09-04-2010, 06:30 PM
#31 (permalink)
Pokémoderator
Hello -
Is "lots of DFCO" a good place for a PCV oil catch can thingy? Or will it "not help much"?
CarloSW2
09-09-2010, 01:01 PM
#32 (permalink)
Legend in my own mind
With regards to my scangauge not reading 9999 when Engine Off Coasting;
As mentiuoned earlier, it is likely a problem with my scangauge ... After reading through this I changed one of my settings to read GPH and when the car is off and the key is in the ON position I still reads .02 GPH usage instead of 0.00 when the car engages the DFCO while cruising in gear ...
Oh well, at least I found my problem ...
Thanks guys ...
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
09-09-2010, 01:08 PM
#33 (permalink)
Maybe if you set the cutoff value a bit higher it'll work ?
09-09-2010, 02:00 PM
#34 (permalink)
Pokémoderator
trikkonceptz -
Thanks guys ...
Can you do me a favor and tell me what your RPM and MAP are when the car is off and the key is in the ON position? The reason I ask is that when my key is in the ON position, I still see 61 RPM. That leads me to believe that the SG thinks the engine is still running, however slightly. The 61 RPM could be an error in the sensor at 0 RPM (likely), or some kind of failsafe non-zero value reported by the ECU/PCM to avoid divide-by-zero errors (not likely, otherwise why not 1 RPM for that case).
CarloSW2
09-09-2010, 02:19 PM
#35 (permalink)
Originally Posted by cfg83
trikkonceptz -
CarloSW2
Will do, I will try it on my way home and I will post my results as soon as I can ...
The Following User Says Thank You to trikkonceptz For This Useful Post:
09-09-2010, 08:49 PM
#36 (permalink)
oldschool
I would talk to Linear Logic about your display errors. It sounds to me like a problem with the conversions of the raw data into decimal values.
When I tune an ECM I normally program in aggressive DFCO values as possible. DFCO does create a lot of engine braking, though it is possible to reduce this down to a minimum by setting the DFCO IAC steps to the maximum value of 255. This reduces the engine vacuum during coast-down DECEL, but be aware that if you have a manifold pressure sensor it is often used as one of the threshold parameters for the DFCO logic routine. That means that if you reduce engine vacuum too much after DFCO is initiated, then it will just kick back out of DFCO. There is a hysteresis that will keep DFCO from pulsing on and off.
Also, there is a parameter to unlock the TCC when DFCO is activated, which will reduce the amount of time that you can keep DFCO on. I like to keep the TCC locked and the lower limit TCC threshold as low as possible to prevent unlocking during coast-down.
I always run filters on my PCV system, but during DFCO most of the oiling will be coming from the intake valve guides and past the piston rings.
I will try to post some of the calibration and code for DFCO that is used in my 1991 Chevy truck.
09-09-2010, 09:07 PM
#37 (permalink)
oldschool
DFCO strategy
This is about 95% of the calibration and algorithm concerning DFCO in one particular ECM.
