Old 10-23-2013, 02:30 PM   #221 (permalink)
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Ugh... did I actually type "L/100km"? That really should be "100km/L".
*headdesk*
The Following User Says Thank You to t vago For This Useful Post:
josemapiro (10-24-2013)
Old 10-23-2013, 02:53 PM   #222 (permalink)
90 day: 49.1 mpg (US)
Hi t vago,
100 km/l is not commonly used in metric fuel efficiency, just km/l or indeed l/100km.
Because then in most situations you'd get one or 2 digits before the decimal point.
In your example it would be 3.968 km/l or 25.2 l/100 km.
My car does about 3.968 l/100 km or 25.2 km/l btw
t vago (10-25-2013)
Old 10-24-2013, 04:19 PM   #223 (permalink)
*headdesk*
Ok,
Thank you
José Rodrigues
Old 10-25-2013, 02:41 PM   #224 (permalink)
One question, when MPGuino goes to the clock display due to downtime, to click the button left or right goes to "Current Reset" is normal or is an error?
Thank you
José Rodrigues
Old 10-25-2013, 05:13 PM   #225 (permalink)
MPGuino Supporter
t vago's Avatar
Thank you
José Rodrigues
Yah, it's normal. Anything, that wakes up the MPGuino, will reset the current trip data. It could be any single button press (or pressing any combination of buttons), or it could be a VSS pulse, or it could be a valid injector pulse.
I am wondering if this particular behavior should be changed - button presses, by themselves, would not necessarily reset the current trip if the MPGuino were to be woken up, but reading a VSS pulse or a valid injector pulse would still do so.
josemapiro (10-26-2013)
Old 10-26-2013, 03:18 AM   #226 (permalink)
I think the best would be to reset by pressing the button for 1 second, because there is always the possibility to query all data from the last trip.
If the data is restarted due to the injector pulses, this means that we will make another trip, which is correct, the rest I believe it should only be done if we wish so.
Or create a possibility to choose in the setup menu.
Thank you
José Rodrigues
The Following User Says Thank You to josemapiro For This Useful Post:
t vago (10-27-2013)
Old 10-26-2013, 01:48 PM   #227 (permalink)
I commented out the auto-reset behavior so that a current trip can span multiple stops.
I wouldn't be opposed to an auto trip reset #define, but I'm fine with how it is currently.
The Following User Says Thank You to Ardent For This Useful Post:
t vago (10-27-2013)
Old 10-27-2013, 04:44 PM   #228 (permalink)
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
I'm back home from my round trip. So I've drove for around 4300km testing new code. It works very good and stable, haven't noticed any issues. After first calibration it shows FE with amazing accuracy. Error on second tank was around 0.1%
Anyway I have some thoughts on new code.
One thing would be good - L/hr display or changing display from L/100km to L/hr during stops.
Graphs are nifty but not very useful.
I want to try to change code a bit to read engine's temp instead of pressures.
Overall I like new code very much. Great job t_vago! Thanks again
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
The Following User Says Thank You to AndrzejM For This Useful Post:
t vago (10-27-2013)
Old 10-27-2013, 11:39 PM   #229 (permalink)
MPGuino Supporter
t vago's Avatar
...create a possibility to choose in the setup menu.
This is probably the route I will go with. I wanted to maintain the behavior of the original code, as best I could. Then again, I modified the dickens out of this same code, so there.
Look for an update in the next few days.
I can also do that. I already used #defines to turn on/off the idle/EOC tracking feature, so this is really easy to do.
The code already can display L/hr... but alternating between L/hr and L/100km is an interesting idea. Or did you mean a big numbered L/hr display?
The graphs were more of a visual aid to see if a modification (aero mod or engine mod or driving style change) changed anything. The DifFE/time might be generally useful - that ScanGauge E has one, so I figured that MPGuino should also have one.
Engine temperature reading might be tricky, especially if you're just reading the voltage going from the existing ECT sensor to the existing ECM. They sometimes will use two different circuits to supply current to the ECT sensor, depending on engine temperature and internal logic. The low temperature circuit will drive the sensor with a lower current, and the high temperature circuit will use higher current. This is to prevent overdriving the ECT sensor and heating it up at low engine temperatures, while providing accurate ECT readings when the engine is warmed up.
This graph, supposedly for a 1995 Cadillac De Ville, shows a graph of voltage vs engine coolant temperature - note how the voltage changes at 50 C.
Thank you! I'm just glad to help.
Old 10-28-2013, 05:05 AM   #230 (permalink)
AndrzejM's Avatar
Haven't found that. Maybe that's because still don't know how exactly setup my custom screen.
I wasn't thinking of big numbered display for L/hr, that's not necessary I think. I was thinking of alternating instant FE display values from l/100km to l/hr when car is not moving. Then you can both see FE when car is moving and engine load when it's idling. It's good for modders to know that value when changing A/C, alternator or PS setup to limit engine load. I was using that with previous code, to see how engine load is changing when for example I'll turn the headlights on or blower.
Yes you're right DifFE/time is the most useful graph and I was driving with it for a while.
Berta has double sensor setup. One is working for ECU purposes and I don't want to mess up with that. Second one is working with temp gauge and I want to hook up this circuit. I've checked Voltage/temp characteristics some time ago of this circuit and all I need is to change the code to get proper readings. I have everything hooked up to my MPGuino already.
