09-26-2021, 02:38 PM
#171 (permalink)
High Altitude Hybrid
I remember a guy that had a geodesic house in South Park with a sunroom. He said he could leave his house with the heat off all winter and not have to worry about anything freezing inside.
09-27-2021, 12:53 AM
#172 (permalink)
The dome I lived in was half a duplex with a connecting room. Open both doors and my stereo just sounded mono in the house in front. It was at a time when everybody liked The Tractors Baby Likes to Rock It so it was okay. A dome with an igloo-style entry (hyperbolic paraboloid, if you please) is a good start on a neighborhood musical instrument.
They're still working on the blades. But why? The single-curved plywood they are forming just needs to be compound curved.
.Necessity is the mother of invention, but simplicity is it's favorite aunt --Amish proverb
09-27-2021, 09:27 AM
#173 (permalink)
Compound curving plywood without stout steam pressure molds is a pita, even using 1/16 aircraft ply. Much ewsier to Hughes process the plywood on a buck form
09-27-2021, 11:22 AM
#174 (permalink)
Perfect timing now that plywood is $100 sheet.
09-27-2021, 02:12 PM
#175 (permalink)
I took this picture myself, years ago when I could travel as far as McMinnville.
I believe aerohead has used a concrete female form to make aerocaps (or something).
09-28-2021, 02:07 AM
#176 (permalink)
I'm particular to a spiral staircase wrapped around a pneumatic elevator.
A spiral staircase would most likely be my choice if I were building a house, yet it wouldn't leave room for storage below it (or even to make a Harry Potter-themed bedroom for some guest  ).
09-28-2021, 03:54 AM
#177 (permalink)
Even if the spiral is around a 18" pipe one could have a dumbwaiter inside it. My parent's house had a dumbwaiter in the downstairs bathroom to the laundry on the second floor.
The pneumatic elevator is cool because if you use an accumulator It doesn't take a noisy fan to recharge it. (30 gallon steel drums buried under a concrete slab for air storage)
09-28-2021, 09:58 AM
#178 (permalink)
But lift is equal to diameter and pressure, so you either lift small/light things or have a big higher pressure reservoirs. Not a bad idea however, if I ever get a multistory.
09-29-2021, 12:30 AM
#179 (permalink)
Enabling some remote fitment of the fan in a less noise-sensitive part of the house would be interesting, and maybe also become easier to recharge the accumulator either when energy is cheaper or when there is a peak generation considering an off-the-grid house. Sure I would be willing to experiment with either solar or wind power generations, maybe even both, if I were already living in a house instead of an apartment.
09-29-2021, 02:37 AM
#180 (permalink)
The pneumatic elevator has some advantage in installation, no pit for an hydraulic ram underneath or chainhouse above it. And having the available air facilitates double side-sliding doors as in Star Trek.
Think about it before. The process of putting yourself in a house will suck you back into the main stream if you're not resisting every step of the way.