; DFCO DECELERATION FUEL CUT-OFF 4 LINE TABLE
LD2E3 FCB 56 ; 1400 RPM, FUEL CUT-OFF, UPPER LIMIT 2500
LD2E4 FCB 40 ; 1000 RPM, FUEL CUT-OFF, LOWER LIMIT 1200
LD2E5 FCB 18 ; 18 MPH, FUEL CUT-OFF, UPPER LIMIT
LD2E6 FCB 15 ; 15 MPH, FUEL CUT-OFF, LOWER LIMIT
LD2E7 FCB 8 ; 22.5 Kpa, S/D MAP DECEL FUEL Cut-Off Thresh, Lower ((X * 0.3125)+20)
LD2E8 FCB 64 ; 40.0 Kpa, S/D MAP DECEL FUEL Cut-Off Thresh, Upper ((X * 0.3125)+20)
LD2E9 FCB 255 ; 3188 RPM/12.5, RPM DIFF DECREMENT (decel rate) THRESH To disable DFCO
LD2EA FCB 255 ; 79.7 Kpa, S/D MAP DIFF INCREMENT THRESH to disable DFCO (X * 0.3125)
LD2EB FDB 0464 ; 7.07 msec, Fuel PW IF EXITING DFCO BY RPM, OR Park/Neut PW * 65.536
LD2ED FCB 160 ; 2 sec REQ FOR DFCO
LD2EE FCB 32 ; 400 Msec AFTER DFCO FOR BPW
LD2EF FCB 240 ; 3 secs MIN TIME BETWEEN DFCO (Sec * 80)
LD2F0 FCB 14 ; 5% MAX TPS FOR DECEL FUEL Cut Off
LD2F1 FCB 96 ; 0.375 MULTIPLIER FOR BPW IN DFCO EVERY 12.5 msec LOOP (sub'd, not mult)
LD2F2 FCB 128 ; 75c/167f, LINEAR COOLANT THRESHOLD TO DISABLE DFCO
__________________________________________
LD5D3 FDB 40 ; 40 Steps, ADDED TO IAC WHEN DFCO IN EFFECT (single byte)
D87A: LD87A LDAA L0021 ; GET LINEAR COOLANT
D87C: CMPA LD2F2 ; COMPARE A TO (75c/167f, DISABLE DFCO BELOW COOLANT THRESHOLD)
D87F: BCC LD884 ; IF COOLANT GT THRESH, BRANCH TO $D884 (DO DFCO CHECKS)
D881: JMP LD946 ; JUMP TO $D946 (TURN DFCO OFF)
D884: LD884 LDAA L000F ; GET STATUS, b4=1= (IN PARK/NEUT)
D886: BITA #$10 ; TEST b4 (IN PARK/NEUT?)
D888: BNE LD8B5 ; IF b4 BRANCH TO $D8B5 (EXIT FUEL DFCO ROUTINE)
D88A: LDAB L0009 ; GET STATUS WORD
D88C: BITB #$24 ; TEST b5,b2
D88E: BNE LD89F ; IF b5,b2 BRANCH TO $D89F
D890: LDAA L0049 ; GET CURRENT TPS
D892: CMPA LD2F0 ; COMPARE TO 5% MAX TPS FOR DECEL FUEL Cut Off
D895: BCS LD89F ; IF TPS LT 5% BRANCH TO $D89F (SKIP DFCO UPDATE)
D897: LDAA L0003 ; GET STATUS WORD FOR DFCO
D899: ORAA #$10 ; SET b4, IN FUEL DFCO
D89B: STAA L0003 ; UPDATE STATUS WORD FOR DFCO
D89D: BRA LD8CB ; BRANCH ALWAYS TO $D8CB
D89F: LD89F LDAA L0020 ; GET OLD RPM/12.5
D8A1: SUBA L001F ; SUBTRACT FILTERED RPM/12.5 (OLD - CURRENT FILTERED)
D8A3: BCS LD8AA ; IF RPM INCREASING, BRANCH TO $D8AA
D8A5: CMPA LD2E9 ; COMPARE TO RPM/12.5, 3188 RPM DIFF To disable DFCO (Decel rate)
D8A8: BHI LD8B5 ; IF DIFF RPM GT CALIBRATION, BRANCH TO $D8B5 (EXIT DFCO ROUTINE)
D8AA: LD8AA BITB #$48 ; TEST b6 & b3, L0009
D8AC: BNE LD8E2 ; IF b6,b3, BRANCH TO $D8E2
D8AE: LDAA L0032 ; GET DIFF MAP (S/D MAP)
D8B0: CMPA LD2EA ; COMPARE TO 100 kpa MAP INCREASE TO DISABLE DFCO
D8B3: BLS LD8D0 ; IF MAP INCREASE LT THRESH TO DISABLE, BRANCH TO $D8D0 (CONTINUE DFCO CHECKS)
; HERE TO EXIT DECEL FUEL CUT/0FF (DFCO)
D8B5: LD8B5 LDAA L00A0 ; GET POST DFCO TIMER
D8B7: BEQ LD8CB ; BRANCH IF TIMER = 0
D8B9: LDD L0096 ; GET BPW, ASYN
D8BB: ADDD LD2EB ; ADD FUEL PULSE WHEN EXITING DFCO, 7.07 Msec BY RPM < OR Park/Neut
D8BE: BCC LD8C3 ; BRANCH IF NO OVERFLOW
D8C0: LDD #$7FFF ; GET USE MAX VALUE
D8C3: LD8C3 STD L0096 ; UPDATE BPW, ASYN
D8C5: LDAA L000D ; GET STATUS WORD
D8C7: ORAA #$80 ; SET b7
D8C9: STAA L000D ; UPDATE STATUS WORD
D8CB: LD8CB CLR L00A0 ; CLEAR POST DFCO TIMER
D8CE: BRA LD937 ; BRANCH ALWAYS TO $D937
D8D0: LD8D0 LDAA L0026 ; GET S/D MAP
D8D2: LDAB L0008 ; GET STATUS WORD FOR DFCO
D8D4: CMPA LD2E7 ; COMPARE MAP TO DFCO MAP Thresh, Lower, 22.5 Kpa
D8D7: BCS LD8E2 ; IF S/D MAP LT DFCO MAP THRESH LOWER, BRANCH TO $LD8E2 (DO OTHER CHECKS)
D8D9: BITB #08 ; TEST b3, (IN DFCO ALREADY?)
