Old 09-26-2017, 09:13 PM   #61 (permalink)
Cooling the air has always been my goal.
Old 09-26-2017, 10:45 PM   #62 (permalink)
the green machine :P - '97 Jeep Grand Cherokee ZJ
90 day: 20.92 mpg (US)
Thee s10 - '00 Chevy S10
90 day: 24.27 mpg (US)
Freedom - '05 Kawasaki Ninja 250EX
90 day: 75.55 mpg (US)
LE Focus - '05 Ford Focus
I've always wondered if you could get something like this to replace the intercooler in a diesel truck giving it quicker response from spool up?!?
Old 09-26-2017, 11:48 PM   #63 (permalink)
Even though it's possible to use water injection as a replacement for a conventional intercooler, that's not exactly the best approach.
Old 09-27-2017, 07:55 AM   #64 (permalink)
Also, so that you don't have to waste money on a pump that just takes power from the alternator, take a 4 inch pipe that will hold the amount of water you need(or 6 inch if you need to!) and pressurise the system with compressed air. If you only need around 50-60psi then having a 5-10 gallon storage tank should be more then enough!!
Old 09-27-2017, 10:12 AM   #65 (permalink)
We think alike. I don't have an on board compressor yet, but always planned for one. The water to air intercooler I have planned is less than 20% the volume of the stock ic with all its piping. That should dramatically decrease spoolup time.
Old 09-27-2017, 10:15 AM   #66 (permalink)
teoman's Avatar
A3 - '12 Audi A3
You could use a much smaller reservoir and one of those tire inflation pumps. If you have to inflate your tires, you will have it ready.
I had thought about the same thing before. I have some scuba equipment and they would nicely pressurize the water.
Old 09-27-2017, 12:33 PM   #67 (permalink)
I once tried a tire inflation pump.
A bike pump is faster.
Old 09-27-2017, 04:29 PM   #68 (permalink)
Maybe supplying some air from the turbocharger's wastegate valve?
Old 09-27-2017, 06:10 PM   #69 (permalink)
ar5boosted's Avatar
If we go back to straight water injection for a minute and let the combustion temp create the steam. How much pressure would you need for good atomization? Would 100 psi wih a decent nozzle do the job?
I have been working again on my system. I made up an aluminium frame this time and am trying to get the design a bit organised.
A 100psi pump is what I used.
I think it would send too much water if it is unrestricted - depends how fast you are driving though. You will need to add some valves to restrict flow.
I will add the electronics and cover on but that's roughly what I did for the pump and nozzle side.
2003 Renault Scenic - 30% more power with no loss in fuel economy.
1991 Toyota GT4 - more economical before ST215W engine-swap.
previous: Water-Injected Mitsubishi ~33% improved.
future - probably a Prius
Old 09-27-2017, 08:09 PM   #70 (permalink)
I was also wondering if I'd risk hurting something if I put two injectors in the intake for water wired inline with the actual fuel injectors at opposite firing points, or would I run the risk of blowing something??
