Old 09-15-2011, 06:17 PM   #1 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
Why do a grill block when you could put excess air to good use?
Stick one of these in front of or behind your grill and you will get the same effect as a partial grill block and some energy back to boot.
BPE14 TURBO STAND-BY ALTERNATOR from Aircraft Spruce
Sounds like a good idea but would it be really?
Old 09-15-2011, 06:38 PM   #2 (permalink)
CigaR007's Avatar
GreenTurtle (Retired) - '01 Toyota Echo Sedan
90 day: 44.85 mpg (US)
Zulu - '14 Honda CR-Z
90 day: 49.05 mpg (US)
As per the specs, it only outputs 6 amps @ 85 mph; not a great speed for hypermiling, not to mention the probable increase in drag upfront.
Old 09-15-2011, 06:46 PM   #3 (permalink)
Black Knight - '94 Toyota Corolla
90 day: 58.53 mpg (US)
because its $800.
Old 09-15-2011, 07:14 PM   #4 (permalink)
Mostly because you want the car to go through the air as easily as possible. If its spinning a turbine, no matter if its in a grill or strapped to the top of the car its still spinning that air blender up.
Old 09-15-2011, 09:29 PM   #5 (permalink)
Aerodynamics are one thing, but the reason most of us in Northern climates use a grille block is to have the engine warm up faster in sub-freezing temps.
Old 09-16-2011, 12:19 AM   #6 (permalink)
DieselMiser
ConnClark's Avatar
If it is in the grill and spinning the turbine it is creating resistance to the flow through the grill, just the same as a grill block. This forces more air around the car and thus helping it cut through the air more cleanly.
Old 09-16-2011, 12:36 AM   #7 (permalink)
There ain't no free lunch and it takes more power to spin that thing. Grill blocks BLOCK the internal flow; this does not.
Old 09-16-2011, 01:21 AM   #8 (permalink)
HighMPG's Avatar
Super Duty - '12 Ford F250 Super Duty XLT Long Bed Super-Cab
90 day: 15.29 mpg (US)
Hey, I got one of those on my plane!
Good Bye Insight Hello 6.7 Diesel Truck!
**My First Hybrid Insight**
Old 09-16-2011, 12:48 PM   #9 (permalink)
DieselMiser
ConnClark's Avatar
A 100% grill block blocks internal flow. A partial grill block impedes it. The turbine will impede it as well. Its not a free lunch. Its taking a bite out food you have already paid for before it rots.
Old 09-16-2011, 05:27 PM   #10 (permalink)
tortoise's Avatar
number 9 - '89 Geo Metro LSi
90 day: 49.25 mpg (US)
A grill block giving the same reduction of internal flow as the turbine will reduce power required more than the turbine would have produced. Unless the turbine is greater than 100% efficient. Give up on this one.
