Go Back   EcoModder Forum > AltModding > Alternative Transportation
Old 02-09-2008, 10:21 AM   #61 (permalink)
ECO-Evolution
Lazarus's Avatar
Iron Horse (retired) - '97 Iron horse Intrepid
Ninja - '08 Kawasaki 250R
90 day: 76.23 mpg (US)
You might know this but there should be two clicks on the front shifter when you shift which will move the FD either further out or closer in depending on where you are running the rear cogs to keep it from rubbing. When you engage it all the way push the little shifter just enough to bring it back a bit without taking it off the big ring. Also what gears is it rubbing in. You should not be extreme cross chained, Big ring front big cog back or Small ring front small cog rear that will wear the chain and cogs fast and will rub on most road bikes.
"Judge a person by their questions rather than their answers."
Old 02-09-2008, 01:06 PM   #62 (permalink)
Send a message via AIM to Gone4
I did not know this! I guess I should get my pedals and ride it for real to make sure I am actually having problems. Up until this I only had mountain bikes with 27 gears, or fixies, and the borrowed road bike last summer with 27 gears that weren't indexed.
Old 02-09-2008, 01:06 PM   #63 (permalink)
Originally Posted by Who View Post
http://www.crankbrothers.com/quattro.php
Disadvantage: A bit slower to engage than typical road pedals
I do rando riding (200 - 1200kms) and these are incredible pedals and can be had for under $100 if you shop around. These are essentially eggbeaters with a platform.
Are they too slow for riding in the occasional traffic?
Old 02-09-2008, 02:18 PM   #64 (permalink)
Who
UnderModded
Pablo - '07 Hyundai Santa Fe AWD
90 day: 23.62 mpg (US)
They are totally fine for that in fact some pros race with them. They are just a tad bit slower for clipping in. No maintenance or adjustments needed. Also the cleat is protected to help with walking, although it is not a fully recessed cleat like the SPDs and other MTB style pedals. The cool part with the longer platform area is that it makes them far easier to adjust angle than SPDs. With SPDs it is very difficult to only move them a degree or two because you are turning it right at the cleat. With these the housing is 2 or 3" long so it's like a longer more precise way. Fit is everything when cycling any distance, and cleat position and angles are vitally important.
Old 02-09-2008, 05:13 PM   #65 (permalink)
Awesomeness personified
AndrewJ's Avatar
Harold - '94 Honda Civic CX
90 day: 54.51 mpg (US)
Margot - '08 Surly Big Dummy
Send a message via AIM to AndrewJ
I currently have regular eggbeaters and eggbeater mallets (the ones with the huge BMX style platforms) and I find that both of them are equally fast to clip into. I've never been able to clip in as fast with any other pedals, and the only other type of pedals I haven't tried are speedplays.
"I got 350 heads on a 305 engine. I get 10 miles to the gallon. I ain't got no good intentions." - The Drive By Truckers.
Old 02-10-2008, 12:05 AM   #66 (permalink)
Who
UnderModded
Andrew, I had Speedplay Zeros before the Crank Bros Quattros... sinfully expensive and a nightmare for maintenance. Philips srew-heads (is anything worse?) that have to go snug plus a ΒΌ turn and then it's up to locktite to save the day. The float is wonderful, even if you feel you you are walking on ice, but they just weren't durable and if they got really wet they wouldn't release.
They'd hot spot on long rides, were terrible to walk in, and you could pull out of them in a sprint.
Old 02-26-2008, 07:19 PM   #67 (permalink)
Just to serve as a thread update. I was given a Cateye bicycling computer, including cadence, I found some egg beater quattro's pretty cheap, and bought a pair of shoes. After my grueling week of school work, I should be taking the bike for a ride this weekend in the field house. We're getting a good 28 inches of snow starting 12 hours ago and extending for the next 24 hours, so I won't get to try it on pavement for a while...
Total spent is $497 for the bike, shoes, pedals (free), and computer. If I were intending to ride this to displace driving costs, it would take me quite some time. This is discounting the considerable amount of time it took getting good deals on everything. Fortunately I fully intend to use it for recreation.
Should I get (and carry?) a spare tube or tire repair kit? I did about 3k miles last summer without giving it a thought, honestly.
Thansk for all the help, I'm sure I'll be back with questions after my first ride
Old 02-26-2008, 08:40 PM   #68 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Nice! Cadence!
I carry a spare tube and a pump/c02 canister...the last time I got a flat it was a long 2 hour walk home, and think if I had gotten the 15 miles out that was my goal...
How my home-built bicycle trailer lowers my MPG MetroMPG Alternative Transportation 17 03-30-2012 07:15 PM
X-Prize team is looking for advice AD5OS General Efficiency Discussion 24 01-16-2008 09:48 PM
Smooth Road Effect newtonsfirstlaw General Efficiency Discussion 7 01-16-2008 05:37 PM
If all the vehicles on the road were ultra-low Cd.... basjoos EcoModding Central 10 01-07-2008 08:34 PM
Article: Road traffic up 84% in the U.K. MetroMPG General Efficiency Discussion 20 12-15-2007 02:34 PM
