Old 07-22-2010, 02:10 AM   #71 (permalink)
Chug - '96 Volkswagon Polo CL
90 day: 49.42 mpg (US)
L'Autre - '03 Renault Megane Sport Tourer Expression
Diesel
90 day: 45.02 mpg (US)
I'm going to do a internal grill block when i replace the rad this weekend, I was also thinking of putting in a rad blank across the majority of the surface in order to bring the temps up quicker.
Sadly i can't find any smaller rads with out going Alloy, and that would improve the cooling + its a bit out of my price range!
good things come to those who wait, sh*t turns up pretty much instantly
twitter.com/bertchalmers
Old 07-22-2010, 05:54 AM   #72 (permalink)
vtec-e's Avatar
De Yaris - '04 toyota yaris T2
90 day: 69.55 mpg (US)
But isn't it less cooling you need? Save your money and get a bog standard one. You'll be blocking it off anyway. Good luck with the repairs Rob.
Old 07-22-2010, 06:15 AM   #73 (permalink)
Diesel
yep - got a bog standard one off the car I took the bumper, grille etc from all Rads are common (according to brief internet searches) on the 6N polo :thumb up: makes things easy!
Old 07-22-2010, 08:07 AM   #74 (permalink)
The Mistress - '88 Bmw 320i Touring SE
Team m8
Last 3: 27.17 mpg (US)
Germany Beadle - '91 Mercedes 300td (estate, N/A)
90 day: 24.63 mpg (US)
The Bloodylingo - '05 Citroen Berlingo Multispace Desire
90 day: 39.77 mpg (US)
Shanner Scaab - '03 Saab 9-5 estate Vector
90 day: 26.19 mpg (US)
Clio 182 - '05 Renault Clio RS 182 182
90 day: 31.73 mpg (US)
There are several different sizes of rad listed on GSF's website- maybe worth seeing them side by side?
As for the rad block- I dont think that'll help it heat up quicker- surely the thermostat keeps the coolant in the block until Operating temp reached?
The Following User Says Thank You to 320touring For This Useful Post:
robchalmers (07-22-2010)
Old 07-22-2010, 09:58 AM   #75 (permalink)
Diesel
good point well put.
Old 07-22-2010, 11:53 AM   #76 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Originally Posted by ConnClark View Post
A warm air intake on a diesel reduces fuel economy as well as power and increases NOx emissions. No body benefits from a warm air intake on a diesel
Yep on a d best to cool the intake or make the intake bigger and move it to suck from a high pressure cooler location. On old NA 6.2s dual snorkles was popular because you gained a noticeable amount of power and a bit of fuel economy.
It is OK to heat the fuel on a diesel and that can have certain positive side effects But don't heat the air.
Old 07-22-2010, 12:19 PM   #77 (permalink)
vtec-e's Avatar
True, but the cold air coming through the rad will help cool the engine directly as it blows onto it. Mine was blocked completely last winter and i barely got it above 85 deg c. with the block. Without the block it took longer to get to a max of 80 deg c. I agree though, it's a small gain but it sure helped me last winter.
I must point out that i never do motorway speeds and never stop pulse and gliding. If i drove normally the engine would overheat for sure.
So it's a case of horses for courses maybe?
ollie
Old 07-22-2010, 03:03 PM   #78 (permalink)
The PRC.
the hammer - not sophisticated but does the job
Rob - Assuming the big square thing at the back is the air filter where does the pipe coming out of the left go to ? If you want to experiment maybe an upper grill block with that pipe just behind an opening to get the coldest air into it ?
You've also turned my head now Mr Chalmers - I keep looking at every example of this Polo and checking it out for the 1.9D badge...
Old 07-22-2010, 03:07 PM   #79 (permalink)
The PRC.
I think the block makes this happen faster though especially if you have a fairly big grill like older cars (think The Sweeney Cortina ). My uncle has a Landy SII with a wide open mouth and his heater starts working much sooner in winter with his radiator 'muff' (steady - its like a glove...) on than when not.
Once its up to temp then the thermostat should keep it there ?
(I use the ? so some expert can come along and correct my ramblings...)
Old 07-22-2010, 04:21 PM   #80 (permalink)
Diesel
the box is the intake chamber the filter is in the front corner of the bumper. the intake itself is in the front wheel arch.... odd huh. thinking about moving it to the grille area to get cool air in a ram effect.
when I change the rad tomoro I'll try and remember to take pics while I've got the bumper off
VW Polo Cup game - Try to be economical master noxman The Lounge 3 04-12-2024 01:33 PM
Spark ignition Diesel engine, AKA your car mechman600 EcoModding Central 28 05-11-2017 07:12 PM
Undertray / belly pan build - VW Golf MK3 1.9 Turbo Diesel sallen Aerodynamics 27 05-21-2011 01:13 PM
Rob's '98 VW Polo Build Thread robchalmers EcoModding Central 36 05-16-2010 05:33 PM
Build Thread Key Postings Index Experiment. TestDrive Forum News & Feedback 7 02-15-2009 08:53 PM
