Old 09-26-2021, 02:38 PM   #171 (permalink)
High Altitude Hybrid
Avalon - '13 Toyota Avalon HV
90 day: 40.45 mpg (US)
Prius - '06 Toyota Prius
I remember a guy that had a geodesic house in South Park with a sunroom. He said he could leave his house with the heat off all winter and not have to worry about anything freezing inside.
Old 09-27-2021, 12:53 AM   #172 (permalink)
The dome I lived in was half a duplex with a connecting room. Open both doors and my stereo just sounded mono in the house in front. It was at a time when everybody liked The Tractors Baby Likes to Rock It so it was okay. A dome with an igloo-style entry (hyperbolic paraboloid, if you please) is a good start on a neighborhood musical instrument.
They're still working on the blades. But why? The single-curved plywood they are forming just needs to be compound curved.
Without freedom of speech we wouldn't know who all the idiots are.
anonymous poster
• If you loan someone $20 and you never see them again because they are avoiding paying you back, that makes it worth $20.
Kevin Kelly
Old 09-27-2021, 09:27 AM   #173 (permalink)
Compound curving plywood without stout steam pressure molds is a pita, even using 1/16 aircraft ply. Much ewsier to Hughes process the plywood on a buck form
Old 09-27-2021, 11:22 AM   #174 (permalink)
90 day: 28.24 mpg (US)
Lafawnda - '01 Honda CBR600 F4i
Big Yeller - '98 Dodge Ram 2500 base
Prius Plug-in - '12 Toyota Prius Plug-in
90 day: 57.64 mpg (US)
Mazda CX-5 - '17 Mazda CX-5 Touring
90 day: 27.52 mpg (US)
90 day: 16.56 mpg (US)
Perfect timing now that plywood is $100 sheet.
Old 09-27-2021, 02:12 PM   #175 (permalink)
I took this picture myself, years ago when I could travel as far as McMinnville.
I believe aerohead has used a concrete female form to make aerocaps (or something).
anonymous poster
Kevin Kelly
aerohead (09-29-2021)
Old 09-28-2021, 02:07 AM   #176 (permalink)
I'm particular to a spiral staircase wrapped around a pneumatic elevator.
A spiral staircase would most likely be my choice if I were building a house, yet it wouldn't leave room for storage below it (or even to make a Harry Potter-themed bedroom for some guest ).
Old 09-28-2021, 03:54 AM   #177 (permalink)
Even if the spiral is around a 18" pipe one could have a dumbwaiter inside it. My parent's house had a dumbwaiter in the downstairs bathroom to the laundry on the second floor.
The pneumatic elevator is cool because if you use an accumulator It doesn't take a noisy fan to recharge it. (30 gallon steel drums buried under a concrete slab for air storage)
anonymous poster
Kevin Kelly
Old 09-28-2021, 09:58 AM   #178 (permalink)
But lift is equal to diameter and pressure, so you either lift small/light things or have a big higher pressure reservoirs. Not a bad idea however, if I ever get a multistory.
Old 09-29-2021, 12:30 AM   #179 (permalink)
Enabling some remote fitment of the fan in a less noise-sensitive part of the house would be interesting, and maybe also become easier to recharge the accumulator either when energy is cheaper or when there is a peak generation considering an off-the-grid house. Sure I would be willing to experiment with either solar or wind power generations, maybe even both, if I were already living in a house instead of an apartment.
Old 09-29-2021, 02:37 AM   #180 (permalink)
The pneumatic elevator has some advantage in installation, no pit for an hydraulic ram underneath or chainhouse above it. And having the available air facilitates double side-sliding doors as in Star Trek.
Think about it before. The process of putting yourself in a house will suck you back into the main stream if you're not resisting every step of the way.
anonymous poster
Kevin Kelly
Copyright ©2000 - 2022, vBulletin Solutions Inc.
