Old 09-24-2018, 11:36 PM   #51 (permalink)
Here is my test gear:
Name:	All Donewdetails.jpg
ID:	24912   Click image for larger version
Old 09-24-2018, 11:38 PM   #52 (permalink)
Later when I gave up most MPG testing I fixed the car up:
ID:	24914   Click image for larger version
Name:	Center Console.jpg
ID:	24915   Click image for larger version
Name:	Cluster White.jpg
ID:	24916   Click image for larger version
ID:	24917   Click image for larger version
Old 09-24-2018, 11:40 PM   #53 (permalink)
I have problems with the engine SO I am planing on a engine/transmission and FRAME swap from a 2000 to a 2004 drive line with a full frame swap.
Old 09-25-2018, 12:43 AM   #54 (permalink)
...from earlier today.
I think I will need pictures of most of these ideas.
The search field is in the upper right. I apologize for being lazy.
  • diverter...stagnation point
  • air curtains...spats.
  • Aerocivic
  • fender skirts...TurnpikeCruiser
  • fiberglass...the proper curve.
You've already got vortex generators on the back. Aren't they working? See Gurney flap. Since you went thumbs down on the boat tail, I'll include a picture for that.
The proportions would change for your vehicle. It could have a piano hinge at 18-24" and dispense with the 'stinger' that stores over the roof in this instance.
It might have a vertical hinge at one end of the bumper and a retractable leg with a caster wheel on the other.
Here's another thing:
Which topper has the lowest Cd?
The slick-top is 0.44, The bubble-top is 0.40 because of the arched profile. The area is larger, of course. You'd need only do the back half. Those divots in the front are facing onrushing air. "It isn't how big a hole you make, it's how big a hole you leave."
Two wrongs don't make a right, but three lefts do.
Old 09-25-2018, 02:00 AM   #55 (permalink)
Interesting, my van is closes to #4 the dark blue and white van in profile.
ID:	24920   Click image for larger version
ID:	24921   Click image for larger version
Old 09-25-2018, 02:03 AM   #56 (permalink)
Note she rises in front and tapers down in back and has a rounded shape. The roof rack is side rails only no cross rails at all.
I also replace the window doors with solid doors.
Rich
Old 09-25-2018, 08:30 AM   #57 (permalink)
Originally Posted by racprops View Post
I was going to use the factory unit...
Make it a piggy back set up.
Rich
To my knowledge no one has done that yet. Even the 6 speed controllers that are out there need to be paired with a stock type engine controller so it can talk back and forth. And the 8 speed is much more sophisticated in how it controls the engine torque through a shift. The Chevrolet Perfomance crate 8 speed transmissions can only be used behind a crate LT1 or LT4 engine.
Old 09-25-2018, 08:37 AM   #58 (permalink)
IGL - '04 Saturn Ion
Team Saturn
90 day: 56.19 mpg (US)
I’m absence of being able to use the 8L90 trans, why not try and swap an NV4500? Or if you wanted to be spendy, you could find a T-56 with the 0.50 OD...
My current Ecotec project...
My last Ecotec project...
Old 09-25-2018, 09:09 AM   #59 (permalink)
That is my plan, pair it with my older OBDI PCM sharing most sensors.
I note you say "The Chevrolet Performance crate 8 speed transmissions" so is there a non performance version??
Can you share more information on these Transmissions??
Rich
Old 09-25-2018, 09:25 AM   #60 (permalink)
Looked it over and what a beast....
Again I will stay with a auto...
I have also considered the 6L80....
Name:	6L80E 2.39 rearend.jpg
