Old 02-25-2009, 10:45 PM   #1 (permalink)
cheap yet balla
buster - '97 JEEP Grand Cherokee LTD
Send a message via AIM to energy0uth
ScanGauge worth it?
I have a stock unit that tells me MPG and average, etc. but with past experiences I feel the ScanGauge will still be worth it...
opinions?
Old 02-25-2009, 10:48 PM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Probably,
Old 02-25-2009, 11:21 PM   #3 (permalink)
I bought one for the other stuff, for example my vehicle doesn't have a stock trans temp. gauge and I use the vehicle brutally, in Arizona (yes, I have an aftermarket cooler fitted) - as well I enjoy the benefit of being able to check SES light codes, clear them if necessary, and use the assorted gauges to diagnose problems which periodically arise on an aging vehicle.
TBH I hardly use the MPG features.. I drive how I drive and haven't felt the need to correct my habits - I get ~20mpg in a lifted conventional 4x4 on all terrain tires, what more should I expect?
Old 02-27-2009, 10:27 PM   #4 (permalink)
Renaissance Man
Formula413's Avatar
Aegean C - '17 Honda Civic LX
90 day: 39.61 mpg (US)
I love mine because I am an information junky, I love being able to see all the stuff that that the factory gauge cluster doesn't tell you, like TPS, IAT, engine load, exact coolant temperature, etc etc. And having a code reader comes in handy too. TPS and load are very useful for improving your driving technique to increase fuel economy.
Old 02-28-2009, 12:37 PM   #5 (permalink)
I think it's worthwhile just for the temperature functions. I run a radiator block & hot air intake and do most of my driving in mountains, so having an actual readout rather than the useless OEM temperature gauge lets me know when it's time to pull the block out.
The other functions range from interesting (things like battery voltage & engine load) to possibly useful someday (the code reading & clearing), but the fuel consumption ones don't seem to be accurate at all. They'll give sometimes wildly different numbers than the Insight's internal gauges - and those check pretty well with the numbers I got from recording miles & gallons.
Old 02-28-2009, 12:58 PM   #6 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
"Worth it"? Depends on how much of a data nerd you are, and if you're up to the task of diagnosis if anything ever goes wrong with your vehicle. It can be really useful there.
A properly calibrated MPGuino will be more consistently accurate with fuel consumption readings than the SG, based on the different ways they calculate fuel use.
I've used my SG to diagnose a vacuum leak (via MAP readings) that didn't even set off a trouble code.
I'm sure you already know the SG doesn't factor lean burn into its MPG calcs, right? The Guino does, however.
In my opinion, the SG's weak point is its calculations of non-stoich conditions MPG (including open loop during warm-up or strong acceleration).
When I get my $S@^ together, I'll have both the SG and Guino in my vehicle.
Old 03-01-2009, 01:25 PM   #7 (permalink)
I don't really know much about the internals of either, but was under the impression that they apply various algorithms to estimate fuel consumption from the OBDI-accessible info, while the Honda OEM display computes fuel consumption by adding up the amount of fuel the ECU tells the injectors to deliver. A lot more accurate, but hard to do unless you're the one writing the ECU code.
Old 03-01-2009, 02:34 PM   #8 (permalink)
E-Class - '04 MB Mercedes E320 4Matic
Matrix - '09 Toyota Toyota Matrix 2.4L AWD Sports Package
Please allow a little stretching of the subject. This welcoming site and thread looks like the closest place where I can say what I want to say below.
To the OP, I envy you because you already have a stock mpg device on your car, but forgive my technical illiteracy, I am still waiting for the availability of an easy to install, fool proof and calibration free plug and play device that can be used in my Matrix to show me the instant mpg data. It has to be available in the shops, not just on the internet. Impossible to make such a thing? Look at the add-on GPS units that are so widely available. Too bad they don't show mpg numbers directly.
I will arbitrarily deem such a device to be worth of its price if I can recoup the money that I pay for it in five years (about 40,000 kms) through the achievement of better FE (I am currently beating EPA ratings by a few % and believe that I can do better). Having been here for some time, I am already "infected" by everybody's enthusiasm about saving fuel and protecting the environment. However, my lack of a technical background makes me feel like an outcast (time to have a thread or sub-forum designed to attract laymen/beginners). I am sincerely waiting to buy the device that I have described with a ton of patience.
Someone please tell the manufacturers. It should not be difficult to make something like what I want. Many things that looked like a dream yesterday have become reality today. The add-on MP3, blue tooth and GPS units are good examples.
Old 03-01-2009, 10:23 PM   #9 (permalink)
The difference between those and and a mpg unit is that they're stand-alone units which need nothing from the car except a 12-volt power connection.
Old 03-02-2009, 07:50 PM   #10 (permalink)
Driving the TurboWeasel
Yes, the ScanGauge is worth it. I've recouped much cost in gas with it, and have learned to drive much more efficiently.
Granted, I do drive a semi-FSP. The techniques can be transferred to any car.
2012 Chevrolet Cruze Eco 6MT
Scangauge II vs cruise control rjacob Instrumentation 10 06-02-2011 02:36 PM
Dealer says ScanGauge ruined my PCM and I can't use ScanGauge anymore Markmysite EcoModding Central 55 05-06-2010 06:31 AM
Woohoo, this place is worth more than CleanMPG dcb The Lounge 4 10-16-2008 10:24 AM
Scangauge 1 - Some help please! jdubbs_scort Instrumentation 6 06-17-2008 03:26 PM
scangauge coolant temp accuracy? Daox Instrumentation 12 05-03-2008 01:09 PM
