04-20-2017, 02:54 AM
#2121 (permalink)
...you are sitting at a traffic light and your antennae pick up a new, somewhat syncopated, rattle.
Then you realize your right next to a Dodge RAM 2500.
04-21-2017, 01:54 AM
#2122 (permalink)
i should weld
- ... you wish your non-sporty pickup truck was paddle-shift simply because it would mean you could upshift earlier than the TCM will let you
- ... you've contemplated fitting a sporty overdrive to that same truck for the same reason
- ... you still haven't gotten around to making your dream operating system for your computer because not only does the difficulty of said weigh on your mind but so does that of fitting an overdrive to a pickup
04-21-2017, 02:55 PM
#2123 (permalink)
Volvo-driving MachYeen
YKYAEM and even if you drive ethanol gas that is a lot cheaper, 23MPG makes you anxious
If you don't make any mistakes in your life,
life itself will be a f*ckup.
With Volvo to Valhalla and back!
04-21-2017, 11:36 PM
#2124 (permalink)
YKYAEM ....if you make jokes with the attendant at the pump about 'range anxiety' as you fill up with clear premium.
04-22-2017, 06:26 PM
#2125 (permalink)
Focused on MPG
YKYAEM when you keep your mouth closed so you don't fog up the windscreen and have to run defrost
Staying Focus'd on MPG
The Following 4 Users Say Thank You to ECO-AKJ For This Useful Post:
04-22-2017, 09:16 PM
#2126 (permalink)
Eco Sol
YKYAEM if you have converted your driving habits have affected those around you.
My wife now coasts to stops in neutral, accelerates down hills to coast up the next one, stays in neutral at stop lights, cycles her AC, and today she was swearing at a headwind.
Edit: YKYAEM if you turn your car off long BEFORE you get to the gas pump. Did this the other day and got some strange looks as I EOCd about 1/4 mile from the highway, onto the service road and into the parking lot, finally stopping at the pump as I was losing momentum.
Best Tank = 42.72 mpg (in the 94 Del Sol)
CR-Z Current Mods:
Max Sidewall PSI
The Following User Says Thank You to Shortie771 For This Useful Post:
04-23-2017, 05:11 AM
#2127 (permalink)
Hah, true. I keep telling myself to just breathe, but find myself holding in when my mind wanders
04-23-2017, 09:36 AM
#2128 (permalink)
Focused on MPG
YKYAEM if you hit the brakes at the speed limit thinking you're speeding because your used to going about 15mph slower
04-23-2017, 11:44 AM
#2129 (permalink)
Or, you could be driving an old 36hp Beetle with the heater flaps rusted shut.
04-24-2017, 08:44 AM
#2130 (permalink)
YKYAEM When you play Euro Truck simulator 2 and apply ecodriving techniques
