Old 04-14-2021, 11:55 AM   #31 (permalink)
That sounds like something that would only happen once.
MetroMPG (04-22-2021)
Old 04-21-2021, 06:29 PM   #32 (permalink)
90 day: 51.82 mpg (US)
Ready! Set! #&÷$€ SNOW !
Originally Posted by nemo View Post
And now some snow for testing purposes.
Well +@&€!! You jinxed me!
That's today's snow. Not quite enough for a test drive, though.
But I did finish it up: patched the squirrel chew holes on the tank top & cap with a bit of bondo, (visible in the above pic).
She's ready to go for next winter, I guess!
Name:	2021-04-21 18.26.22.jpg
Old 04-22-2021, 08:42 AM   #33 (permalink)
nemo's Avatar
Chief - '06 Pontiac Grand Prix
90 day: 26.7 mpg (US)
SF1 - '12 Ford Fiesta S
90 day: 30.95 mpg (US)
Bondo is ethanol resistant? Probably only need to half fill the tank anyway. If you haven't drained it you should add some Stabil.
The Following User Says Thank You to nemo For This Useful Post:
Old 04-22-2021, 08:54 AM   #34 (permalink)
Not sure about ethanol... but I won't be using ethanol fuel in this tank.
Bondo is resistant to fuel, but only after it is cured
As you point out, the patches I made won't ever be submerged in gas, but they will likely get splashed.
I figure "resistant" is good enough for that use. It's not a critical leak repair.
If it peels off, I will report back.
Tank & carb float bowl have been drained until next winter.
Old 04-22-2021, 09:42 AM   #35 (permalink)
last thing...
The final thing left to do is have a look at the drive belts. They're probably as old & crusty as the tires.
But instead, I will probably just go with the "ignorance is bliss" approach until one breaks in the middle of a blizzard.
Gasoline Fumes (04-22-2021)
Old 04-22-2021, 10:20 AM   #36 (permalink)
We used bondo and screen mesh for fuel tank repain back in the day when I was driving gas vehicles.
At least get replacement belts. Belt will self destruct in the middle of the biggest event.
Old 04-22-2021, 10:23 AM   #37 (permalink)
Darn you and your reasonable advice.
Old 04-22-2021, 10:33 AM   #38 (permalink)
Do as you wish. I am just an adherent of Brother Murphy.
