Old 03-20-2012, 11:21 AM   #281 (permalink)
Horse with no name - '00 Ford Mustang Base
Team Mustang
90 day: 20.53 mpg (US)
Orange peel - '00 Ford Focus SE
90 day: 26.83 mpg (US)
Originally Posted by Sven7 View Post
How do you guys change gears during engine braking? I feel like it's probably harder on the clutch than bump starting.
Engine braking is a way to slow the vehicle without using the brakes. When it is time to down shift put on the brakes until the vehicle is slow enough for the next gear, then down shift.
Some cars can save fuel by shutting off the gas during engine braking but that is just a benefit. Saving brakes for when you need them, especially on long steep hills is the main reason to engine brake. I personally like not having to change the brakes for 150K miles.
Old 03-20-2012, 01:36 PM   #282 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
These days I usually engine brake until it's at about 1500rpm then downshift and let it slow down some more. Just didn't know whether to blip the throttle like normal.
Old 03-20-2012, 03:03 PM   #283 (permalink)
90 day: 51.82 mpg (US)
I would still blip for the downshift: a tiny amount of fuel vs. a bit of clutch wear.
Use the engine for braking, not the clutch itself.
Old 03-20-2012, 03:33 PM   #284 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
A slight blip of the throttle will make it just as smooth as an upshift.
Old 03-25-2012, 02:20 AM   #285 (permalink)
Sven7's Avatar
OK thanks guys
Those front and back designs are really going to mess with other drivers
Old 03-25-2012, 08:20 AM   #286 (permalink)
I don't think that stress is good for the camshaft and other connected bits.
Never do that in a Porsche 911, very bad for the engine and transmission, mostly the transmission. Many new 911 owners have found this out the hard way (expensive way).
Brakes are on a car for a reason, use them - brake pads are replaceable and acceptable wear items. Brake pads are cheaper than transmission work too.
Tyler, the title of this tread tells me that you would enjoy the movie "Your Highness" (comedy). I watched the unrated version on BluRay yesterday, my wife claimed it to be a "guy movie". Natalie Portman has some good lines in it too.
Your car is looking loved again, keep it going on.
Old 03-25-2012, 10:16 AM   #287 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 80.56 mpg (US)
Send a message via MSN to jakobnev
How is engine braking supposedly stressing all those bits?
Old 03-25-2012, 12:41 PM   #288 (permalink)
Team Mustang
I think he means that trying to slow a super car by down shifting can ruin the engine. This is true, you can over rev any engine by aggressively down shifting. When I engine brake I aggressively regular brake before I down shift.
He may also not live in a hilly area. Long steep hills with stops at the end that would smoke even my brakes. I had to teach my brother how to engine brake on his first automatic because he was smoking his brakes until the point of fad on long downhills.
Also take what kach22i says with a grain of salt. He told me to oil my distributor but my engine had not had one for 6 model years before mine.
The Following User Says Thank You to pjbgravely For This Useful Post:
bespurcell (01-30-2015)
Old 03-25-2012, 06:07 PM   #289 (permalink)
Look up White Bird Hill, Idaho on Google Maps. Check out the elevation change from top to bottom. 4,245 ft (1,294 m) at the summit.
Headed south, it's a quite steep grade. Many was the time I would drive down that road, no need for brakes or down shifting (especially in my 1977 Mustang with 351ci V8, same for my 1988 Corsica after replacing the buggy computer chip) while tooling along at 55 MPH.
Almost always some nut would blast past me at the summit, driving hard into every curve, frying his brakes. At the bottom I'd still be right on his tail. All that extra effort for no gain in overall time down the mountain.
Old 03-25-2012, 07:23 PM   #290 (permalink)
.....I had to teach my brother how to engine brake on his first automatic...........
I'm willing to admit that I have no idea how to do this either. Please try to step by step me through this process.
Bent vales and burnt clutches, just say no to engine braking on some cars (like vintage 911's).
You must drive one of those fancy modern cars less than 25 years old.
Vintage does have it's drawbacks, but makes life more interesting too.