D8DB: BEQ LD937 ; IF NOT b3, BRANCH TO $LD937 (TURN DFCO OFF)
D8DD: CMPA LD2E8 ; COMPARE MAP TO DFCO MAP Thresh, Upper, 45 Kpa
D8E0: BCC LD937 ; IF MAP GT DFCO MAP THRESH UPPER, BRANCH TO $LD937 (TURN DFCO OFF)
; Limits for FUEL CUT-OFF In decel (DFCO)
; 1000/1400 RPM 4-LINE TABLE 15/18 MPH
D8E2: LD8E2 LDX #$D2E3 ; POINT TO 4 LINE TABLE DFCO PARAMS
D8E5: LDAB L0008 ; GET STATUS WORD
D8E7: BITB #$08 ; TEST BIT 3 (IN DFCO ALREADY?)
D8E9: BEQ LD8EC ; IF NOT B3, BANCH TO $LD8EC (NO DFCO, CHECK RPM LIMIT UPPER)
D8EB: INX ; INCREMENT REGISTER X BY ONE (IN DFCO, CHECK RPM LIMIT LOWER)
D8EC: LD8EC LDAA L001C ; GET RPM/25
D8EE: CMPA 0,X ; COMPARE RPM TO 1000/1400 RPM HYSTERESIS
D8F0: BLS LD8B5 ; IF RPM LT 1000/1400 LIMIT, (EXIT DFCO)
D8F2: LDAA L0034 ; GET FILTERED VSS MPH/1
D8F4: CMPA 2,X ; COMPARE TO 15/18 MPH
D8F6: BCS LD8B5 ; IF MPH LT 15/18 MPH, (EXIT DFCO)
; CHECK DECEL FUEL CUT/OFF TIMER (DFCO)
D8F8: LDAA L00A1 ; GET DFCO TIMER
D8FA: BNE LD934 ; IF NOT TIMED OUT, BRANCH TO $D934 (DECREMENT TIMER, TURN DFCO OFF)
D8FC: LDAB LD2EF ; GET CALIB 3 Secs MIN BETWEEN DFCO
D8FF: LDAA L0003 ; GET STATUS WORD
D901: BITA #$10 ; TEST b4, (IN FUEL DFCO?)
