Old 01-16-2019, 05:17 PM   #91 (permalink)
You're an ecomodding hero. What year was that? No mention of Darko because it was a different vehicle?
Et tu, Gumby.
aerohead (01-19-2019)
Old 01-17-2019, 12:27 AM   #92 (permalink)
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
Same same.
I tested more than 1 configuration before settling on 5" center and 7" on the corners of the air dam. Posted hear.
Gumby /David
V1 prototype was just the 2.5" Bronco air dam bolted to the bottom of the bumper I did not notice a positive or negative change on the gravity drop acceleration test
https://ecomodder.com/forum/showthre...rty-35894.html
You had been active in the thread, thought you knew about the gravity drop results. Pine wood derby cars in Cub Scouts taught me these fundamentals. The heavier more streamlined a block of wood when's the race with one gravity horsepower.
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
Old 01-17-2019, 11:08 PM   #93 (permalink)
Tufts, surface pressures and local flow veclocities
Old 01-18-2019, 04:10 AM   #94 (permalink)
teoman's Avatar
A3 - '12 Audi A3
Thank you for these videos!
Very informative.
What should we as ecomodders be aiming for? Suspension compressed or elongated? Or no change at all?
Old 01-18-2019, 04:46 AM   #95 (permalink)
No lift or downforce will result in less induced drag. ie no suspension height change with speed.
However, it's a bit more subtle than that because if there is lift or downforce present, you need to get rid of it without then creating a lot of drag.
As Dick Barnard said to me when we were working on the book, you can destroy lift by placing a fence across the curved roof - but that won't be so good for drag!
Old 01-19-2019, 04:13 AM   #96 (permalink)
Resolving the direction of forces caused by the surface body pressures you can measure - lift and downforce, thrust and drag.
Old 01-19-2019, 12:30 PM   #97 (permalink)
what year
Et tu, Gumby.
I ran Bonneville and did the Chrysler Proving Grounds both in 1991.
It was with 'Spindletop',the streamlined 1984 HONDA CIVIC CRX HF.
It would be in my photo library at the Aero Forum.
freebeard (01-19-2019)
Old 01-20-2019, 02:56 PM   #98 (permalink)
Separation edges and wake size.
The Following 2 Users Say Thank You to JulianEdgar For This Useful Post:
aerohead (01-23-2019), freebeard (01-20-2019)
Old 01-20-2019, 03:46 PM   #99 (permalink)
My favorite dust picture:
It shows the three zones of turbulence around an open wheel. The top is defined by dirt carried over-top by the tire. The center vortex is mixed with turbulence off the axle, and the vortexes off the leading edge of the contact patch are still low to the ground by the time they reach the back tire.
Old 01-21-2019, 03:06 PM   #100 (permalink)
The Following 3 Users Say Thank You to JulianEdgar For This Useful Post:
aerohead (01-23-2019), freebeard (01-21-2019), gumby79 (01-31-2019)
