04-09-2012, 12:24 AM
#71 (permalink)
Pokémoderator
2000mc -
No problem here. I'm just adding the info I have. If you are seeing better MPG without the spoiler, then that's great. Maybe Saturn flipped the values by accident.
CarloSW2
04-09-2012, 08:10 AM
#72 (permalink)
Master Ecomadman
My '98 SC1 had a stock spoiler too, so that can't be the difference. It shows SL1 to have lower drag that SC1 and SL2. The '97 twin cams had wider tires, 185/65R15 vs 175/70R14 so they should have more drag. I would say this is marketing and not fact.
- Tony
04-09-2012, 12:56 PM
#73 (permalink)
herp derp Apprentice
The spoiler was a $245 option according to the window sticker on my car, but I think it was included on all sc2's. I think saturn got the numbers switched around, especially if you throw in the wider tires on the sc2, but I don't know if tires are always figured into drag.
04-09-2012, 01:31 PM
#74 (permalink)
Pokémoderator
2000mc -
Yeah, the published Cd for the SC# has been debated in the past. I'd like to think they got it mixed up too.
CarloSW2
04-11-2012, 08:11 AM
#75 (permalink)
Master Ecomadman
The natural color 1/16 thick HDPE sheet has arrived from Mc Masrter Carr. Very slippery to the touch, and stiffer than the PVC sheet. Probably wont hold paint well. I'll update on the fabrication.
- Tony
04-15-2012, 04:52 PM
#76 (permalink)
So I retested the spoiler today. From today's results it's a wash. Avg mpg 34.87 vs. 34.89, or about .05% difference. Now I was putting the spoiler in the trunk, so if you actually removed it from the vehice you might see larger gains because it weighs maybe 3lbs :P
update 9-8-12 finally decided to take off the spoiler after seeing arcosine's tuft test http://ecomodder.com/forum/showthrea...p-22429-8.html
04-15-2012, 06:09 PM
#77 (permalink)
Pokémoderator
2000mc -
Thanks for the effort! Aero can be sooooooooo frustrating to test. From now on I will claim that Saturn's Cd claims for the different SC# models are suspect.
CarloSW2
04-16-2012, 02:00 AM
#78 (permalink)
Unfortuneately if I assume that my retest is correct, whether the numbers are switched or not, i dont know what else could cause the difference.
06-23-2012, 04:38 PM
#79 (permalink)
Master Ecomadman
I added little fairings in front of the front tires and painted them silver. Theses are big tires, 205/70R15. I'll put similar fairings on the back of the front tires and the front of the back tires too, before putting on the front wheel skirts.
- Tony
The Following 3 Users Say Thank You to arcosine For This Useful Post:
06-23-2012, 06:58 PM
#80 (permalink)
Pokémoderator
arcosine -
Looking good :
CarloSW2
The Following User Says Thank You to cfg83 For This Useful Post:
