Old 06-25-2014, 04:22 PM   #21 (permalink)
Cool
Is that all the same piece of vacuum hose or are you redoing your plumbing under the hood?
Old 06-25-2014, 04:27 PM   #22 (permalink)
dlb
that is a sharp looking mounting job. very nice.
what is your vacuum at idle after fixing the kink in the vac line? on an engine in good condition, it should be 18-21".
here's a great reference on how to use a vacuum gauge to diagnose a variety of engine issues. scroll down to the bottom for a great little graphic.
How to Use and Interpret a Vacuum Gauge
by t-ing into the vac line for the brake booster, do you find applying the brakes has much effect on the readings? for future reference, you can splice into any vac hose coming off the intake plenum but i prefer not to use the hoses associated with the brake booster, fuel return diaphragm, or PCV systems. that leaves hoses going to stuff like sensors, EGR, etc. alternatively and ideally, some engines have unused ports on the intake plenum or manifold that are capped at the factory. pull the plastic or rubber cap off and attach the hose to that port.
i've been driving with a vac gauge for a few months now and have managed to increase my mileage by an average of 10% so i'm a big believer in them.
Old 06-25-2014, 04:30 PM   #23 (permalink)
I would suspect the vacuum would be slightly lower on a VX since the idle speed is a good bit lower than the average, around 550 RPM. The length of hose was enough to make sure it would cover the distance and routing involved.
My 37 Ford idled at 350 RPM. You checked it by letting it idle in top gear and it was supposed to be 7 MPH!
regards
Mech
Old 06-25-2014, 07:26 PM   #24 (permalink)
DOFZO's Avatar
SLOMOTO - '92 Honda Civic VX
90 day: 56.49 mpg (US)
I'll eventually get it cut to length. For now I'm going to need every inch if I keep crimping the hose installing the gauge!
I'm located in Denver, so 16 in. hg. is pretty good negative pressure. Although the car is in great condition for it age, the suspension and brakes need work. I've pressed all new bushings into every suspension component* and I'm going to convert to rear disc at the same time. I will then do new rotors and pads, springs and struts all the way around.
So to answer your question, no, I haven't felt a difference with braking, but my brakes are VERY well worn. I just took her around the block and maybe up to 30 mph.
Without a vacuum leak within the booster line or my tap I don't understand why anything would change anyway. I'll monitor it though.
*I've sourced front lower control arms from a GS-R, rear lower control arms from a LS, front anti-sway bar from the LS and rear anti-sway from a Type-R , and Del Sol Si rear trailing arms for the rear disc conversion. New upper front control arms, rotors and pads. Koni STR.T struts with H&R springs. This is my plan for the suspension rebuild/conversion. Hopefully I find the time to start the project, I have all the parts.
ZO.
Big Oil hates lean-burn.
Originally Posted by cowmeat View Post
If my hypermiling in the Insight cancels out the effects of just one gap toothed git-er-done in his big dumb F250 dually with his inbred kids and pitbull hanging off the side rails in the back, glaring at me as they roll coal around me . . . . . then maybe there will be some gas left when my grand kids start to drive.
Old 06-25-2014, 08:43 PM   #25 (permalink)
Thats ok, helps add to your vacuum reserve. Gauge looks professional.
Old 06-26-2014, 01:35 PM   #26 (permalink)
dlb
i don't think you would feel a difference in braking due to the gauge being run off the brake booster hose. what i wonder is if applying the brakes will cause the gauge to read slightly lower at those moments due to the brake booster diaphragm using most of the vacuum supplied to it. i'm not sure if it would show up or not, just curious.
Old 06-27-2014, 12:15 AM   #27 (permalink)
DOFZO's Avatar
Thanks!
Interesting! I hadn't even thought of that. Once I get to driving the car regularly I'll report the results back.
ZO.
Old 08-03-2014, 09:51 PM   #28 (permalink)
DOFZO's Avatar
The vacuum drops (rises, moves towards zero) as I apply the brakes.
I'm getting 19 in. Hg. at idle. That reading doesn't make any sense to me. I personally haven't checked the ignition timing, but I asked and paid to have it done at a dealership just after I completed the install.
ZO.
Old 08-04-2014, 01:01 AM   #29 (permalink)
Wanting more for less
D.O.G.'s Avatar
Metric - '94 Honda Magna 250
Motorcycle
90 day: 69.83 mpg (US)
RedCelica - '94 Toyota Celica ZR
90 day: 35.97 mpg (US)
i30 - '12 Hyundai i30 Elite
90 day: 39.84 mpg (US)
i30-22 - '12 Hyundai i30 Elite
90 day: 39.22 mpg (US)
ZO.
I tried a couple of different locations before finding a "stable" one. The first ones I tried gave a big jump as whatever was being supplied vacuum by that line turned on or off.
I tap into the fuel regulator vacuum line now.
I get around 18 in.Hg at idle in my 1.8 litre Mazda.
Every car I've used a vacuum gauge on has given different readings.
Old 08-04-2014, 05:28 PM   #30 (permalink)
Eco Storm Chaser
Stacygifford's Avatar
Nemo - '87 Ford Mustang GT
90 day: 27.26 mpg (US)
K-sight - '02 Honda Insight
90 day: 39.24 mpg (US)
You could tap into hose 18, or 19 on the earlier diagram to get rid of the pressure fluctuations.
I used 18 on my 91 civic and 19 on my 94
looks awesome btw
