Old 01-30-2015, 07:17 PM   #11 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
I run 55-60 PSI on 44 PSI tires. Some tires handle it better than others. What are the roads like in South Africa?
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
The Following User Says Thank You to Gasoline Fumes For This Useful Post:
Eddie25 (02-01-2015)
Old 01-30-2015, 07:22 PM   #12 (permalink)
Master Ecomadman
arcosine's Avatar
sc1 - '98 saturn sc1
Team Saturn
90 day: 43.17 mpg (US)
rans - '97 rans tailwind
90 day: 28.25 mpg (US)
red bug - '00 VW beetle TDI
big tractor - '66 ford 3400
90 day: 58.42 mpg (US)
RV - '88 Winnebago LeSharo
90 day: 16.67 mpg (US)
Between 80 and 120 psi, depending on which bike I ride, 60 psi for the studded snows. Car tires I run around 44 psi.
- Tony
The Following User Says Thank You to arcosine For This Useful Post:
Old 01-30-2015, 11:19 PM   #13 (permalink)
After 50 psi the gains are minimal, I run 40 in all but my XFE 50+ works for me.
The Following User Says Thank You to roosterk0031 For This Useful Post:
Old 01-31-2015, 12:53 AM   #14 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
44psi tires that i keep about 60psi when warmed-up and hopefully not less than 54psi when cold. But your tires and your road conditions matter a lot for what you should do for comfort and safety.
Old 01-31-2015, 01:00 AM   #15 (permalink)
Beating EPA Unmodded
Blue Eagle - '10 Honda Civic LX
90 day: 31.12 mpg (US)
Between 40 and 44 PSI. Would go higher, but some of the roads here are extremely crappy, plus I have passengers that like a little smoother ride. If tire pressure wasn't an issue in getting good FE, then I'd be running 36, which seems to be optimal for comfort, grippiness, and maybe wear (not much, just a little).
The Following User Says Thank You to awcook For This Useful Post:
Old 01-31-2015, 06:09 AM   #16 (permalink)
Tire Geek
CapriRacer's Avatar
Originally Posted by Eddie25 View Post
im currently running 35psi. but my tyre max press is 51psi. what is the highest I can safely run it........
There have been long and acrimonious debates about tire pressure. The problem is where is the line between safe and unsafe.
Your starting point in all this would be the vehicle tire placard, which is usually located on the driver's doorframe, but sometimes is in the glovebox, on the fuel filler door or in the trunk (boot). The tire placard will list the original tire size and the vehicle manufacturer's specification for that size.
The further you go from that value, the greater the risk. Risk of what? Traction issues, wear issues, rough ride, etc.
As a tire engineer, I don't recommend using more than 5 psi more than what is listed on the vehicle tire placard, but others have different opinions.
CapriRacer
Visit my website: www.BarrysTireTech.com
New Content every month!
The Following User Says Thank You to CapriRacer For This Useful Post:
Old 01-31-2015, 11:15 AM   #17 (permalink)
Liberty Lover
j12piprius's Avatar
pris prius - '12 Toyota plug in prius
90 day: 71.09 mpg (US)
52 psi
My tires are 52 psi on 44 rated tires, and I like the ride better.
The Following User Says Thank You to j12piprius For This Useful Post:
Old 01-31-2015, 04:20 PM   #18 (permalink)
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 42.77 mpg (US)
I run 50 PSI in tires rated for 47 PSI. I suspect that I'd get slightly better traction on snow if I dropped the pressure in winter, but the traction I get is good enough.
The Following User Says Thank You to JRMichler For This Useful Post:
Old 02-01-2015, 04:58 AM   #19 (permalink)
Eddie25's Avatar
Fiesta - '06 Ford Fiesta 1.4 Ambiante
90 day: 45.9 mpg (US)
Dakar - '03 BMW f650 GS Dakar (retired)
Tucson - '07 Hyundai Tucson 2.0 GLS
90 day: 32.67 mpg (US)
Thanks guys so many inputs and opinions. However I need a new tyre first just found the biggest gash in one of the side walls. Highway roads here are fine however they have recently been re surfaced with a very course layers of tar that is quite noisy. I will go up in increments but the car is fairly new so it has alot more sound dentining than older cars.
Old 02-01-2015, 10:57 AM   #20 (permalink)
Liberty Lover
j12piprius's Avatar
noise
Maybe the noise is due to larger open spaces on the underside.
