01-05-2019, 05:48 PM
#21 (permalink)
Originally Posted by pete c
Seems to me that anything past 6-7 gears is a waste. Maybe in a diesel truck where you have large loads and a limited rev range.
I agree for the Car, 6 fits it to a T.
The Van I feel I need the extra gears so I can maintain the best speeds under all cases.
Rich
01-05-2019, 11:30 PM
#22 (permalink)
Originally Posted by racprops
OK So what is the MPG??
I actually forgot to ask him about the MPG, as we were more entertained talking about how bad it was the presidential decree that has forbidden Diesel engines below 4-litre in Bolivia...
01-06-2019, 11:48 AM
#23 (permalink)
Od gearing Consumers power as it is the nature of the Beast. The largest percentage of actual flywheel horsepower gets through the transmission at 1: 1.
I'm considering a over-geared rear end and running my aftermarket overdrive box as an underdrive for Bonneville and at the top end going 1 to 1 through the add-on gearbox to reduce the power consumption of the gearing giving me more power available at the top end we're more power is needed due to the added air resistance. However this will require rear gearing close to 1.5 : 1 ,or higher, hence a Quick Change Rearend
Ecky what's the name of the program/link you use for your graph. I've been looking for something like that.
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
01-07-2019, 04:30 PM
#24 (permalink)
Seems like at least with ford everything they sell they tout the acceleration and fun factor of the vehicle over FE. lol
*see useless ST variant of suv/cuv.
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
01-07-2019, 04:32 PM
#25 (permalink)
Althought a 2019 Ford Ranger with the 300lb-ft off idle 2.3 four cylinder would be a good truck to do a swap on. Literally a 10 speed transmission and the FD ratio is still only 0.64. If thats the case im taking off the 3.73s and 30" all terrains and putting on LRR tires and 2.73s! Surely the truck could get 30s on the highway at that point.
01-07-2019, 04:38 PM
#26 (permalink)
Originally Posted by gumby79
Od
Here it is: Gear Ratio RPM Chart Calculator
Rich
01-07-2019, 04:39 PM
#27 (permalink)
I would go lower to 2:47 of if you can find them then 2:26.
Rich
01-08-2019, 08:51 AM
#28 (permalink)
Rich
Its common Ford gears. Typically the lowest you will fine are 2.73, 3.08, 3.15, 3.31, 3.45, 3.55, 3.73, 4.10.
01-08-2019, 09:23 AM
#29 (permalink)
That is a fact, they are rare, but at one time for some cars or trucks they DID make them.
Here is the data I am working from:
Ring gear measures 8.8".
28 Spline axle shafts with a 1.29" diameter
31 Spline axle shafts with a 1.32" diameter
Ratios: 2.26, 2.47, 2.73, 3.08, 3.27, 3.31, 3.45, 3.55, 3.73, 4.10 & 4.56, 5.14
This is from here: https://en.wikipedia.org/wiki/Ford_8.8_axle
Rich
01-08-2019, 10:27 AM
#30 (permalink)
I think richmond gear has a 2.29 or a 2.50 but im not sure how interchangeable 8.8 internal stuff is.
Their web site sucks. Maybe I am wrong.
