09-27-2008, 09:19 PM
OCD Master EcoModder
Yee-hah! - picking up Civic HX Sunday
I bought a '97 Civic HX, 5-spd, gray, with dirty HX rims, a/c and power windows, but no cruise control. Finally convinced my good wife that I should buy a gas sipper for my 50 - mile commute.
It's about 2-1/2 hours drive from home. I saw it and drove it Thursday, will pick it up tomorrow (Sunday). I'm pumped! And, it looks like I have a road trip coming up in that car in early October. Cool.
Coast long and prosper.
09-27-2008, 09:49 PM
Dartmouth 2010
Congrats! You should definitely be able to cut those gas bills in half.
09-28-2008, 02:13 AM
Awesomeness, you'll be loving lean burn
09-28-2008, 03:08 AM
CAUTION: May Stink!!!
~Cool
I've never seen a HX that doesn't get at least 45 mpg!
.:: B16A2 HX/Si Coupe | '98 HX shell with full '99 CiViC Si swap | 40+ MPG
Listen to the people who fail. They know what they're talking about!
09-28-2008, 07:36 AM
Nice find - congrats!
Have you built yourself an MPGuino yet? It'll be more accurate than a ScanGauge with your lean burn motor.
09-28-2008, 08:37 PM
Originally Posted by BlackDeuceCoupe
~Cool
Yup! BlackDeuceCoupe was exactly right, it turned out.
I got 53 mpg over 137.2 miles, driving it home to CT from NH. I'm pleased!
I drove between 60-70 mostly, sometimes 80. I did coast on downhills, in neutral with engine running. A few fast starts and a small bit of a/c and defrost use. Tires at 37 psi cold because they're sidewall stamped for 35. If it had 44 psi tires I'd have pumped them up harder.
And MetroMPG, I don't know anything about a ScanGauge not being useful with lean burn. Clarify?
My understanding is that ScanGauge calculates fuel consumption based on injector open time and frequency - and calculates that against speed to get mpg. So? Even for hybrids - and the Insight is a hybrid with lean burn also - ScanGauge supposedly does a great job. You do have to set it to HYBRID mode for it to calculate engine-off coasting. If you don't set it to HYBRID it doesn't count distance if ign. is off.
As for MPGuino- yikes. I have a wife and a play in a band and sing in a choir and and and - I don't think I can right now muster the concentration to build that sort of thing. Sorry to disappoint you there. If I didn't have some of these other things going on I might be up to the challenge.
09-28-2008, 09:44 PM
My understanding is that the SG does not have access to injector pulse width/frequency, and that it's extrapolating fuel use assuming stoichiometric ratios, based on displacement, RPM, speed, etc. So it can't actually "see" lean burn mode.
Two Caveats For Hybrid Car Owners. First, I found the ScanGauge mpg calculations cannot accommodate the lean burn engine found in specific hybrid cars, such as the 5-speed Honda Insight. - Source
Maybe this has been addressed since I first heard about it. But I would certainly check into it before ordering a SG.
09-28-2008, 10:01 PM
Ecoformance Engineer
EJ7 - '96 honda civic Hx Last 3: 58.02 mpg (US)
Congrats on the Hx and 53mpg! These lean burn hondas are insanely capable of great FE, just depends on how far you wanna go
As for the MPGuino, there is a company that is going to make a complete kit so you dont have to source anything to put it together, just solder a bit. I'm sure you could even pay someone to build one for you and still have quite a bit less money into it then a Scanguage and be more accurate to boot.
Also I have been working on a obd2-obd2 ecu jumper harness that has all the connections for a MPGuino wired in already so it would be plug and play.
70 mpg or die modding
www.full-race.com
Originally Posted by MetroMPG
looking forward to seeing what kind of uber-sipper slinks out of the full race skunkworks.
09-29-2008, 11:29 AM
#9 (permalink)
That VX guy!
Congrats, Bruce. Welcome to the lean burn club, lol.
Build a MPGuino! Do eet, make some time, it'll pay off!
09-29-2008, 02:43 PM
#10 (permalink)
My personal best with a D16Y5 (OEM HX motor) was 62.5 MPG...
For the most part, I got 45-55 MPG. All depends on the fuel. With 'winter blends', e.g. lots of alcohol, I would lose 10%. No kidding!
Worst mileage I ever got was 38 MPG, when I was burning in some Hawk HPS pads.
Burnishing Instructions- After installing new brake pads, make 6 to 10 stops from approximately 30-35 mph applying moderate pressure.
- Make an additional 2 to 3 hard stops from approximately 40 to 45 mph.
- DO NOT DRAG BRAKES!
- Allow 15 minutes for brake system to cool down.
- After step 4 your new pads are ready for use.
LoL!
I did about 20 stops from approximately 60 mph - had 'em smoking like a barbeque!