D903: BEQ LD90B ; IF NOT b4, BRANCH TO $D90B
D905: ANDA #$EF ; CLEAR b4
D907: STAA L0003 ; UPDATE STATUS WORD
D909: STAB L009F ; UPDATE BETWEEN DECEL FUEL C/0 TIMER
D90B: LD90B CMPB L009F ; COMPARE TO BETWEEN DECEL FUEL C/0 TIMER
D90D: BLS LD914 ; IF LOWER OR SAME, BRANCH TO $D914
D90F: INC L009F ; INCREASE DECEL FUEL C/0 TIMER
D912: BRA LD946 ; BRANCH ALWAYS TO $D946 (TURN DFCO OFF)
D914: LD914 LDAB L0008 ; GET STATUS WORD
D916: ORAB #8 ; SET b3,
D918: STAB L0008 ; UPDATE STATUS WORD
D91A: LDAA LD2EE ; GET CALIBRATION, 400msec AFTER DFCO FOR BPW
D91D: STAA L00A0 ; UPDATE POST DFCO TIMER (AFTER DFCO TIL PW)
D91F: LDAA L000D ; GET STATUS WORD
D921: ORAA #$10 ; SET b4, (DECEL ENLEANMENT IN EFFECT)
D923: STAA L000D ; UPDATE STATUS WORD
D925: LDAA L009E ; GET DECEL FUEL MULTIPLIER
D927: SUBA LD2F1 ; SUBTRACT ( A - CALIBRATION, 10.2% MULT FOR BPW IN DFCO)
D92A: BCC LD92D ; IF DECEL FUEL MULT GT CALIBRATION, BRANCH TO $D92D (DO NOT RESET MULT)
D92C: CLRA ; CLEAR A REGISTER (RESET DECEL MULTIPLIER TO ZERO)
D92D: LD92D STAA L009E ; UPDATE DECEL FUEL MULTIPLIER
D92F: JSR LD839 ; GOSUB $D839 (POINT TO BPW SYNC, AND DO CALC)
D932: BRA LD9A4 ; BRANCH ALWAYS TO $D9A4
D934: LD934 DECA ; DECREMENT DECEL FUEL TIMER
D935: BRA LD93A ; BRANCH ALWAYS TO $D93A
D937: LD937 LDAA LD2ED ; GET 2 Sec REQ FOR DFCO
D93A: LD93A STAA L00A1 ; DECEL FUEL CUT/OFF TIMER
D93C: CLR L009F ; CLEAR BETWEEN DECEL FUEL CUT/OFF TIMER
D93F: LDAA L00A0 ; GET POST DFCO TIMER
D941: BEQ LD946 ; IF TIMED OUT, BRANCH TO $D946 (SKIP DECREASE POST DFCO TIMER)
D943: DEC L00A0 ; DECREASE POST DFCO TIMER
D946: LD946 LDAA L0008 ; GET STATUS WORD
D948: ANDA #$F7 ; CLEAR b3 (TURN DFCO OFF)
D94A: STAA L0008 ; UPDATE STATUS WORD
D94C: LDAA #255 ; LOAD A REGISTER WITH MAX VALUE (255)
D94E: STAA L009E ; UPDATE DECEL FUEL MULTIPLIER
D950: LDD L004D ; GET FILTERED TPS (TWO BYTES) INTO D
D952: ASLB ; REGISTER Bx2
D953: ADCA #0 ; REGISTER A ROUND OFF
D955: BCC LD958 ; IF NO OVERFLOW, BRANCH TO $D958
D957: DECA ; DECREMENT A REGISTER
D958: LD958 SUBA L0049 ; SUBTRACT (A FILTERED TPS - CURRENT TPS)
D95A: BCS LD99E ; IF A LT CURRENT TPS, BRANCH TO $D99E (TPS INCREASING, TURN DECEL OFF)
D95C: CMPA LD2E0 ; COMPARE DIFF TPS TO 1% TPS, DECEL ENLEAN INCREMENT THRESH
D95F: BLS LD99E ; IF DIFF TPS LT 1% DECEL THRESH, BR TO $D99E(NOT DECREASING ENOUGH FOR DECEL)
D961: LDD L002F ; GET FILTERED MAP (TWO BYTES) INTO D
D963: ASLB ; REGISTER Bx2
D964: ADCA #0 ; REGISTER A ROUND
D966: BCC LD969 ; IF NO OVERFLOW, BRANCH TO $D969 (DON'T DECREMENT A)
D968: DECA ; DECREMENT A REGISTER
D969: LD969 SUBA L0026 ; SUBTRACT (A, FILTERED MAP - CURRENT S/D MAP)
D96B: BCS LD99E ; IF A LT S/D MAP, BRANCH TO $D99E (MAP INCREASING, TURN DECEL OFF)
D96D: CMPA LD2E1 ; COMPARE DIFF MAP TO 2.5 Kpa S/D MAP DIFF DECREMENT THRESH FOR DECEL ENLEAN
D970: BLS LD99E ; IF DIFF LT 2.5 THRESH, BRANCH TO $D99E (NOT DECREASING ENOUGH FOR DECEL)
D972: LDAB LD2E2 ; GET 0.375 ENLEAN MAP FACTOR (Mult .375 * DIFF MAP for calc)
D975: MUL ; MULTIPLY A x B = D
D976: LDAB L009D ; GET DECEL COOLANT FACTOR
