya all later.
Old 10-06-2011, 02:39 AM   #5120 (permalink)
PaulH
MPaulHolmes's Avatar
hahaha. ya it's long. Isaac, I can confirm that you can't just program the micro through the serial port until the initial programming has happened. I use a programmer from digikey that was $35 I think.
Digi-Key - ATAVRISP2-ND (Manufacturer - ATAVRISP2)
kits and boards
The Following User Says Thank You to MPaulHolmes For This Useful Post:
isaac_alaska (10-06-2011)
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 3480 05-04-2022 05:43 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 04:10 PM
