04-14-2021, 12:55 PM
#31 (permalink)
That sounds like something that would only happen once.
04-21-2021, 07:29 PM
#32 (permalink)
Ready! Set! #&÷$€ SNOW !
Originally Posted by nemo
And now some snow for testing purposes.
Well +@&€!! You jinxed me!
That's today's snow. Not quite enough for a test drive, though.
But I did finish it up: patched the squirrel chew holes on the tank top & cap with a bit of bondo, (visible in the above pic).
She's ready to go for next winter, I guess!
04-22-2021, 09:42 AM
#33 (permalink)
Chief - '06 Pontiac Grand Prix 90 day: 26.7 mpg (US) SF1 - '12 Ford Fiesta S 90 day: 30.95 mpg (US)
Bondo is ethanol resistant? Probably only need to half fill the tank anyway. If you haven't drained it you should add some Stabil.
The Following User Says Thank You to nemo For This Useful Post:
04-22-2021, 09:54 AM
#34 (permalink)
Not sure about ethanol... but I won't be using ethanol fuel in this tank.
As you point out, the patches I made won't ever be submerged in gas, but they will likely get splashed.
I figure "resistant" is good enough for that use. It's not a critical leak repair.
If it peels off, I will report back.
Tank & carb float bowl have been drained until next winter.
04-22-2021, 10:42 AM
#35 (permalink)
last thing...
The final thing left to do is have a look at the drive belts. They're probably as old & crusty as the tires.
But instead, I will probably just go with the "ignorance is bliss" approach until one breaks in the middle of a blizzard.
04-22-2021, 11:20 AM
#36 (permalink)
We used bondo and screen mesh for fuel tank repain back in the day when I was driving gas vehicles.
At least get replacement belts. Belt will self destruct in the middle of the biggest event.
04-22-2021, 11:23 AM
#37 (permalink)
Darn you and your reasonable advice.
04-22-2021, 11:33 AM
#38 (permalink)
Do as you wish. I am just an adherent of Brother Murphy.
