Old 07-09-2009, 01:20 PM   #1 (permalink)
Removing decals?
As most have seen, I just picked up a Prius. On the back, the dealer of course had to slap his decal on. I don't like it and want it off. Chalk it up as a weight reduction if you want to. I just don't like it. So, what is the best way to remove a decal?
Old 07-09-2009, 03:56 PM   #2 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Warm it with a hair dryer, or let it warm up in the sun (with the careful help of mirrors or lenses) if you don't want to use electricity. Then try to 'floss' it with fishing line. I'm thinking of doing the same with a few decals I have, and that is the answer I got when asking around.
Old 07-09-2009, 07:55 PM   #3 (permalink)
Harebrained Idea Skeptic
The White Car - '84 Mercedes-Benz 300td
90 day: 28.84 mpg (US)
The Blue Car - '86 BMW 535i
Last 3: 23.86 mpg (US)
"Flossing" works on foam-adhered badges, but it won't work well on a decal.
If a hairdryer doesn't do the trick, get some General Purpose Adhesive Cleaner #051135-08984 from an auto body supply shop -- it will dissolve the glue without harming the paint. It's a great solvent for working around the car, so you'll find other uses for it as well.
Old 07-09-2009, 08:39 PM   #4 (permalink)
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
Heat + plastic paint scraper and maybe some solvent.
!!!!!NOT SOLVENT + HEAT!!!!!!!
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
Old 07-09-2009, 09:45 PM   #5 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
Heat is the trick and then a good fingernail will work it off without damage. After it's removed, buff it.
GeoMetroforum.com - got mpg?
Old 07-10-2009, 12:12 AM   #6 (permalink)
if it's one of those thick plastic ones, just peel it off with fishing line or something, then use goo gone and a cloth to remove the remaining stuff.
if it's a normal decal, you can buy a rubber wheel that goes on a drill and will be amazingly effective at removing it. Goo gone for the remainder.
Some polish and wax after and it'll probably disappear.
Old 07-10-2009, 12:46 AM   #7 (permalink)
My Goal: 35 MPG All Day
RandomFact314's Avatar
1NZ-FE (Year 1) - '05 Scion xA RS 2.0
Last 3: 34.02 mpg (US)
1NZ-FE (Year 2) - '05 Scion xA RS 2.0
90 day: 33.32 mpg (US)
1NZ-FE (Year 3) - '05 Scion xA RS 2.0
90 day: 35.32 mpg (US)
1NZ-FE (Year 4) - '05 Scion xA RS 2.0
90 day: 34 mpg (US)
1NZ-FE (Year 5) - '05 Scion xA RS 2.0
90 day: 26.87 mpg (US)
1NZ-FE (Years 6,7,8) - '05 Scion xA RS 2.0
90 day: 28.6 mpg (US)
1NZ-FE (Years 9,10,11) - '05 Scion xA RS 2.0
90 day: 27.8 mpg (US)
1NZ-FE (Years 12,13,14) - '05 Scion xA RS 2.0
90 day: 29.13 mpg (US)
I JUST posted a post like yesterday, of me removing all the badges on my car, I sprayed it with goo gone, let it sit for a few seconds and got some thread and flossed all of them off, really easy... http://ecomodder.com/forum/showthrea...tyle-9154.html was my post
Old 07-10-2009, 01:30 AM   #8 (permalink)
Eucalyptus oil is another eco friendly oil which happens to be great for removing glue residue from decals etc.
Cheers , Pete.
Old 07-10-2009, 07:05 AM   #9 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Sand-blaster! I hear the rough surface will make the paint like a golf ball and therefore more aerodynamical!
Old 07-10-2009, 10:37 AM   #10 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 49.47 mpg (US)
Bad Yankee! No Chowder!
Ecomodder.com stickers / decals - information page SVOboy Forum News & Feedback 192 05-28-2018 08:50 AM
Removing your spare tire? Krunko EcoModding Central 31 06-25-2011 09:39 AM
Dumb Idea of the Day(TM)?: removing a compression ring to mimic the XFi 1-ring piston MetroMPG EcoModding Central 22 02-18-2009 04:43 PM
Removing components off engine belt. NoCO2 EcoModding Central 15 02-11-2008 04:52 PM
