Old 09-17-2022, 01:04 PM   #1091 (permalink)
It's an aerodynamic oddity becasue it's an air compressor?
Thomas Smith began the Smith Model A Motor Compressor Co when he realized how much air compressors were needed in industry, and construction, by rethinking junkyard Model As
Smith designed a clever system to retrofit a used Model A.
He patented a cylinder head for the car’s 40-horse four-cylinder:
Cylinders one and four burned gasoline, powering the engine as usual;
two and three pumped air into a reservoir tank mounted on the car
It reminds me of the Dunn-Right compressor, also based on a 4-cylinder 40HP base engine.
dunnrightinc.com
Home [dunnrightinc.com]
Dunn-Right Incorporated Home of the "Volks-Air" Air Compressor Sold Worldwide Since 1987 3672 Abbeville Hwy. Anderson, SC 29624 Voice (864) 296-9316 Fax (864)296-1636 "When it has to be Dunn-Right" Build it Yourself from an Air-Cooled VW Engine. 120 PSI Max Pressure.
Old 09-17-2022, 03:21 PM   #1092 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Brazilian mid-'90s medium-duty Ford F-Series, with the Brazilian-specific aerodynamic cowl. They're a dying breed...
Maybe the front was lowered/rounded for better visibility?
Still, looks nice
Old 09-17-2022, 05:54 PM   #1093 (permalink)
One wonders how well it would fit an F-150.
Old 09-20-2022, 10:05 PM   #1094 (permalink)
The cab is basically the same of a bricknose or OBS F-150 anyway...
Not sure if that was taken as a priority at the designing stage, but most likely it was easier to mould. The tilt-cowl is a single-piece fiberglass unit.
Old 09-23-2022, 01:01 PM   #1095 (permalink)
justacarguy.blogspot.com/2022/09/piaggio-grip-p-7-1929
It never flew. Taxi tests only, and problems with the clutches meant it never made the 1929 race.
Old 09-24-2022, 10:43 AM   #1096 (permalink)
Brilliant concept, ahead of it's time?
Piaggio P.7
https://en.wikipedia.org/wiki/Piaggio_P.7
http://lisa-airplanes.com/en/private...tion/seafoils/
Old 09-24-2022, 12:20 PM   #1097 (permalink)
My thought was an electric conversion would obviate the clutch problem.
Know anybody that makes R/C models?
Old 10-03-2022, 02:54 PM   #1098 (permalink)
Re Permalink #1091, JACG posted his banners for the month, which makes this accessible:
justacarguy.blogspot.com/2022/09/the-banners-of-september
Old 10-04-2022, 01:37 AM   #1099 (permalink)
That looks so strange with the longitudinal leaf-springs, instead of the transverse leaf-springs which were originally fitted to full-size Fords at least until the '40s.
Old 10-04-2022, 12:03 PM   #1100 (permalink)
It makes sense. A traverse spring requires a wishbone or radius rods.