D978: MUL ; MULTIPLY A x B = D
D979: ASLD ; REGISTER Dx2
D97A: BCS LD982 ; IF OVERFLOW, BRANCH TO $D982
D97C: ASLD ; REGISTER Dx2
D97D: BCS LD982 ; IF OVERFLOW, BRANCH TO $D982
D97F: ASLD ; REGISTER Dx2
D980: BCC LD984 ; IF NO OVERFLOW, BRANCH TO $D984 (DON'T USE MAX VALUE)
D982: LD982 LDAA #255 ; USE MAX VALUE
D984: LD984 NEGA ; INVERT
D985: BEQ LD99E ; IF ZERO, BRANCH TO $D99E (TURN DECEL ENLEAN OFF)
D987: LDAB L000D ; GET STATUS WORD
D989: ORAB #$10 ; SET b4, (TURN ON DECEL ENLEAN)
D98B: STAB L000D ; UPDATE STATUS WORD
D98D: STAA L0058 ; UPDATE PROP DURATION, Secs
D98F: LDX #L0096 ; POINT TO L0096 & L0097 BPW, ASYNC
D992: JSR LFBB9 ; GOSUB $FBB9 (FUEL OUT ROUTINE)
D995: STD L0096 ; UPDATE L0096 & L0097, BPW, ASYNC
D997: LDAA L0058 ; GET PROP DURATION, SECs
D999: JSR LD839 ; GOSUB $D839 (POINT TO BPW SYNC, AND DO CALC)
D99C: BRA LD9A7 ; BRANCH ALWAYS TO $D9A7
D99E: LD99E LDAA L000D ; GET STATUS WORD
D9A0: ANDA #$EF ; CLEAR b4 (TURN DECEL ENLEAN OFF)
D9A2: STAA L000D ; UPDATE STATUS WORD
D9A4: LD9A4 LDX #L00AB ; GET L00AB & L00AC BPW, SYNC INTO X
D9A7: LD9A7 LDAA L00B2 ; GET BATTERY COMPENSATION MULTIPLIER INTO A
D9A9: JSR LFBB9 ; GOSUB $FBB9 (FUEL OUT ROUTINE)
09-10-2010, 10:47 AM
#38 (permalink)
OK as requested I checked my RPM and MAP data while Engine Off Coasting.
My RPM's drop to 0 once the engine shuts off, as far as the MAP reading .... well that must not report through my OBT port because it remained blank with no reading whether the car is running or OFF. So sorry about that one ..
The only one that still puzzles me is the GPM that reads .02 while the car is off and key is on. I have to assume that is the only thing keeping the mileage from going to 9999 while EOCing.
Good luck with your quirky SG ..lol
09-10-2010, 11:54 AM
#39 (permalink)
oldschool
Here is a screen-shot of some of the (stock) DFCO calibrations on my 1991 Chevy Truck.
link for larger photo:
http://i702.photobucket.com/albums/w...FCOscreen1.jpg
Note that the factory calibrations shown are not very aggressive at all, and during normal driving conditions it is rare for DFCO to engage.
Also, DFCO and DECEL-enleanment are two completely different things.
DECEL-enleanment commands leaner than stoich AFRs during most deceleration conditions, but only functions when in open-loop mode.
Though it is very wasteful of fuel, closed-loop mode maintains a 14.6:1 AFR during deceleration conditions unless DFCO is engaged.
The Following User Says Thank You to Olympiadis For This Useful Post:
09-13-2010, 10:04 PM
#40 (permalink)
no map sensor ?
...."OK as requested I checked my RPM and MAP data while Engine Off Coasting.
My RPM's drop to 0 once the engine shuts off, as far as the MAP reading .... well that must not report through my OBT port because it remained blank with no reading whether the car is running or OFF. So sorry about that one .."....
the car may not be a speed density system
it may use a MAF sensor as the primary load sensor
in which case
it would not report MAP value in
Generic OBD2 which is all you get with Scangauge2
