Old 01-28-2014, 06:36 AM   #1 (permalink)
EcoModding Alien Observer
suspectnumber961's Avatar
highcountryexplorer - '86 Nissan 720 KC 4x4 ST with fiberglass cap
90 day: 21.78 mpg (US)
Elroy - '03 Ford Focus ZX3 w/Zetec DOHC engine
90 day: 32.89 mpg (US)
Should you use E15?
Carry on humans...we are extremely proud of you. ..................
Forty-six percent of Americans believe in the creationist view that God created humans in their present form at one time within the last 10,000 years. GALLUP POLL
Old 01-28-2014, 06:43 AM   #2 (permalink)
90 day: 56.53 mpg (US)
I use hE15 in my 2011 Insight.
If Fox says it's is bad I feel reassured in knowing that is is in fact good.
But Fox is not the only one reporting this:
http://www.usatoday.com/story/news/n...-cars/1735793/
The ethanol industry does not agree as could be expected:
http://ethanolproducer.com/articles/...-irresponsible
Mix in some criticism on the production of ethanol: http://bigstory.ap.org/article/secre...n-power-push-1
So let's take it straight from the horses mouth:
http://newsroom.aaa.com/tag/aaa-e15/
Wait, is that dated November 15th? That's so 2013...
And so are the other items, the Fox item even going back to 2012.
Old news.
The Following 2 Users Say Thank You to RedDevil For This Useful Post:
Cobb (01-28-2014), Frank Lee (01-28-2014)
Old 01-28-2014, 07:09 AM   #3 (permalink)
ecoTex's Avatar
green VX - '95 Honda civic VX
90 day: 59.74 mpg (US)
If your car is is flex-fuel compatable, E15 or even E100 is safe. If it is not, the 10% that is now mandated by the federal government, is damaging it. This stuff is destroying lawnmowers, generators, boats and cars that sit for days at a time.
My adjustable WAI / HAI build thread
http://ecomodder.com/forum/showthrea...tml#post408134
Old 01-28-2014, 07:22 AM   #4 (permalink)
All I can say is that this hE15 blend they sell over here has 0.6% water content to protect against ethanol erosion.
Ethanol in its purest form is very volatile, but just 4% (volume) of water binds it enough to make it behave more like a fluid. As it is quite hard to extract the last bit of water out, they just leave it; reducing the cost of production as a bonus.
While a high percentage of water is detrimental, as you can imagine, matching the ethanol content with 1/25 of water does take the sharp edge off.
My car was approved for E10 (even without water content). I think it'll be fine.
This scare news is old, I'd like to see proof rather than opinions or I won't believe it.
It would have been banned long since if it were that bad.
Old 01-28-2014, 07:41 AM   #5 (permalink)
Wow Tex, you really are a noob.
Faux Noise.
E15- makes no difference to me, unless the price break isn't proportional to E10/E85. I'll keep running E10 or E15 in brutal winter temps, E85 in the heat of summer, and proportional blends inbetween.
BTW- I mistakenly filled the snowblower with E85 and you know what? The darn thing started just fine in the cold! I wasn't expecting that. The only thing I noticed was that I had to be slower opening the choke, and I couldn't open it that last notch. Otherwise it ran perfect.
Old 01-28-2014, 07:47 AM   #6 (permalink)
ecoTex's Avatar
this is page 296 from your owner's manual.
Your car IS designed to run E10. Older cars and small engines are not.
Help assure your vehicle’s future
reliability and performance by paying
extra attention to how you drive
during the first 600 miles (1,000 km).
During this period:
Avoid full-throttle starts and rapid
acceleration.
You should also follow these
recommendations with an
overhauled or exchanged engine, or
when the brakes are replaced.
Your vehicle is designed to operate
on unleaded gasoline with a pump
octane number of 87 or higher. Use
of a lower octane gasoline can cause
a persistent, heavy metallic rapping
noise that can lead to engine damage.
Do not change the oil until the
scheduled maintenance time.
Avoid hard braking for the first
200 miles (300 km).
In addition, in order to maintain good
performance, fuel economy, and
emissions control, we strongly
recommend, in areas where it is
available, the use of gasoline that
does NOT contain manganese-based
fuel additives such as MMT.
We recommend using quality
gasolines containing detergent
additives that help prevent fuel
system and engine deposits.
Use of gasoline with these additives
may adversely affect performance,
and cause the malfunction indicator
lamp on your instrument panel to
come on. If this happens, contact
your authorized dealer for service.
Some gasoline today is blended with
oxygenates such as ethanol or
MTBE. Your vehicle is designed to
operate on oxygenated gasoline
containing up to 10% ethanol by
volume and up to 15%MTBE by
volume.
Do not use gasoline
containing methanol
If you notice any undesirable
operating symptoms, try another
service station or switch to another
brand of gasoline.
For further important fuel-related
information for your vehicle, or
information on gasoline that does not
contain MMT, visit Owner Link at
. In Canada, visit
for additional
information on gasoline.
owners.honda.com
Honda.ca Official Website of Honda Canada Inc.
Break-in Period Fuel Recommendation
Old 01-28-2014, 07:55 AM   #7 (permalink)
I think it would have to sit for more than days to wreck things. Lemme put it this way: I've dumped E85 into almost everything I own, small engines included. I haven't found wreckage that I can attribute to ethanol, and I've been playing with this stuff since the '80s.
The Following 2 Users Say Thank You to Frank Lee For This Useful Post:
Cobb (01-28-2014), Mustang Dave (04-16-2014)
Old 01-28-2014, 07:57 AM   #8 (permalink)
ecoTex's Avatar
Frank,
I didn't say they won't run on it, I said they will incure damage if E-XX is left in the tank. if you run the tank of your snowblower empty after each use, there will probably be no damage.
Take you insults somewhere else. im sure there is a 16 year old girl making her first post in intoductions that you can outwit.
The Following User Says Thank You to ecoTex For This Useful Post:
Cobb (01-28-2014)
Old 01-28-2014, 08:04 AM   #9 (permalink)
Your car IS designed to run E10....
Yes, just as I stated. I have read the manual more than once.
Please do not copy whole pages in your post, that is copyright infringement and bad net etiquette.
Cobb (01-28-2014)
Old 01-28-2014, 08:07 AM   #10 (permalink)
No, I don't run the blower dry each time.
As noted, been running this stuff in various concentrations for decades. Lessee, what are all the bad things that happened...
I had to replace a clear plastic line on an old McCollough to get it going... I don't have the history of the thing though, maybe it was run on E0 it's whole life and the line went bad just from age? Dunno.
I filled the V-Max with straight E-85 once. It didn't like it; had to ride the rest of the way with the choke slightly closed. I generally don't run higher than E10 in carb'd stuff, but I have run a strong blend through a carb'd '76 Chevy pickup and it ran just fine. I wouldn't be surprised, though, if I have to replace hardened rubber fuel lines at some point. I will experiment with E15 in the carb'd stuff to see how it goes.
I pushed the envelope a little too much in my early days of using straight E85... had a tank full of it when it got brutally cold- like today (-26F) - and that car would not start. Yeah, don't use it in the cold.
But this is about WRECKING stuff. I've never replaced a fuel filter or an injector or anything except that McCullough line and our State has had "gasohol" since the late '70s.
RedDevil (01-28-2014)
