08-19-2014, 10:25 AM
#31 (permalink)
This isn't new at all, I am thinking 1970s it first came around. Guys running nitrous oxide will cut back the plugs grounding arm so while on a nitrous shot the extreme heat from burning concentrated amounts of nitrous oxide and gasoline does not over heat the spark plug ground arm, causing it to glow red hot and pre-igniting the fuel.
This is not what he is doing. Look at the picture.
I say it is defiantly not unicorn poo.
Yes, yes it is.
The Following User Says Thank You to Carbon For This Useful Post:
08-19-2014, 10:51 AM
#32 (permalink)
Yes, yes it is.
Wow I couldn't open the picture on my tablet for some reason, now with a real computer I see what going on. Holy crap!
08-20-2014, 05:09 AM
#33 (permalink)
Deedee - '09 Smart ForTwo Pure 999cc 90 day: 47.39 mpg (US)
I don't know why I included the drawing or did the plugs. I am reverent of the idea behind the spark plug and to Mr. Tesla. And so I figured it might pay for a replacement set of plugs.
Yes, yes it is.
Oilpan4:
I remember that style plug Champion plugs were what all they would talk about Also they were quite inexpensive.
I have found the pictures you all
Sorry I am taking too much time but it is an idea.
08-20-2014, 03:08 PM
#34 (permalink)
How big is that chunk? Did you weigh it? If it is steel then it would weigh 8.6 grams per CC.
It does not look that big.
Also the washer that goes with the plug looks like it can be stacked, so if you have a bunch of them those seem ideal to lift the plug to controllably and reversably enlarge the volume.
Now those photos have taken away one of my worries.
The thread is the medium that cools the plug, but in the area where you cut it the core does not touch the metal. So I guess it won't get too much thermal stress there.
08-22-2014, 08:20 PM
#35 (permalink)
wrx - '02 subaru impreza wrx wagon 90 day: 33.81 mpg (US) Leg - '05 Subaru Legacy 2.5i
It should be stated with good reason and understanding a car manual that suggests 91+ does not require 91+.
Most cars that require premium (91+ octane) do so for a reason, such as mentioned higher compression. The higher compression can not be sworted with this mod because there are added components like super or turbo chargers. Cars that suggest 91+ octane do not require 91+ so 87 octane can be used.
With a little web search I see that the smart for two suggests it's required for longevity and an increase of 3mpg. Prove it before creating potential engine damage, also as suggested try a more common mod like a spacer first.
08-22-2014, 08:23 PM
#36 (permalink)
I don't think I've ever seen threads that long on a plug. So in your case I retract the minimal thread/reduce torque statement. But I'll let the rest of my concerns stand.
08-25-2014, 11:36 AM
#37 (permalink)
Yes, yes it is.
Yes, yes it is.
You are quite entertaining. Bless your heart. Don't ever change.
Everyone else: spark plug heat range - Google Search
08-25-2014, 01:11 PM
#38 (permalink)
What are you quoting as entertaining?
08-26-2014, 01:45 AM
#39 (permalink)
It sort-of spoils the joke; but if BikerModder's use of the QUOTE facility were cromulent, then everything after 'Originally Posted by Carbon' would be identical.
Words out of who's mouth? Amirite?
08-26-2014, 05:25 PM
#40 (permalink)
Gotcha... bonus points for using the word 'cromulent'.
