Old 10-21-2008, 05:38 PM   #11 (permalink)
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
I don't see how using the same pump at the same gas station and the same grade of gas would get you better FE.
I absolutely agree that doing so would take a set of variables out of your testing and make you tests more valid. I do this myself while testing. Rigorously objective testing is truth.
I tried acetone. No improvement over a 1500 mile test.
I tried two-stroke oil. No improvement over a 1500 mile test.
I wasted a whole testing season (mid-May to late September) on snake oil - which is what I view acetone and/or two-stroke oil.
Acetone is an excellent clean-up solvent and takes off yellow road paint. Its really good prep for a high-quality wax job. But improving MPG? No.
BTW, you can get acetone in a studly container in Lowe's.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
Old 10-21-2008, 05:51 PM   #12 (permalink)
MechE
The Miata - '01 Mazda MX-5 Miata
This is EXACTLY WHY I hoped Acetone would NOT make a difference...
I'm looking at your log... and I honestly don't see a difference.... Acetone #2 was high - but Acetone #3 was lower... Which leads me to think #2 was pump error under fill.
Your 90 day average is 41.61.... Your last 3 fill average is 41.47... Your lifetime is 40.92.... The average of all acetone fills thus far is 41.60. Without doing the math - what you're seeing from tank to tank is statistically insignificant. the variation you're getting is within the normal variation. Your Acetone #2 is only .19mpg higher than your second highest non acetone mpg fill (42.86) - also note the large drop in mpg right after that 42.86mpg fill (down to 38.58).
The service truck was probably to check calibration - which is done periodically to ensure the station isn't screwing you
I'll keep adding less n' less Acetone until my mileage peaks, and it starts going the other direction... then, I'll add more n' more and see if it comes back up again. In other words, I'm seeking a 'happy median'.
If you want to do that - with any statistical significance and/or confidence... You need to maintain a consistent mixture over a series of tanks (maybe 1000 miles or more). Then modify the variable and run for another 1000+ miles. Otherwise, there's too many variables.... Unfortunately, weather (seasonal) is going to be a big deal.
The best way to do this would be to have it done blind such that you can't make this claim:
The Acetone makes my ride *feel* like I'm running premium gas again (which Honda recommends) although this is likely a placebo effect.
Cars have not created a new problem. They merely made more urgent the necessity to solve existing ones.
Old 10-21-2008, 05:52 PM   #13 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Might be a good 'lesson' in this somewhere, no?
Lesson should be: on-road "testing" of additives is next to futile.
Old 10-22-2008, 01:25 PM   #14 (permalink)
CAUTION: May Stink!!!
BlackDeuceCoupe's Avatar
BDC's Honda CiViC HX/Si - '98 Honda CiViC HX/Si (HX Shell/Si Swap)
90 day: 40.56 mpg (US)
Send a message via ICQ to BlackDeuceCoupe Send a message via AIM to BlackDeuceCoupe Send a message via MSN to BlackDeuceCoupe Send a message via Yahoo to BlackDeuceCoupe
Without doing the math - what you're seeing from tank to tank is statistically insignificant...
If you want to do that - with any statistical significance and/or confidence... You need to maintain a consistent mixture over a series of tanks...
True, on both accounts!
I'm going to continue going through this 16 oz. bottle of Acetone, then call it quits for a while.
There is NO doubt that my car is running 'smoother' with the Acetone, but the FE is all over the place, and it's a PITA to mix. No matter how careful I am, I always end up getting some on my hands/fingers - which is not a good thing, from what I've read...
And, yes, my 'measuring cup' routine leaves a lot to be desired - that alone might explain the wild fluctuations and inconsistency in mileage.
LoL!
My 'sig' is becoming a self-fulfilling prophecy...
.:: B16A2 HX/Si Coupe | '98 HX shell with full '99 CiViC Si swap | 40+ MPG
Listen to the people who fail. They know what they're talking about!
Old 10-22-2008, 03:03 PM   #15 (permalink)
WonderWagon - '94 Ford Escort LX
Last 3: 51.52 mpg (US)
DaBluOne - '99 Ford Escort SE
90 day: 48.97 mpg (US)
DaRedOne - '99 Ford Escort ZX2 Hot
If you're doubtful about the precision of the mixture (due to small amounts of additive per fill), premix the entire 16 fl. oz. bottle of additive with gas in a 1 gallon gas can that has been marked (with a sharpie) on the side to indicate the 1 gallon/full point. There are 16 cups in a gallon and 16 oz in the bottle, so 1 cup of premix, partial concentrate = 1 oz full concentrate.
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 55 08-20-2012 11:34 PM
How to put 14.6 gal in a 13.2 gal tank! Z28WTW EcoModding Central 18 05-14-2009 07:41 PM
Lower gas in tank = lower gas FE? NoCO2 Hypermiling / EcoDriver's Ed 10 06-09-2008 01:37 AM
Easy 5mpg gain in FE (due to switch to summer gas?) Green Machine General Efficiency Discussion 7 04-24-2008 05:07 AM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
