Old 01-15-2009, 08:39 PM   #11 (permalink)
Wannabe greenie
The Clunker (retired) - '90 Honda Accord EX sedan
90 day: 29.49 mpg (US)
Mountain Goat - '96 Ford Ranger XLT 4x4 SuperCab
90 day: 18 mpg (US)
Zippy - '10 Kymco Agility 125
90 day: 65.03 mpg (US)
Originally Posted by Christ View Post
For the modder - fuel cut is merely a switch away.. since your fuel cut is partially controlled by the TPS, which is only a small pot anyway, you might be able to rig up another pot that shows the ECU 0 throttle whenever you want it to.
This probably won't work on speed/density (mass air flow) systems.
Anyway - the idea is that if you MUST leave it in gear, and leave the engine on, set it up so that you can manually cut the fuel, then open the throttle to 100% (least pumping losses for the engine). In this way, you can partially modulate the amount of engine braking that is actually being done.
This could be achieved using some type of switch and a rotary pot.
I tried the open throttle on the Clunker when doing my 13 mile downhill. I switched off the key, and then tried going downhill in gear with the throttle both closed and open. It changed the sound of the engine, but didn't reduce engine drag at all. I think the only way to make that work would be to also hold the intake valves open, and my engine's an "interference" engine, so I think I'd end up with bent valves anyway.
Old 01-15-2009, 10:21 PM   #12 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Originally Posted by modmonster View Post
is that thing about engine oil amount true? only fill up to the lower limit and you get less oil pumping losses?
Not oil pumping losses... but it does create less work for the engine to do, if the crank is churning that oil... you can get away from doing this by installing a windage tray... not only do you get the benefits of NOT risking oil starvation, but you will actually gain a few HP at the flywheel from the windage tray shaving oil off the crank, reducing the rotating weight (and thus the power needed to spin it) of the crankshaft. It's kinda like adding a lighter flywheel... it doesn't give you more horsepower, it just lets you use more of what's already being created.
I think this has alot to do with the engine size and type, among other considerations. To accurately see how it affects coastdown times, you'd have to AABBAA test it, honestly. It's not by and large a huge difference, but in some cars, there is a difference.
My loose-engined Civic, for instance - I would be able to modulate 3-5 MPH difference at the end of a long coast on the same stretch of flat road, when coasting from the 45mph stop sign to the same curve (really tight curve, have to slow down to like 20 or so) Usually, by the time I hit that curve, I'd be around 30 MPH... but using the throttle with the engine off, I could keep it around 33-35 MPH over that same 1000ft stretch. Of course, engine RPM also has alot to do with it, and I would never take it out of 3rd gear while doing this.
Old 01-15-2009, 10:51 PM   #13 (permalink)
Wannabe greenie
90 day: 18 mpg (US)
Ah, okay. I think my expectations were too high, and maybe it does make a difference, but not as much difference as I expected.
Old 01-15-2009, 10:55 PM   #14 (permalink)
Frictional losses are most definitely the biggest culprit for engine braking... Imagine it this way -
You've got a 300 lb person sitting on your chest, and you're flat on your back on a hardwood floor, with your mouth and nose covered by a slightly porous wet rag. You're laboring to breathe at this point...
Remove that rag, but leave the fat guy. Now you can breathe freely, but your chest has trouble rising to get an "easy" breath...
When you open the throttle, you're just taking the rag off your engine's face - get it?
Old 01-15-2009, 10:58 PM   #15 (permalink)
Wannabe greenie
90 day: 18 mpg (US)
Great imagery; now I'm going to have nightmares.
Old 08-28-2009, 01:37 PM   #16 (permalink)
noxman's Avatar
I love DFCO mode. This mode helped me go down about 1 litre on 100km. ( 5 to ~4).
Verified by refueling, driven over 100km (105) with average consumption 4,12 l/100km. (my personal record).
Driven at highland ( hills and downhills) and flat road.
Pulse and dfco mode at flat roads i tried also. But i have not data yet.
Engine-off glide i don't use because i'm too much scary :-/
1.Fiat Punto 1.1 8v 40 Kw - 1996. 4l/100km with external board computer http://www.youtube.comwatch?v=P0Eq_m1VhBQ
2.Fiat Punto 1.2 8V 44kw - 2002, LPG injection system, trying to be eco... Video shows my lpg system and ride.
http://www.youtube.com/watch?v=FlQ-Xl6aIj0
Old 08-28-2009, 07:58 PM   #17 (permalink)
Intermediate EcoDriver
Mustang Dave's Avatar
Trigger - '07 Ford Mustang V6 Premium Coupe
Team Mustang
Sports Cars
90 day: 32.76 mpg (US)
Big Red (retired) - '89 Ford F-250 4wd Custom
90 day: 18.13 mpg (US)
Big Red II - '13 Ford F-150 FX4
Pickups
90 day: 19.61 mpg (US)
I love DFCO mode.
So do I!
That said, I only use DFCO as a substitute for my service brakes. For Decelerating and controlling my speed on a downgrade. From my point of view, those are the only scenarios that warrant its use.
It's helped me get fairly decent fuel economy from my "pony". It saves brake pads and fuel.
YMMV
Fuel economy is nice, but sometimes I just gotta put the spurs to my pony!
Originally Posted by thatguitarguy View Post
Just 'cuz you can't do it, don't mean it can't be done...
Originally Posted by elhigh View Post
The presence of traffic is the single most complicating factor of hypermiling. I know what I'm going to do, it's contending with whatever the hell all these other people are going to do that makes things hard.
Glossary Take II SVOboy Forum News & Feedback 50 12-29-2022 08:09 PM
