Old 10-15-2016, 06:40 AM   #7141 (permalink)
Golfwagen - '89 Volkswagen Golf mk2
90 day: 107.14 mpg (US)
See this: https://drive.google.com/folderview?...UU&usp=sharing
I've tried to gather everything needed for basic 2C mosfet version build there. I'd like to do the same for IGBT build and 3-phase controller.
The Following 2 Users Say Thank You to mora For This Useful Post:
jedsmd (10-29-2016)
Old 11-10-2016, 05:46 AM   #7142 (permalink)
Has the AC motor controller been released because I need this too.
Old 11-10-2016, 02:56 PM   #7143 (permalink)
PaulH
MPaulHolmes's Avatar
I have control/driver boards that I can solder and test, and then you would just have to plug it into 3 IGBTs and attach a bus capacitor.
kits and boards
Old 11-10-2016, 03:01 PM   #7144 (permalink)
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
I'm not sure what 'released' means, but I have a Beta AC controller, and it has been tested and works.
Paul is selling the control board for the AC Controller, assembled and tested, on hist web site. I have ordered 2 of them, my wife will be bringing them back home near the end of November.
I have not seen the IGBTs and the water-cooled heat sink kitted yet on Paul's web site.
Old 01-05-2017, 12:44 PM   #7145 (permalink)
Hall Effect Throttle on DC Controller
Hey Paul,
I was looking at replacing the throttle on my Mazda to interface to the IGBT-based DC controller.
BUT .. it would be a lot easier for me if I could just use the hall effect throttle that I have installed and plug it into the DC controller. There are only 2 wires going into the controller throttle, and I don't see any unpopulated holes on the silk screen like 'Hall Effect Throttle'
So would it be a relatively easy fix, or should I buy a pot-box?
The Following User Says Thank You to thingstodo For This Useful Post:
MPaulHolmes (01-05-2017)
Old 01-05-2017, 12:46 PM   #7146 (permalink)
PaulH
It would be pretty easy to convert to hall effect. Cut out a resistor, add a jumper, change a pull down resistor value. badabing badaboom, done!
kits and boards
Old 01-05-2017, 02:23 PM   #7147 (permalink)
And change firmware too.
This is found from JackBauer's instruction:
remove R10 and replace R8 and D1 with wire links. Pin 5 now outputs a +5v supply for the pedal and pin 4 is now the input from the pedal. Ground can be connected to pin 2. Just a case of disconnecting the traction supply and using RTD to setup the range.
Old 01-05-2017, 03:44 PM   #7148 (permalink)
Is that from the IGBT version of the DC controller or the MOSFET version?
If there are already instructions ... and I just need to follow them ... can you post a link? Or is this in the WIKI?
EDIT: I ask since RTD Explorer does not exactly work with the IGBT version as yet.
Last edited by thingstodo; 01-05-2017 at 03:45 PM.. Reason: Make it easier to read
Old 01-05-2017, 03:49 PM   #7149 (permalink)
PaulH
Jack had the 500amp board. Let me see if I can get very specific directions. Must go find that board on the computer!
kits and boards
Old 01-05-2017, 04:14 PM   #7150 (permalink)
I went through my backups - I don't have the .sch or .pcb files for the DC controller. If you find them, can you shoot them to me?
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 3431 05-04-2022 06:43 PM
Paul & Sabrina's Cheap EV Conversion MPaulHolmes Fossil Fuel Free 542 11-12-2016 10:09 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 05:10 PM
