Old 09-16-2011, 05:43 PM   #11 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
The device adds more drag to the car than the power it makes. Much like a classmate of mine who designed an electric car with giant wind turbines on the back to supplement battery power. Neat idea, not applicable to our universe.
Old 09-16-2011, 06:04 PM   #12 (permalink)
HighMPG's Avatar
Super Duty - '12 Ford F250 Super Duty XLT Long Bed Super-Cab
90 day: 15.29 mpg (US)
Why not just add some solar panels on the roof.
Good Bye Insight Hello 6.7 Diesel Truck!
**My First Hybrid Insight**
Old 09-16-2011, 07:05 PM   #13 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
Originally Posted by tortoise View Post
A grill block giving the same reduction of internal flow as the turbine will reduce power required more than the turbine would have produced. Unless the turbine is greater than 100% efficient. Give up on this one.
If the drag reduction is due to reduction of internal flow then any form of blockage inside the internal flow intake that reduces the flow the same amount will reduce the drag the same amount. The case is we have a required mass of air that must flow internally to cool the engine. The dynamic pressure of the air is not needed for the cooling. So if we convert some of that dynamic pressure into energy we are not preventing it from cooling the engine. Turbine efficiency never enters the equation. The argument that since your generating something its going to create more drag due to thermodynamics doesn't apply here. Your just utilizing a resource more effectively.
If you don't buy that in the 80's nasa put wing tip turbines on a piper aircraft and showed you could generate electricity while reducing drag.
Old 09-16-2011, 07:15 PM   #14 (permalink)
90 day: 19.36 mpg (US)
At what cruise speed? (All in all I like the thread, thanks).
Old 09-16-2011, 07:16 PM   #15 (permalink)
CigaR007's Avatar
GreenTurtle (Retired) - '01 Toyota Echo Sedan
90 day: 44.85 mpg (US)
Zulu - '14 Honda CR-Z
90 day: 49.05 mpg (US)
Aren't there vortices being generated on wing tips (due to lift) ? If so, it would beneficial to tap into that unused energy for power generation. A very precise application, in my opinion, which would be hard to mimic on a car.
Old 09-16-2011, 07:19 PM   #16 (permalink)
HighMPG's Avatar
faster then a car can go usually.lol
I am only kidding and I thought of this before also, just invent a better one that creates less drag and has very low inertia like 3" in diameter for a car but I like solar panels better and it's better use of the cars roof and it works even when you aren't moving. + for hybrid cars.
Old 09-16-2011, 07:25 PM   #17 (permalink)
DieselMiser
ConnClark's Avatar
If I remember correctly when I read a report on it a few years ago it was something like 140 knots. But they did say that this test was by no means optimized, it was just the cheapest way to prove the concept. I'm sure it would work at lower speeds too.
Actually most cars generate a pair of vortices from the c pillar
see page 9 here
http://www.grandmarq.net/blaze/Blaze...of%20Autos.pdf
The Following User Says Thank You to ConnClark For This Useful Post:
gone-ot (09-18-2011)
Old 09-16-2011, 10:01 PM   #18 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
I can't find it right now, but the last time someone asked this question I found a calculator on the energy that you can get out of the wind at a given speed and for 55mph I think you could get about 200 watts out of a turbine that was about 2 feet across, so how do they get around 100 watts out of a little 6" turbine? they are going over 85mph! just like it's going to take signifagently more energy to go 85mph, you can also get more energy out of the wind when you are going that speed! just like you can get 3/4 more out of a 12mph wind then you can out of 11mph wind.
So a turbine like that might be able to run your LED running lights, but not much else unless you are going above the speed limit.
The Following User Says Thank You to Ryland For This Useful Post:
mcrews (09-26-2011)
Old 09-16-2011, 11:47 PM   #19 (permalink)
The "perpetual motion" thing pops up with some regularity.
Sure there is already internal drag through the engine compartment. I think a prop driven device would only add to it.
The Following 3 Users Say Thank You to Frank Lee For This Useful Post:
mcrews (09-26-2011), NeilBlanchard (09-17-2011), Sven7 (09-17-2011)
Old 09-18-2011, 05:28 PM   #20 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
The basic squarish wingtip design of the day created vortices and was so inefficient that the wingtip pods bettered it so much, it still reduced drag despite the turbines.
Wingtip Vortex Turbine Investigation for Vortex Energy Recovery
The inefficiency was already built into the baseline vehicle.
This experiment won back some of that energy.
It's better to avoid the inefficiency to start with, rather than try to recover some of the wasted energy later.
