Old 04-28-2020, 10:52 PM   #241 (permalink)
My new way of measuring changes in on-road drag.
Introduction and background:
Quantifying changes in drag coefficient:
The Following 4 Users Say Thank You to JulianEdgar For This Useful Post:
aerohead (04-29-2020), COcyclist (05-03-2020), freebeard (04-29-2020), redneck (04-29-2020)
Old 04-28-2020, 11:13 PM   #242 (permalink)
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
Shopping cart becomes aerodynamic body
You could build it like arrowheads Spirit of ecomodder model used bicycle wheels in the short-term put the birdcage over the top of it and as Julian said spandex with a paint to stiffen it or shrink wrap( the cheap3-7mil stuff down at the marina would be fine for this approach ). All you need is the wheelbase/width and the cage exterior dimensions. you could skip filling superstructure other than hardpoints for mounting The Birdcage. I would suggest a phone call to the manufacturer to get dedicated locations of the cage structure set your hard points don't have to move from prototype shape testing to practical application.
Clamps like this would work nice.
4 atempts to post a pic usung my normal methods no dice. So hears the www. to it.
https://www.speedwaymotors.com/All-I...mps,42491.html
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
The Following User Says Thank You to gumby79 For This Useful Post:
Old 04-29-2020, 03:03 AM   #243 (permalink)
If you limit power to 20-40% is there difficulty working up through the intermediate gears?
gumby79 — Back when we were at Darko wind tunnel, I looked at a 1/3rd scale model, but the 26.5" tires become nine inches tall tricycle wheels. I keep bugging Arcimoto for a .obj file but they aren't releasing anything.
Two wrongs don't make a right, but three lefts do.
Old 04-29-2020, 03:08 AM   #244 (permalink)
Interestingly enough, no. Power = torque x rpm, and since when going up through the gears you can use a lot more revs, it's quite easy to get up to speed, even with the relatively small throttle opening.
Last edited by JulianEdgar; 04-29-2020 at 12:57 PM.. Reason: Silly mistake corrected
The Following 2 Users Say Thank You to JulianEdgar For This Useful Post:
aerohead (04-29-2020), freebeard (04-29-2020)
Old 04-29-2020, 04:10 AM   #245 (permalink)
gumby79's Avatar
Team Streamliner
Pickups
... 26.5" tires become nine inches tall tricycle wheels. I keep bugging Arcimoto for a .obj file but they aren't releasing anything.
Insted of .33% go .447%=12.01", 2nd hand store kid bike to go scale, or go full scale with 26"ers if you wanted trunk space you could use 12" pop up tent trailer tires for the front. Then when you get the bike and relocate the monocoque simply turn it around and hitch it to the back of bike with locked out or compassion stearing as your Oregon <1500lb free utility/garden trailer.
I meant minimal running gear/structure for a tadpole a simple T frame with stub spindles bolted /clamped secured and a hollow interior.
Dont ask for all there desine secrets,just 3d locations of key bars in relationship to the axel pins So that you can locate youre bolt holes.
Former
87' Hyundai Excel
Old 04-29-2020, 12:04 PM   #246 (permalink)
bicycle wheels
Actually,they were a 1/3rd-scale, 235/75 R-15 wheel,solid rubber unit,with solid,full-coverage, 'MOONs' inside and out,from Harbor Freight.They were the only thing I could purchase off -the-shelf which fit the scale.
Old 04-29-2020, 12:33 PM   #247 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
Originally Posted by JulianEdgar View Post
Torque = power x rpm
I think it's actually power times the inverse of rpm and angular distance swept, or power divided by rpm:
Power = (torque)(angular velocity) = (torque)(2pi)(# revs / time)
Torque = (power) / [(2pi)(# revs / time)] = [(power)(time)] / [(2pi)(# revs)]
Which would mean that, limited to a specific power, less torque is developed as rpm increases.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
Old 04-29-2020, 12:56 PM   #248 (permalink)
I am sorry, I meant of course that power = torque x rpm. Original post corrected.
aerohead (04-29-2020), Vman455 (04-29-2020)
Old 05-01-2020, 01:46 AM   #249 (permalink)
These aren't diffusers!
53 seconds 35 minutes ago.
What does the not-a-turbo claim to be? A tin whistle?
edit: Youtube is pointing toward your vids.
Series and parallel switching in car electrical
11 views •Apr 30, 2020
Old 05-01-2020, 03:26 AM   #250 (permalink)
https://www.amazon.com.au/Car-Turbo-.../dp/B07DCHVYF7
freebeard (05-01-2020)
