Old 05-30-2012, 02:56 PM   #31 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Originally Posted by Gasoline Fumes View Post
A slow-moving car was about to screw up my good coast, then I realized I could pass him.
YKYAHM when it takes you a moment to realise that you can also pass, not just be passed
The Following User Says Thank You to Piwoslaw For This Useful Post:
Gasoline Fumes (06-05-2012)
Old 05-30-2012, 06:57 PM   #32 (permalink)
MPG Militia HMV-25E80+A
JethroBodine's Avatar
FrankenJetta D - '90 Volkswagen Jetta GL
Diesel
90 day: 64.35 mpg (US)
...When you have to change the shut off time of your MPGuino to 10 minutes, because you started EOCing for more that the 7 minute preset time.
It is always very amusing how our imagination is put to the test when overcoming reality. Redyaris
Boat tail project
How to gently bump start during EOC
Old 05-31-2012, 02:35 AM   #33 (permalink)
meelis11's Avatar
Green frog - '97 Audi A4 Avant 1.9TDI 81kW
Diesel
90 day: 43.1 mpg (US)
It should stay on if it gets speed or injector signal.
Old 05-31-2012, 08:44 PM   #34 (permalink)
Diesel
No speed signal, and engine off for more than 7 minutes. I've been only using the GPH, trip total, and tank total function on my MPGuino.
Edit- My Jetta has a mechanical speedo.
Boat tail project
Old 06-01-2012, 05:46 AM   #35 (permalink)
meelis11's Avatar
Diesel
maybe something helpful (made new topic so others can find it too)
http://ecomodder.com/forum/showthrea...tml#post309903
The Following User Says Thank You to meelis11 For This Useful Post:
JethroBodine (06-01-2012)
Old 06-04-2012, 10:57 AM   #36 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
YKYAHM... When the guy riding your rear bumper is a school bus.
Transmission type Efficiency
The Following 3 Users Say Thank You to Fat Charlie For This Useful Post:
Gasoline Fumes (06-05-2012), Piwoslaw (06-05-2012), Sporty Modder (06-04-2012)
Old 06-08-2012, 03:45 PM   #37 (permalink)
Elise - '13 Hyundai Elantra GLS
You know you're a hypermiler if:
You've ever been passed by a Prius
You shift into neutral to speed up
You can drive for 10 minutes without touching the gas pedal (or using cruise control)
Old 06-08-2012, 04:04 PM   #38 (permalink)
The Dirty330 Modder
Gealii's Avatar
CruzeRS - '15 Chevy Cruze LT RS
90 day: 41.29 mpg (US)
YKYAHM....when you forget where you placed your fuel log in your car from not filling up
"The only real mistake is the one from which we learn nothing."
- Henry Ford
Old 06-09-2012, 08:38 AM   #39 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Check !
Check !
This part of the country is far too flat for that.
2 out of 3 ain't bad
The Following User Says Thank You to euromodder For This Useful Post:
wmjinman (10-31-2012)
Old 06-10-2012, 02:07 PM   #40 (permalink)
aero guerrilla
Piwoslaw's Avatar
YKYAHM if...
... All of the roads in your area seem much shorter when someone else is driving.
aggressive drivers, harassment, hypermiling, idiot drivers
