View Poll Results: Is it worth it to drill the underbody for a MPG belly pan? Or not worth it with rust?
Worth it 10 50.00%
Not worth it 10 50.00%
Voters: 20. You may not vote on this poll
Old 11-02-2012, 08:24 PM   #11 (permalink)
The Dirty330 Modder
Gealii's Avatar
CruzeRS - '15 Chevy Cruze LT RS
90 day: 41.29 mpg (US)
i guess im a dam yankee even though i'd love to be in northern texas
"The only real mistake is the one from which we learn nothing."
- Henry Ford
Old 11-02-2012, 09:44 PM   #12 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
Come on down Gealii, plenty of room!
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 11-03-2012, 01:09 AM   #13 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
If you don't want to drill parts of your car to mount the panels, consider bending up some copper tubing into clamps, then you can clamp the panels to the rocker pinch-points under the car. I believe MetroMPG did just this for another project, although probably slightly different.
If he doesn't reply here, try msging him about his "home made clamps". I dont' even remember what he did it on... it's been probably 2 years now.
Old 11-03-2012, 01:12 AM   #14 (permalink)
You can also use body bond (aircraft glue) to glue screw retainers to the underside of the car. They will not come back off without damaging the paint and possibly denting the metal, though.
Tee nuts facing the wrong way, glue the flat side to the body of the car, drill the coroplast to go over the sleeve of the tee nut, add a screw and washer to hold it in place. May be a good idea to glue some butyl gasket material to the side going against the car to keep it from vibrating.
Old 11-03-2012, 06:37 AM   #15 (permalink)
The Dirty330 Modder
Gealii's Avatar
when i finish college i plan on getting out of the rust belt either way and staying away from the ocean
- Henry Ford
The Following User Says Thank You to Gealii For This Useful Post:
Christ (11-03-2012)
Old 11-05-2012, 06:22 AM   #16 (permalink)
Hmm, thanks for all the ideas folks but for now I'm going to hold off on the project. Where I live it rains all the time and I plan on keeping my Civic forever. On some thread on here someone with a Civic used the bottom skirts, putting the choroplast in between the car body and the bottom skirts, running the screws through. But still I think he had to make bolt holes for the front and back points.
1 thing you have to think about with full underbody pans that cover the engine bay. This can be a fire hazard in case your engine, tranny or power steering leaks oil. The fluid could build up instead of going on the pavement. There was some recall, maybe Ford Escapes where there wasn't enough (or any) holes for fluid to escape.
Old 11-05-2012, 08:18 AM   #17 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
A full length "splash shield" will do wonders for underbody protection.
Transmission type Efficiency
Old 11-05-2012, 04:53 PM   #18 (permalink)
Vehicle Maintenance.
It's really not hard to make sure your vehicle isn't leaking fluids, and you should be doing that as a part of driving anyway.
Old 11-05-2012, 07:02 PM   #19 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
then I must be a frozen _ _ _ Yankee D)
drill the holes, then caulk, tar, paint or seal them in your preferred manner.
Or use epoxy to to stick a (also coated with epoxy) wooden block to the underside then screw into that.
The Following User Says Thank You to Weather Spotter For This Useful Post:
mcrews (11-05-2012)
Old 11-05-2012, 07:29 PM   #20 (permalink)
mcrews's Avatar
I may not be following this logic.
Ford recalled Escapes not because they leaked too much.......BUT because the oil couldnt reach the ground!!!??????????
I have had several cars that leaked. I would spend the $1.50 a month to clean the engine compartment at the car wash.
And it is very easy to design a pan the would allow the fluid to drain.
ECO MODS PERFORMED:
First: ScangaugeII
